How to handle the firing of a Revit command with CommandEventArgs C#
rita.aguiar
rita.aguiar
I would like to be able to register which commands are being used within the Revit aplication  C#.
To do so, I am trying with the CommandEventArgs.
I know that it is possible to register when the RevitCommandId is the same as e.g. "ID_OBJECTS_WALL" by using the ExecutedEventArgs:
AddInCommandBinding importBindingID_OBJECTS_WALL = application.CreateAddInCommandBinding(RevitCommandId.LookupCommandId("ID_OBJECTS_WALL"));
                importBindingID_WINDOW_CLOSE_HIDDEN.Executed += new EventHandler
                    <Autodesk.Revit.UI.Events.ExecutedEventArgs>((sender, arg) => application_Command(sender, arg, "ID_OBJECTS_WALL"));
However, I would like to register ANY command that the user fires and thus, it's not very feasible to use the ExecutedEventArgs with AddInCommandBinding for all Revit commands (+1200).
To do so, I am trying with the CommandEventArgs:
UIControlledApplication.CreateAddInCommandBinding(RevitCommandId) += new EventHandler
<Autodesk.Revit.UI.Events.CommandEventArgs>(application_Command);
But I am not sure which namespaces and classes to use to successfully handle this event, I'm not sure if I should use the UIControlledApplication, I'm not sure if I should use the CreateAddInCommandBinding. I have been looking at the Revit Api Docs but I couldn't figure it out.
Is it possible to register ANY command with the CommandEventArgs or the ExecutedEventArgs?
How can I achieve that?
Any help would be appretiated.
rita.aguiar
Unfortunately it is not possible to register any command in Revit.
I ended up using this method:
        public void application_DocumentChanged(Object sender, DocumentChangedEventArgs args_changed)
            // get document from event args_changed.
            Document doc = args_changed.GetDocument();
            // dump the element information
            ICollection<ElementId> addedElem = args_changed.GetAddedElementIds();
            foreach (ElementId id in addedElem)
                DumpEventArgs(id, doc, "Added");
            ICollection<ElementId> deletedElem = args_changed.GetDeletedElementIds();
            foreach (ElementId id in deletedElem)
                DumpEventArgs(id, doc, "Deleted");
            ICollection<ElementId> modifiedElem = args_changed.GetModifiedElementIds();
            foreach (ElementId id in modifiedElem)
                DumpEventArgs(id, doc, "Modified");
And I also used
elem.Category.Name
to identify which element in being added or modified.
to retrieve this:
        private void DumpEventArgs(ElementId id, Document doc, string changeType)
            Element elem = doc.GetElement(id);
            if (elem == null)
                // this branch is for deleted element due to the deleted element cannot be retrieve from the document.
                MessageBox.Show($"The user {Environment.UserName} edited a document: {changeType} of unknown category");
            else
                MessageBox.Show($"The user {Environment.UserName} edited a document: {changeType} {elem.Category.Name}");
