How to get intersect curve from two intersected faces?
qoreodlf37
qoreodlf37
Hi, I want to get intersect curve from two intersected faces.
So I tried to use "floorTopFace.Intersect(face, out Curve intersectCurve)".
But this method return always 'intersect'.
I researche about this method in forum, I found out that method has a bug for a long time.
I want to know intersected curve(red curves) from two faces(scarlet, blue).
How to I do?
admaecc211151
face.Intersect(face, out Curve intersectCurve)
in this function, the "out" is also a return value in another way.
so you can use intersectCurve as a curve in your codes after that.
