How to modify some parameters value (like "Luminous Flux") inside a family doc
Message 1 of 8
Hello all,
I need to change the electrical properties of some Revit family files, related to lighting fixtures (lighting category).
I've found some interesting things at http://thebuildingcoder.typepad.com/blog/2009/04/deeper-parameter-exploration.html . Anyway, as far as I understand it seems to concern family instances inside a revit project.
I have to make these changes directly in the .rfa files.
For instance, I would like to change the "Initial Intensity" by giving the value of the "Luminous Flux".
How to reach the BuiltInParameter FBX_LIGHT_INITIAL_INTENSITY and FBX_LIGHT_LIMUNOUS_FLUX in the FamilyManager object ?
If not possible, is there a workaround ?
Regards
Jean-Robert
Replies (7)
Message 2 of 8
MarryTookMyCoffe
I'm not sure about that specific FamilyParametr but this is how I usually do it.
1 i get family document change parameters
Document familydoc = doc.EditFamily(some_family);
FamilyParameterSet FPS =  familydoc.FamilyManager.Parameters;
foreach ( FamilyParameter fP in  FPS)
 if(fP.Definition.Name == "some name of parameter")
  familydoc.FamilyManager.Set(fP, someKindOfValue);
2 than if it didn't change, try: document.LoadFamily(familydoc) or you can experiment with saving files and than load it.
do not worry it only gonna take Autodesk 5 years to fix bug
Message 3 of 8
豪三品8170
I have just bumped into exactly the same problem. Did you find a solution or workaround since then?
Message 4 of 8
Revitalizer
in the RevitAPI.chm, there are a few code samples for LightType and its members.
For example on "LightFamily.SetLightDistributionStyle" page.
There you can see how to get LightTypes in the family document:
public void ModifyLightDistributionStyle(Document familyDoc)
    // Get the light family from the static method.
    LightFamily lightFamily = LightFamily.GetLightFamily(familyDoc);
    // Set the light distribution style to PhotometricWeb
    lightFamily.SetLightDistributionStyle(LightDistributionStyle.PhotometricWeb);
    // After light shape style set to PhotometricWeb, each tyoe returns a CircleLightShape instance,
    for (int index = 0; index < lightFamily.GetNumberOfLightTypes(); index++)
        LightType lightData = lightFamily.GetLightType(index);
        PhotometricWebLightDistribution lightDistribution =
            lightData.GetLightDistribution() as PhotometricWebLightDistribution;
        lightDistribution.PhotometricWebFile = @"C:\IES\1x4 2Lamp.ies"; // input a full file path here.
        lightDistribution.TiltAngle = Math.PI / 6;    // use radian value to set
        lightData.SetLightDistribution(lightDistribution);  // set back
Once you have a LightType, you can set its properties, for example the initial intensity.
Depending on which BuiltInParameter you want to adress, use
lightData.SetInitialIntensity(new InitialFluxIntensity(lumen));
FBX_LIGHT_LIMUNOUS_INTENSITY
lightData.SetInitialIntensity(new InitialIlluminanceIntensity(1, candela));
FBX_LIGHT_WATTAGE
lightData.SetInitialIntensity(new InitialWattageIntensity(1, watt));
FBX_LIGHT_EFFICACY
lightData.SetInitialIntensity(new InitialLuminousIntensity(lumenPerWatt));
Also, there is a code sample for setting the initial color, on page "LightType.SetInitialColor":
public void SetInitialColorProperty(LightType lightType)
    InitialColor initialColor = lightType.GetInitialColor();
    if (initialColor is CustomInitialColor)
        CustomInitialColor custom = initialColor as CustomInitialColor;
        double colorTemperature = custom.Temperature;
        // Set new value for color temperature and set modified initial color to LightType.
        custom.Temperature = 3450.0;
        lightType.SetInitialColor(custom);
        // Create a PresetInitialColor and set it to LightType.
        PresetInitialColor preset = new PresetInitialColor(ColorPreset.Halogen);
        lightType.SetInitialColor(preset);
And so on.
RevitAPI.chm says "Since: 2013".
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 5 of 8
豪三品8170
I really appreciate your detailed answer. And yes, it solved my problem completely!
(I wonder why I couldn't find anything about the Autodesk.Revit.DB.Lighting namespace while I was googling around...)
Thank you!!
tmishina
Message 6 of 8
franjavigarciavalencia
Hello, I have tried using this, but it seems that my LightFamily has no LightTypes in it (lightFamily.GetNumberOfLightTypes() = 0, although it does have a light source where I can load a photometric IES file) so I am at a loss as to what does this class control and how to create/manipulate it.
I am working from within the family itself, in case that may be the problem.
Thank you for your help.
Message 7 of 8
Revitalizer
just a guess.
There may be a relation between LightTypes and FamilyTypes.
In the Family document, after you have added a new FamilyType:
Does GetNumberOfLightTypes() return more than zero, then?
Perhaps family document needs regeneration or commited transaction between the two steps.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 8 of 8
I can't believe I forgot to create at least one type on the family I was using for tests.
Thank you very much, it works perfectly now.
