How to get element parameter's BuiltInParameter
Hi,everyone!How to get element parameter's BuiltInParameter?
such as parameter:Image its BuiltInParameter is All_Model_IMAGE.
Image:   ALL_MODEL_IMAGE
subject:  HOST_ID_PARAM
Revitalizer
if your Parameter's definition is an InternalDefinition, this has a BuiltInParameter property.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
thanks for your reply.
is there any revit api to get each BuiltInParameter property?
Thanks!
Revitalizer
you could iterate over the BuiltInParameter enum values.
For each BuiltInParameter, you could check if it is existing on your Element.
static List<BuiltInParameter> GetBuiltInParametersByElement(Element element)
	List<BuiltInParameter> bips = new List<BuiltInParameter>();
	foreach (BuiltInParameter bip in BuiltInParameter.GetValues(typeof(BuiltInParameter))
		Parameter p = element.get_Parameter(bip);
		if (p != null)
			bips.Add(bip);
return bips; }
Note that even if there are two Elements of the same category, saying two FamilyInstances of BuiltInCategory.OST_Windows,
it may be that one of them has got a given BuiltInParameter while the other one doesn't have.
Also, depending on how a Family has been constructed, a BuiltInParameter may be existing but without having a useful value.
For example, you can have different window families in your project file.
If you check the BuiltInParameter.WINDOW_WIDTH, it may be that this can be found twice, both as an element parameter and as a type parameter.
As an element parameter, it may return a value of 0. That means: the parameter is existing, not null, but does not provide a plausible value.
In this case, the type parameter BuiltInParameter.WINDOW_WIDTH may provide a realistic result.
Use RevitLookup to inspect your elements.
It displays the available BuiltInParameters and shows the mapping of the relating localized names.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
