I developed a plugin which convert cad lines into pipes ;
I tested 9 dgw files,the result is ok;
but in the 10th dwg,I found some error and made some adjust in my code;
To ensure no new bugs are introduced after that modification,I have to re-test the privious 9 dwg files.
Is there a way that the test can be done automaticly?
For a method,I can use unitTesting,how can I test a plugin like a method?
Developer Advocacy and Support +
