How to know which curve is span direction in floor sketch?
qoreodlf37
qoreodlf37
Hi, I have a floor like this. And I get all curves of floor  sketch.
List<Curve> floorCurves = new List<Curve>();
foreach (CurveArray arr in floorSketch.Profile)
    foreach (Curve curve in arr)
        floorCurves.Add(curve);
I want to know which curve is span direction.
I'm trying to edit floor's sketch with SketchEditScope.
When I delete span direction curve and commit sketchEditScope, Revit say 'structural floor span direction not specified'.
I know I can change floor's structural to false.
But if I change floor's structural to false, Revit say 'Path Reinforcement can be placed only in Structural Floors and straight Structural Walls.' when the floor has Structure Path Reinforcemen.
So I want to know which curve is span direction, and set span direction to other curve when I delete span direction curve.
Is there a way to know?
Moustafa_K
I believe the span direction curve does not define the slope direction. Therefore, we can use this parameter to determine if the curve is a span curve or not
see this example if it can help
var modelLines = floor.GetDependentElements(
    new CurveElementFilter(CurveElementType.ModelCurve)
List<Curve> curves = new List<Curve>();
foreach (var modelCurveId in modelLines)
    var modelCurve = Doc.GetElement(modelCurveId) as ModelCurve;
    var canDefineSlop =
        modelCurve.get_Parameter(BuiltInParameter.CURVE_IS_SLOPE_DEFINING) != null;
    if (canDefineSlop)
        // I am a floor curve
    else
        // I am a Span direction curve
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
qoreodlf37
Thanks for your answer.
But canDefineSlop, all curve's canDefineSlop are true.
Do you know other way?
Moustafa_K
yes you are correct if the span Indication is part of the original curve. I was testing it on this case
Couldn't find a way to detect which curve, except by getting the bounding box of the model curve. it would reflect a bigger Bounding box than the other similar curve direction.  but still, this is not a reliable method.
I am out of thoughts at the moment
Moustafa Khalil
qoreodlf37
Thank you. I'll find another way!!
qoreodlf37
I solve this problem!
double angledirection = selectedFloor.SpanDirectionAngle;
var sketchEditScope = new SketchEditScope(doc, "Add profile to the sketch");
sketchEditScope.Start(floorSketch.Id);
using (var t1 = new Transaction(doc, "trans"))
    double tempSpanDirectionAngel = 1;
    t1.Start();
    selectedFloor.SpanDirectionAngle = tempSpanDirectionAngel;
    t1.Commit();
    t1.Start();
    //  Edit floor's Model Curves
    t1.Commit();
    t1.Start();
    selectedFloor.SpanDirectionAngle = angledirection;
    t1.Commit();
sketchEditScope.Commit(new FailuresPreprocessor());
When I change span direction angel of floor, new angle is created.
And modify floor's model curves, and change span direction anlge to original.
It works!
