How to get the elements associated with each row in a Schedule using Revit API?
mespinosagKJG49
mespinosagKJG49
Community Visitor
Community Visitor
Hi everyone,
I'm working with the Revit API in C# and I need some help understanding how to map elements to individual rows in a Schedule.
So far, I can do the following:
  • I can get the rows of the schedule:
   ViewSchedule viewSchedule = viewSchedules.First(vs => vs.Name == schedule.Name);
   TableData tableData = viewSchedule.GetTableData();
   TableSectionData body = tableData.GetSectionData(SectionType.Body);
  • I can get the scheduled elements:
ICollection<ElementId> elementIds = viewSchedule.GetDependentElements(null);
 However, what I really need is to figure out how to get the element (or elements) associated with each specific row in the schedule.
Is there a direct way to do this in the API?
Any help or example would be much appreciated.
Thanks!
TripleM-Dev.net
As far as I know you can't directly get the element(s) associated with specified rows in a schedule.
GetDependentElements, will return more elements than needed.
Use a FilteredElementCollector and set as ViewId the schedule
Schedules in this respect behave like any other view so you get all elements listed in the schedule
Note:
- selection doesn't work directly, unless you activate a model view after selecting rows
- For Area and Rooms the "Not placed etc" setting is ignored and all are retrieved (with respect to filters)
To id the elements for a Row you would need to rebuild the filtering and grouping/sorting of the schedule, get all parameter fields etc. in you're app
And then compare that to the values in the rows....and then it may or may not be accurate.
- Michel
ctm_mka
try "GetCellText" from the ViewSchedule itself. Dont know if you can actually get this info, but heres what Revit Lookup is showing:
