How to get elements welded by Weld command from steel tab?
YarUnderoaker
YarUnderoaker
Is it posssible to get elements which welded by element of category OST_StructConnectionWeld?
jeremy_tammik
This is tricky (or maybe impossible) to answer without exploring a sample model, unless someone happens to know off-hand.
Have you explored your sample model yourself?
Here is the standard approach how to research to find a Revit API solution:
https://thebuildingcoder.typepad.com/blog/2017/01/virtues-of-reproduction-research-mep-settings-onto...
YarUnderoaker
Yep, I'm in process.
foreach(Subelement subelem in sublist)
  if (!subelem.HasParameter(new ElementId(BuiltInParameter.STEEL_ELEM_WELD_MAIN_THICKNESS))) continue;
  Reference rf = subelem.GetReference();
  FilerObject filerObj = this.GetFilerObject(doc, rf);
  WeldLine weld = filerObj as WeldLine;
  IEnumerable<Autodesk.AdvanceSteel.CADLink.Database.ObjectId> ObjList;
  weld.GetConnectedElements(out ObjList, 0);
I itterate throught structural connections sublelements and search welding. Then I try to get FillerObject but get null.
public static FilerObject GetFilerObject(Autodesk.Revit.DB.Document doc, Reference eRef)
   FilerObject filerObject = null;
   Autodesk.AdvanceSteel.DocumentManagement.Document curDocAS = DocumentManager.GetCurrentDocument();
   if (null != curDocAS)
      OpenDatabase currentDatabase = curDocAS.CurrentDatabase;
      if (null != currentDatabase)
         Guid uid = SteelElementProperties.GetFabricationUniqueID(doc, eRef);
         string asHandle = currentDatabase.getUidDictionary().GetHandle(uid);
         filerObject = FilerObject.GetFilerObjectByHandle(asHandle);
   return filerObject;
 Something wrong with this subroutine, because I can't get any filer object. I get it from help page of  GetSteelElementProperties class.
YarUnderoaker
Ok, there is nuance - to get filer object you must do this under fabrication transaction. Next simple macroc show info about weldings between different elements of connection.
		public void GetWeldedElementInfo()
			RVTDocument doc = this.ActiveUIDocument.Document;
			StructuralConnectionHandler hnd = StructuralConnectionSelectionUtils.SelectConnection(this.ActiveUIDocument);
			if (hnd == null) return;
			IList<ElementId> ids = hnd.GetConnectedElementIds();
    		IList<Subelement> sublist = hnd.GetSubelements();
    		List<WeldInfo> WeldInfos = new List<ThisApplication.WeldInfo>();
			using(RvtDwgAddon.FabricationTransaction t = new RvtDwgAddon.FabricationTransaction(doc, true, "SteelSheetParam"))
	    			if (!subelem.HasParameter(new ElementId(BuiltInParameter.STEEL_ELEM_WELD_MAIN_THICKNESS))) continue; //STEEL_ELEM_PLATE_WEIGHT
							if (filerObj is WeldPoint)
								WeldPoint weld = filerObj as WeldPoint;
								WeldInfo wc = new WeldInfo(subelem);
								foreach(Autodesk.AdvanceSteel.CADLink.Database.ObjectId objId in ObjList)
									FilerObject filerObject = FilerObject.GetFilerObject(objId);
									foreach(ElementId eId in ids)
										Element profile = doc.GetElement(eId);
										FilerObject pFiler = this.GetFilerObject(profile);
										if (pFiler.GetUniqueId().Equals(filerObject.GetUniqueId()))
										    	wc.profiles.Add(profile);
										    	break;
									foreach(Subelement subweld in sublist)
										Reference weldrf = subweld.GetReference();
										FilerObject filerObjW = this.GetFilerObject(doc, weldrf);
										if (filerObjW.GetUniqueId().Equals(filerObject.GetUniqueId()))
										    	wc.plates.Add(subweld);
										    	break;
								WeldInfos.Add(wc);
			string text = "";
			foreach(WeldInfo wc in WeldInfos)
				text += (wc.weld.GetParameterValue(new ElementId(BuiltInParameter.STEEL_ELEM_WELD_MAIN_TEXT)) as StringParameterValue).Value;
				text += " connected ";
				foreach(Subelement sub in wc.plates)
					Element pe = this.get_ElementParamater(wc.weld, "Пластина.Марка");
					StringParameterValue spv = sub.GetParameterValue(pe.Id) as StringParameterValue;
					if (spv == null) continue;
					text += spv.Value + ", ";
				foreach(Element prof in wc.profiles)
					Parameter p = prof.LookupParameter("КМ.Профиль");
					text += p.AsString() + ", ";
				text += "\n";
    		MessageBox.Show(text);
		private Element get_ElementParamater(Subelement sub, string name)
			List<ElementId> paramIds = sub.GetAllParameters().ToList();
			foreach(ElementId paramId in paramIds)
				Element param = sub.Document.GetElement(paramId);
				if(param == null) continue;
				if(param.Name == name) return param;
			return null;
