How to print images using event handler from winforms? Catch is i have to stay locked in to floorplans because my current program does not work on 3dview
allazaruszcheong_21
Message 1 of 12
allazaruszcheong_21
Alot of guides i have followed were not successful
``` printing views 1
private void button33_Click(object sender, EventArgs e) // It doesnt work
            // Get the current Revit document and active view
            UIDocument uidoc = uiapp2.ActiveUIDocument;
            Autodesk.Revit.DB.Document doc = uidoc.Document;
            Autodesk.Revit.DB.View activeView = uidoc.ActiveView;
            // Create a new viewport for each angle
            List<Viewport> newViewports = new List<Viewport>();
            FilteredElementCollector collector = new FilteredElementCollector(doc, activeView.Id);
            ICollection<ElementId> viewportIds = collector.OfCategory(BuiltInCategory.OST_Viewports).ToElementIds();
            foreach (ElementId viewportId in viewportIds)
                Viewport viewport = doc.GetElement(viewportId) as Viewport;
                if (viewport != null)
                    for (int i = 0; i < 360; i += 10)
                        Viewport newViewport = Viewport.Create(doc, activeView.Id, viewport.ViewId, viewport.GetBoxCenter());
                        XYZ direction = new XYZ(Math.Sin(i * Math.PI / 180), 0, Math.Cos(i * Math.PI / 180));
                        newViewport.SetBoxCenter(viewport.GetBoxCenter() + direction * 10); // Adjust the distance as needed
                        newViewports.Add(newViewport);
            // Extract an image from each new viewport
            List<Image> images = new List<Image>();
            foreach (Viewport newViewport in newViewports)
                using (Transaction tx = new Transaction(doc, "Capture Image"))
                    tx.Start();
                    // Set the active view to the new viewport
                    uidoc.ActiveView = doc.GetElement(newViewport.ViewId) as Autodesk.Revit.DB.View;
                    // Export the image
                    ImageExportOptions options = new ImageExportOptions();
                    options.ZoomType = ZoomFitType.FitToPage;
                    options.PixelSize = 300; // Adjust the pixel size as needed
                    options.FilePath = "C:\\Users\\Public\\Downloads\\RevitImages\\image"; // Specify the file path without extension
                    options.HLRandWFViewsFileType = ImageFileType.PNG;
                    doc.ExportImage(options);
                    tx.Commit();
            // Close the new viewports
                doc.Delete(newViewport.Id);
            MessageBox.Show("Images extracted successfully!");
this produces no images help
Accepted solutions (4)
Replies (11)
Message 2 of 12
Mohamed_Arshad
HI @allazaruszcheong_21
     From your question I can understand that you need to print each viewport from the sheet as a Image. If I'm correct then I can see few errors in your code.
1. If your trying to export multiple images but with the same name is not possible, Kindly add index like image_1 and make unique for every images.
options.FilePath = $"C:\\Users\\Public\\Downloads\\RevitImages\\image_{i}"; // Specify the file path without extension
2. Why you're creating existing new view ports again and deleting in outside transaction.
I need a elaborate definition from you side about the error so can explain your question in briefly with an example. So that I will easily 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
Message 3 of 12
allazaruszcheong_21
I thought the viewports remain after creating them in revit so i wanted to delete them as i thought they are physical items in revit that might lag my PC.
Also, i have to run the program in active 2Dview/floorplan, is that an issue? Also know that i am relatively new to C# and RevitAPI, most of the code above is just bits and pieces from the internet i combined...
Message 4 of 12
Mohamed_Arshad
    Still I didn't Understand your requirement clearly. You need to export image of view port from the sheets ?
Mohamed Arshad K
Message 5 of 12
allazaruszcheong_21
here is my revit model in 3D.
i want to get pictures of the orientations of the walls, so in this case N S E W, NE NW SE SW
allazaruszcheong_21_1-1700566783610.pngallazaruszcheong_21_2-1700566792971.pngallazaruszcheong_21_3-1700566804855.pngallazaruszcheong_21_4-1700566807980.png
Currently my code can only run on the "Floor plan"
if i try to run it in 3dview it will not work.
Currently the button that starts the image export is this:
Message 6 of 12
ctm_mka
As Mohamed stated, change the end of your export file path, something like, dont forget to set the file type! (unless i missed that in your code already)
"//image_"+ ViewName + ".png;
 As for the extra views, set your active view to your floor plan you set as Active View in the beginning, before closing/deleting views. Something like this is think:
doc.ActiveView = activeView;
Message 7 of 12
allazaruszcheong_21
Program runs, however the images dont get saved, directory is correct, i rightclick and press copy addressn then subsequently added yall's requests..
Message 8 of 12
Mohamed_Arshad
    Above code is different from your requirement. Kindly follow the below steps and refer the below code to achieve your requirement.
Steps to be Followed
1. Filter the Elevation ex. East, West.
2. Make Elevation as Active View.
3. Export Image.
Note:
Make sure the Crop Region is Fitted to the Image, Unless the Image is will not export in correct position.
Reference Code
UIDocument uidoc = commandData.Application.ActiveUIDocument;
            //Root Path
            string rootPath = $@"{Environment.GetFolderPath(Environment.SpecialFolder.Desktop)}\Export_Images";
            //Filter Elevation
            List<View> viewList = new FilteredElementCollector(doc)
                .OfClass(typeof(View))
                .Cast<View>()
                .Where(x => x.ViewType.Equals(ViewType.Elevation))
                .Where(x=> ! x.IsTemplate)
                .ToList();
            //Itterate Each View and Export as Image
            foreach(View view in viewList)
                //Make Active View
                uidoc.ActiveView = view;
                //Refresh Active View
                uidoc.RefreshActiveView();
                //Export Image
                PrintImage(doc, rootPath, view.Name);
  public static void PrintImage(Document doc,string rootPath,string viewName)
            // Export the image
            options.PixelSize = 1080;
            options.ImageResolution = ImageResolution.DPI_300;
            options.FilePath = $@"{rootPath}\{viewName}";
Demo Video
I Hope this will Helps 🙂
Mohamed Arshad K
Message 9 of 12
allazaruszcheong_21
Your code works wonderfully, but i also found a solution here:
// Get the desktop path
string desktopPath = Environment.GetFolderPath(Environment.SpecialFolder.Desktop);
// Specify the folder and file name
string folderName = "Orientations_Folder";
string fileName = "PlaceHolder.txt";
// Combine the desktop path, folder name, and file name
string filePath = Path.Combine(desktopPath, folderName, fileName);
// Create the folder if it doesn't exist
Directory.CreateDirectory(Path.Combine(desktopPath, folderName));
var uidoc = uiapp2.ActiveUIDocument;
var doc = uidoc.Document;
var ieo = new ImageExportOptions
ZoomType = ZoomFitType.Zoom,
PixelSize = 512,
FilePath = filePath,
FitDirection = FitDirectionType.Horizontal,
HLRandWFViewsFileType = ImageFileType.PNG,
ImageResolution = ImageResolution.DPI_72,
ExportRange = ExportRange.SetOfViews,
ElementCategoryFilter filter = new ElementCategoryFilter(BuiltInCategory.OST_Views);
FilteredElementCollector views = new FilteredElementCollector(doc);
views.WherePasses(filter).WhereElementIsNotElementType().ToElements();
IList<ElementId> ImageExportList = null;
foreach (Autodesk.Revit.DB.View view in views)
if (view.ViewType == ViewType.Elevation)
try
ImageExportList = new List<ElementId>();
ImageExportList.Add(view.Id);
ieo.SetViewsAndSheets(ImageExportList);
doc.ExportImage(ieo);
catch (Exception ex)
System.IO.File.WriteAllText(filePath, view.Name + " " + ex.Message);
Message 10 of 12
Mohamed_Arshad
 Kindly mark as solution which suit for you. So that others can easily find the answer
Mohamed Arshad K
Message 11 of 12
allazaruszcheong_21
I assume if i want other views like North East North West, South East, South West, i need to create and add the elevations myself?
Message 12 of 12
Mohamed_Arshad
     Yes you need to add Elevation for North East North West, South East, South West. Kindly get the sample code from below link.
URL :https://maciejglowka.com/blog/creating-elevation-views-with-api/#:~:text=ElevationMarker%20marker%20...
Mohamed Arshad K
