How to obtain view range from a view template?
DanielKP2Z9V
DanielKP2Z9V
I'm trying to obtain view range from a view template, but can't find it in revit api? Is it possible at all?
using System;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
[Transaction(TransactionMode.ReadOnly)]
public class ShowViewRange : IExternalCommand
    public Result Execute(
        ExternalCommandData commandData,
        ref string message,
        ElementSet elements)
        try
            // Get the current document and active view
            UIDocument uidoc = commandData.Application.ActiveUIDocument;
            Document doc = uidoc.Document;
            View activeView = doc.ActiveView;
            if (activeView == null)
                TaskDialog.Show("Error", "No active view found.");
                return Result.Failed;
            // Debug information about the view
            string viewInfo = $"View Name: {activeView.Name}\n" +
                            $"View Type: {activeView.ViewType}\n";
            // Get the View Template assigned to the active view
            ElementId templateId = activeView.ViewTemplateId;
            // Check if view template exists
            if (templateId != null && templateId != ElementId.InvalidElementId)
                View viewTemplate = doc.GetElement(templateId) as View;
                if (viewTemplate != null)
                    // Get view range information
                    string viewRangeInfo = GetViewRangeInfo(viewTemplate);
                    // Display complete information
                    TaskDialog.Show("View Template Information",
                        viewInfo +
                        $"Template Name: {viewTemplate.Name}\n" +
                        $"Template Id: {templateId}\n" +
                        "View Range Parameters:\n" +
                        viewRangeInfo);
                else
                        viewInfo +
                        $"Template ID exists ({templateId}) but failed to retrieve template.");
            else
                // Check if view has a non-locked template
                Parameter viewTemplateParam = activeView.get_Parameter(BuiltInParameter.VIEW_TEMPLATE);
                string templateName = viewTemplateParam?.AsValueString() ?? "None";
                TaskDialog.Show("Template Status",
                    viewInfo +
                    $"View Template Applied: {templateName}\n" +
                    "Note: The template might be applied but not locked.\n" +
                    "To get view range information, the template needs to be locked.");
            return Result.Succeeded;
        catch (Exception ex)
            TaskDialog.Show("Error", $"An error occurred:\n{ex.Message}\n\nStack Trace:\n{ex.StackTrace}");
    private string GetViewRangeInfo(View viewTemplate)
        string GetParamValue(BuiltInParameter param)
            Parameter p = viewTemplate.get_Parameter(param);
            return p != null && p.HasValue ? p.AsValueString() : "Not Set";
        return string.Join("\n", new[]
            $"Top: {GetParamValue(BuiltInParameter.PLAN_VIEW_CUT_PLANE_HEIGHT)}",
            $"Cut Plane: {GetParamValue(BuiltInParameter.PLAN_VIEW_RANGE)}",
            $"Bottom: {GetParamValue(BuiltInParameter.PLAN_VIEW_LEVEL)}"
TripleM-Dev.net
Use GetViewRange, from ViewPlan (see: https://www.revitapidocs.com/2023/0a8b7c58-406d-b801-5921-8b23568806be.htm )
So Viewtemplate should be a ViewPlan type (not just view)
Just like retrieving the viewrange from floorplans.
With a small catch: a viewtemplate range doesn't have to option for selecting levels, only relative "terms" like Associated level, Level below and Unlimited.
I think Associated level = -1 (elementid.invalid), don't know for the others, likely -2, -3 or so.
Set up a few viewtemplates with these settings and use RevitLookup to inspect the values and meaning.
I checked a ViewTemplate parameters, it doesn't have "BuiltInParameter.PLAN_VIEW_CUT_PLANE_HEIGHT", neither does a floorplan??
Well anyway use the PlanViewRange object
Gr Michel
