How to Load family from excel spreadsheet
Hi
I just learned how to read a excel file and retrieve all data into a single string.
           string Data = "";
           using(ExcelPackage package = new ExcelPackage(new FileInfo(filename)))
               ExcelWorksheet sheet = package.Workbook.Worksheets[1];
               for (int row = 3; row < 9999; row++)
                   var thisValue = sheet.Cells[row, 1].Value;
                   if (thisValue == null || thisValue.ToString() == "")
                       break;
                   for (int col = 1; col < 3; col++)
                       thisValue = sheet.Cells[row, col].Value;
                           break;
                       Data += thisValue.ToString() + ",";
                   Data += Environment.NewLine;
           TaskDialog.Show("Excel Data&colon; ", Data);
but How can I get a single string from each cell individuality by loop over each row?
for example I need string “Section” for the family symbol, and string “Type” for the category,
and use these 2 strings to load the family and its symbols. Like:
if (Type == "Beam")
FamilySymbol gotSymbol = null;
String fileName = "Families path for structural framing family";
String name = Section;
 using (Transaction t = new Transaction(doc, "Load"))
 t.Start();
 Family family = null;
 if (doc.LoadFamilySymbol(fileName, name, out gotSymbol))
 TaskDialog.Show("Status", name + " is loaded");
 t.Commit();
any suggestion or tips?
jeremytammik
Dear Sarkate,
From the way you phrase your question, I would suggest that you work through some basic .NET and C# tutorials before doing any more advanced work.
The question you ask is too basic and has nothing to do with the Revit API.
I'll take a stab at answering anyway:
The variable
thisValue
is assigned values from individual table cells, one at a time.
You could grab all the individual cell values from there.
Instead, the two lines
and
concatenate all these values into one single long string.
As said, if you do not see this for yourself, I would strongly advise you to proceed no futher with this project but play around with some basic .NET, C# and string manipulation tutorials first.
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Hi,Jeremy
Thanks for your reply and advice.
I've actually solved this problem by reading some C# thread over last weekend, It is much easier than i thought, this is the working code:
                for (int row = 1; row < 9999; row++)
                    var SectionVar = sheet.Cells[row, 1].Value;
                    var EltypeVar = sheet.Cells[row, 2].Value;
                    if (SectionVar == null || SectionVar.ToString() == "")
                        break;
jeremytammik
Well done!
Thank you for letting us know.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
