How to Get ExportDWGSettings Use Revit2014 API
Message 1 of 8
   I will Get a Revit ExportToDwg infomation.And I found a class named ExportDWGSettings.When I create an ExportDWGSettings instance (ExportDWGSettings.Create(Document,string)),Revit was down.
Replies (7)
Message 2 of 8
Troy_Gates
Here is a quick example of creating DWGExportOptions:
DWGExportOptions dwgOptions = new DWGExportOptions();
dwgOptions.MergedViews = true;
dwgOptions.SharedCoords = true;
 You can change many of the export settings (like the 2nd and 3rd lines of code).
Message 3 of 8
Can you  give me a sample to get Export Dwg Layer Information?
Message 4 of 8
Aaron.Lu
See the example code, it is what you need?
var dwgSettingsFilter = new ElementClassFilter(typeof(ExportDWGSettings));
FilteredElementCollector settings = new FilteredElementCollector(RevitDoc);
settings = settings.WherePasses(dwgSettingsFilter);
foreach (ExportDWGSettings element in settings)
    var options = element.GetDWGExportOptions();
    var layerTable = options.GetExportLayerTable();
    foreach (var layerItem in layerTable)
        var layerInfo = layerItem.Value;
        if (layerInfo.CategoryType == LayerCategoryType.Model)
            var modifiers = layerInfo.GetLayerModifiers();
            foreach (var modifier in modifiers)
                var modifierType = modifier.ModifierType; // get modifier type
                var separater = modifier.Separator; // get separator
Aaron Lu
Developer Technical Services
Autodesk Developer Network
Message 5 of 8
Dale.Bartlett
Hoo boy, has anyone picked up the spelling mistake in the API?
var separater = modifier.Seperator;//.Separator; // get separator
Dale
______________
Yes, I'm Satoshi.
Message 6 of 8
Aaron.Lu
Good catch.
and this is fixed in Revit 2015.
Aaron Lu
Message 7 of 8
Dale.Bartlett
I have tested the suggestion and extended slightly. One difficulty I have is returning the sub-category. LayerCategoryType categoryType = layerInfo.CategoryType will return "Model" or "Annotation", but I can't seem to return the sub-category ie "Air Terminal Tags" etc. I'm missing something simple...
Possibly this is helpful for others:
<code>
public static void GetDWGExportSettings(RvtDoc pDoc)
var filter = new ElementClassFilter(typeof(ExportDWGSettings));
FilteredElementCollector settings = new FilteredElementCollector(pDoc);
settings = settings.WherePasses(filter);
string lstrExportTest = "Category Type"
+ "," + "Layer Name"
+ "," + "Color Name"
+ "," + "Color Number"
+ "," + "Cut Color Name"
+ "," + "Cut Color Number";
DWGExportOptions options = element.GetDWGExportOptions();
ExportLayerTable layerTable = options.GetExportLayerTable();
// get others, not done yet
ExportLinetypeTable linetypeTable = options.GetExportLinetypeTable();
LayerCategoryType categoryType = layerInfo.CategoryType;
string layerName = layerInfo.LayerName;
string colorName = layerInfo.ColorName;
int colorNumber = layerInfo.ColorNumber;
string cutColorName = layerInfo.CutLayerName;
int cutColorNumber = layerInfo.CutColorNumber;
lstrExportTest = lstrExportTest
+ Environment.NewLine
+ categoryType.ToString()
+ "," + layerName
+ "," + colorName
+ "," + colorNumber.ToString()
+ "," + cutColorName
+ "," + cutColorNumber.ToString();
if (categoryType == LayerCategoryType.Model)
ModifierType modifierType = modifier.ModifierType; // get modifier type
string separater = modifier.Seperator;//.Separator (spelling fixed in 2015); // get separator
// write test file with name of export settings
FileTools fileTools = new FileTools();
fileTools.WriteTextFile(@"D:\_TempDelete\" + element.Name + ".txt", true, lstrExportTest);
<code>
______________
Yes, I'm Satoshi.
Message 8 of 8
Dale.Bartlett
Self answer:
<code>
var info = item.Value;
// element info
LayerCategoryType categoryType = info.CategoryType;
string categoryName = item.Key.CategoryName;
string subCategoryName = item.Key.SubCategoryName;
<code>
Dale
______________
Yes, I'm Satoshi.
