How to get elementId from LightNode?
e_juma
e_juma
I need track down each lights in the Revit. So, when user changes any of them, I can modify them accordingly. So, I need a way to distinguish a light to others. I thought elementId is useful. But LightNode is very simple. I do not figure out how to get elementId from it.
Can anyone help me?
jeremytammik
LightNode is issued in the custom exporter context. In the same context, you also get things like 'family instance begin' or 'processing element id'. Simply set a breakpoint in each method defined by the custom exporter and see for yourself where the element id associated with the light node pops up.
Jeremy Tammik
Developer Technical Services
The Building Coder
e_juma
Thank you! I will have a try.
