How to render view by RevitAPI
I want to render view by API, but Postcommand(RevitCommandId.LookupPostableCommandId(PostableCommand.Render)) is not effective, it can only open the dialog of render.
jeremytammik
I am asking the development team for advice for you on this.
There may already be some useful information on the topic in the articles on setting up a 3D view:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#5.37
Jeremy Tammik
Developer Technical Services
The Building Coder
Thank you, I am looking forward to your early reply
RPTHOMAS108
I was looking yesterday for this and I don't believe it is possible.
You can post the Render command but that brings up the modeless Render window, there is the ability to change Render options but not then activate the Render.
Was also interested to see if objects created via DirectContext3D were visible in the render, I suspected the asnwer was no and the observed answer was no (by trying duplicate geomery sample). I did kind of think this would have been good since we as an industry often create a lot of temporary objects for rendering (people), things that could be generated at render time within a certain view scope not model wide.
i.e. the workflow could have been Render activating, consider view scope, place RPCs within range, render, remove RPCs.
jeremytammik
The development team confirmed and say:
This seems to be available only through the UI. Sorry.
Jeremy Tammik
The Building Coder
r10521606
Wondering is it feasible in 2023 RevitAPI now? I have same experience of above comment that the rendering options windows will pop up when the program run to something related to GetRenderingSettings(), the GUI panel have export option but it seems not in API. Plus, using GUI is acceptable if it can do bunch rendering but it seems that feature only exist in Rendering in Cloud. Is there any alternatives?
