Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
How to move the topoSurface below?
4 REPLIES 4
682 Views, 4 Replies
Hi to all programists!
I import topoSurface into revit :
But it's location is too high. I want to have the average value of the points along the axis Z on the level 1:
How to do this right? Should I use MovePoints method in TopographyEditScope transaction or something else? Thanks for any help.
Tags (2)
4 REPLIES 4
aignatovich
Hi!
First of all, get average Z from the surface points (surface.GetPoints()), then calculate the distance (this value minus your level project elevation),
then call ElementTransformUtils.MoveElement(doc, surface.Id, -1*distance*XYZ.BasisZ)
in reply to: aignatovich
Thank you very much for your reply.
Could you please help me with one more problem? With your code i have an exception: "A managed exception was thrown by Revit or by one of its external applications"
My code looks about this:
using (Transaction tr = new Transaction(CurrentRevitDocument, "VIEW_3D"))
    tr.Start();
    TopographySurface topoSurface = TopographySurface.Create(CurrentRevitDocument, Points);
    double distance = getCoordinatesOfZAxis(Points, 3).Average();
    ElementTransformUtils.MoveElement(CurrentRevitDocument, topoSurface.Id, -1 * distance * Autodesk.Revit.DB.XYZ.BasisZ);
    tr.Commit();
And in line with moveElement method i have my exception.
Thanks.
aignatovich
Hmm. Strange thing.
Try to split creation of topography surface and moving it down in separated transactions. You can join them later in a transaction group.
Thank you very much for your help.
