How to "Group Parameter Under" in properties dialog?
I have successfully bound a shared parameter to a document. That part works out fine.
Now I want to programatically set the "Group Parameter Under" value.
I have searched a lot of places but I cannot find any hint on how to do this. Does the Revit API not support this task?
Any ideas?
Regards
Jan Grenov
jeremytammik
Dear Jan,
Thank you for your query.
Do you mean one of the groups defined by the BuiltInParameterGroup enumeration?
It defines loads of values with a PG prefix, presumably meaning 'parameter group', such as
  PG_MATERIALS = -5000105,
  PG_GRAPHICS = -5000104,
  PG_CONSTRUCTION = -5000103,
  PG_GEOMETRY = -5000101,
  PG_IDENTITY_DATA = -5000100,
You can specify the parameter group when you insert the parameter binding:
  doc.ParameterBindings.Insert( def, binding,
    BuiltInParameterGroup.PG_GEOMETRY );
Have you looked that up in the Revit API help file RevitAPI.chm?
That should really always be your first port of call, you know, before you post a question here.
Here is an example:
https://github.com/jeremytammik/FireRatingCloud/blob/master/FireRatingCloud/Cmd_1_CreateAndBindShare...
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Yep ... I have looked several places before posting my question here, and the API help was the first place I looked!
I really try not to place stupid question in this forum. Therefore my question may be a result of some language confusion or misunderstanding on my side, but it is certainly not a result of lazyness or lack of effort.
Anyway thanks for the answer Jeremy. I always have a big advantage of your examples.
Best regards
Jan
jeremytammik
Dear Jan,
Thank you very much for your confirmation and appreciiation!
Very commendable  🙂
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
