How to List Assembly Names In Linked File
CHtCAD
CHtCAD
We are trying to create a drop down dialogue which lists all the assemblies in a linked file.
Is this even possible via the API.
William
RPTHOMAS108
If the link is loaded then the project document of the link exists in the document set
UIApplication.Application.Documents
From set you can identify via Document.IsLinked
For a RevitLinkInstance you can also get the document via RevitLinkInstance.GetLinkDocument
You can filter for elements such as assembly instances in link documents as you would in the main document.
