How to refresh a Forge(APS) DockPanel ?
vitruviusbim
vitruviusbim
I have been trying   refresh  my  Forge DockPanel.  I use the  setData method  for refresh a  content div  but  panel do not changing. what  i need to try ?
export class View3dService {
  private viewer: any;
  private customPanel: CustomPropertiesPanel | null = null;
  error?: string;
  initViewer(freshToken: string, modelIdToView: string, apsViewnames? : ApsPresentationView[] ) {
    const options = {
      env: 'AutodeskProduction',
      getAccessToken: (onTokenReady: any) => {
        const token = freshToken;
        const timeInSeconds = 12000; // Use value provided by APS Authentication (OAuth) API
        onTokenReady(token, timeInSeconds);
    Autodesk.Viewing.Initializer(options, () => {
      const htmlDiv = document.getElementById('forgeViewer') as HTMLElement;
      this.viewer = new Autodesk.Viewing.GuiViewer3D(htmlDiv, {
        extensions: ['Autodesk.VisualClusters' ],
      const startedCode = this.viewer.start();
      if (startedCode > 0) {
        console.error('Failed to create a Viewer: WebGL not supported.');
        this.error = 'Failed to create a Viewer: WebGL not supported.';
        return;
      console.log('Initialization complete, loading a model next...');
      // Setup custom properties panel
      this.setupCustomPanel();
      const dropdown = document.getElementById('models') as HTMLSelectElement;
      if (dropdown) {
        this.populateDropdown(dropdown, apsViewnames);
        dropdown.onchange = () => {
          const selectedView = dropdown.value;
          if (selectedView) {
            this.loadModelView(modelIdToView, selectedView);
      } else {
        console.error("Dropdown element with id 'models' not found.");
  private setupCustomPanel(): void {
    this.viewer.unloadExtension('Autodesk.PropertiesManager');
    // Wait for the toolbar to be created
    this.viewer.addEventListener(Autodesk.Viewing.TOOLBAR_CREATED_EVENT, () => {
      // Create custom toolbar group
      const customToolbarGroup = new Autodesk.Viewing.UI.ControlGroup('custom-properties-group');
      this.viewer.toolbar.addControl(customToolbarGroup);
      // Create and add custom button
      const customButton = new Autodesk.Viewing.UI.Button('custom-properties-button');
      customButton.setToolTip('Custom Properties');
      customButton.setIcon('adsk-icon-properties');
      customButton.onClick = () => {
        if (!this.customPanel) {
          this.customPanel = new CustomPropertiesPanel(
            this.viewer,
            this.viewer.container,
            'custom-properties-panel',
            'Builtgenix Properties'
          this.customPanel.initialize();
          this.viewer.container.appendChild(this.customPanel['container']);
        this.customPanel['setVisible'](!this.customPanel['isVisible']());
      // Add the button to the custom toolbar group
      customToolbarGroup.addControl(customButton);
      // Add selection changed event listener
      this.viewer.addEventListener(Autodesk.Viewing.SELECTION_CHANGED_EVENT, () => {
        const selection = this.viewer.getSelection();
        if (selection.length > 0) {
          const dbId = selection[0];
          this.viewer.getProperties(dbId, (props: any) => {
            const name = props && props.name ? props.name : '';
            this.customPanel?.setData({ Name: name });
           this.customPanel?.['setVisible'](true);
        } else {
          this.customPanel?.['setVisible'](false);
This is class of custom panel
export class CustomPropertiesPanel extends Autodesk.Viewing.UI.DockingPanel {
  viewer: any;
  titleBar: any;
  closeButton: any;
  scrollContainer: any;
  footer: any;
  contentDiv: HTMLDivElement | null = null;
  constructor(viewer: any, container: HTMLElement, id: string, title: string, options: any = {}) {
    super(container, id, title, options);
    this.viewer = viewer;
  initialize() {
    this['container'].style.top = "10px";
    this['container'].style.left = "10px";
    this['container'].style.width = "300px";
    this['container'].style.height = "400px";
    this['container'].style.resize = "both";
    // Title bar
    this.titleBar = this['createTitleBar'](this['titleLabel'] || this['container'].id);
    this['container'].appendChild(this.titleBar);
    // Close button
    this.closeButton = this['createCloseButton']();
    this['container'].appendChild(this.closeButton);
    // Allow move
    this['initializeMoveHandlers'](this['container']);
    // Main content area
    this.scrollContainer = this['createScrollContainer']();
    this['container'].appendChild(this.scrollContainer);
    // Example content
    this.contentDiv = document.createElement('div');
    this.contentDiv.innerHTML = '<p>No element selected</p>'; // Use innerHTML instead of innerText
    this.contentDiv.style.padding = '16px';
    this.scrollContainer.appendChild(this.contentDiv);
    // Footer
    this.footer = this['createFooter']();
    this['container'].appendChild(this.footer);
  setData(data: { Name?: string }) {
    if (this.contentDiv) {
      // Clear existing content first
      // Example content
      this.contentDiv.innerHTML = '<p>No element selected 1</p>'; // Use innerHTML instead of innerText
charles
Charles.Piro
Here is a sample with a customPanelExtension for properties :
Main.js :
import { initViewer, loadModel } from './viewer.js';
const MODEL_URN = "";
const login = document.getElementById('login');
try {
    const resp = await fetch('/api/auth/profile');
    if (resp.ok) {
        const user = await resp.json();
        login.innerText = `Logout (${user.name})`;
        login.onclick = () => window.location.replace('/api/auth/logout');
        const viewer = await initViewer(document.getElementById('preview'));
        viewer.addEventListener(Autodesk.Viewing.EXTENSION_LOADED_EVENT, (e)=>{
            if (e.extensionId === 'Autodesk.PropertiesManager') {
                viewer.loadExtension('CustomPropertyPanelExtension');
        await loadModel(viewer, MODEL_URN);
    } else {
        login.innerText = 'Login';
        login.onclick = () => window.location.replace('/api/auth/login');
    login.style.visibility = 'visible';
} catch (err) {
    alert('Could not initialize the application. See console for more details.');
    console.error(err);
CustomPropertyPanel.js :
// Custom Property Panel
export default class CustomPropertyPanel extends Autodesk.Viewing.UI.PropertyPanel {
    constructor(container, id, title, options = {}) {
        this.container.style.resize = "both"//propertie for modify the size of panel
CustomPropertyPanelExtension.js :
import CustomPropertyPanel from './CustomPropertyPanel.js';
export default class CustomPropertyPanelExtension extends Autodesk.Viewing.Extension {
	constructor(viewer, options = {}) {
		super(viewer, options)
        this.options = options;
        this.panel = null;
        this.idNode = 1;
    load = () => {
        var propertiesTool = this.viewer.toolbar.getControl('settingsTools').getControl('toolbar-propertiesTool');
        propertiesTool.onClick= () => this.displayPanel();
        this.viewer.addEventListener(Autodesk.Viewing.AGGREGATE_SELECTION_CHANGED_EVENT, this.onSelectionChanged);
        return true;
    onSelectionChanged = (event) => {
        if (event.selections.length === 0 || event.selections[0].dbIdArray.length === 0) {
            this.idNode = 1;
        else if (event.selections[0].dbIdArray.length === 1) {
            this.idNode = event.selections[0].dbIdArray[0];
        if (this.panel != null && this.panel.isVisible())
            this.setProperties();
    displayPanel = () => {
        var self = this;
        if (self.panel == null) {
            self.panel = new CustomPropertyPanel(self.viewer.container, 'CustomPropertyPanel', 'Properties', self.options);
        self.panel.setVisible(!self.panel.isVisible());
        if (!self.panel.isVisible())
            return;
        self.setProperties();
    setMeshProperties = (object) =>{
        var self = this;
        if (self.panel){
            self.idNode = object.dbId
    setProperties = () => {
        var self = this;
        var _opening = null;
        if(this.openingExtension.allModelOpenings.filter(x => x.dbid == self.idNode).length){
            _opening = this.openingExtension.allModelOpenings.filter(x => x.dbid == self.idNode)[0];
        self.panel.removeAllProperties();
        self.viewer.model.getProperties(self.idNode, function (data) {
            self.panel.setTitle(data.name);
            data.properties.forEach(function (prop) {
                //console.log(prop);
                //If you want to change the properties
    unload =  () => {
        this.panel = null;
        return true;
Autodesk.Viewing.theExtensionManager.registerExtension('CustomPropertyPanelExtension', CustomPropertyPanelExtension);
PIRO Charles
Developer
PIRO CIE
Linkedin
