How to remove cut from beam to beam cut join through Revit API
How to remove cut, between beam to beam cut join, through Revit API.
matthew_taylor
Hi @Anonymous,
Check out StructuralFramingUtils: http://www.revitapidocs.com/2017.1/17e233e7-d975-6ed0-b86b-dbc5d1a918e2.htm
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
