how to modify insulation's workset
KM_Yotsuha
KM_Yotsuha
I tried to set insulation's workset parameter and failed:
how to modify insulation's workset?
jeremy_tammik
If the parameter is read-only, its value cannot be changed. So, why is it read-only? Does this problem occur only with insulation? If so, I would suggest that you research how to fix it manually in the end user interface first. Once you have that sorted out, you can proceed to automate and step up into the programming task. Apparently, insulation workset may be a special case. Here are some discussions that seem to point that way:
https://duckduckgo.com/?q=insulation+workset
KM_Yotsuha
thank you~
