How to read and display revit file in a web viewer
Hello i'm new at revit api and i need to build an app that can read a revit file and display it in a web viewer.
does autodesk provide any api to read revit files?
jeremytammik
The easiest way to achieve this is to use BIM360 or Forge:
Using that approach, there is no need for an app or any Revit API usage at all.
They both translate the Revit model to a light-weight format for high-quality viewing on the web.
The cost is minimal or zero for a single model or limited usage.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
