How to get the center line of items in a rebar element?
hai_nn
Message 1 of 8
hai_nn
I have a rebar element with 4 lines as you can see in the picture.
I edited each item using edit rebar mode.
Using API how can I get exactly 4 lines of each of these items.
Thank you.
Replies (7)
Message 2 of 8
jeremy_tammik
Here is a solution to retrieve rebar curves:
Message 3 of 8
hai_nn
I tried transform but the results don't match the centerline items.
Take a look at the image below.
Can you suggest me more?
Message 4 of 8
Moustafa_K
can you send the a Revit file sample, i wasn't able to reproduce different behavior when you use GetCenterlineCurves(). So far it is always in a match with the rebar instances.
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
Message 5 of 8
hai_nn
Select the edit rebar button to adjust each item
Take a look at a model I created myself
Message 6 of 8
Moustafa_K
you need to use GetTransformedCenterlineCurves instead of  GetCenterlineCurves
var curves = rebar.GetTransformedCenterlineCurves(.......);
Moustafa Khalil
Message 7 of 8
tuan253461
If I edit the bar and delete some bar items in the rebar element, is there any way I can get the centerlines?
Message 8 of 8
jeremy_tammik
I see no connection between the two parts of your question, so, simply ignoring the 'if' aspect, here are some ideas on obtaining rebar centreline curves:
That issue has also been discussed repeatedly here in the forum, so a quick search might bring additional more pertinent results.
