I want to get center positon of a curtain system .
so I can change it. But I don't find any property to it.
Hi @nj19790605,
You can get the center position of the wall by using the following code
Wall w ;
LocationCurve Lc = w.Location as LocationCurve;
XYZ location = Lc.Curve.Evaluate(0.5, true);
string x = location.X.ToString();
string y = location.Y.ToString();
string z = location.Z.ToString();
You can refer the below link
thanks ,but curtain system is more complex.
It isn't a property. The information is available through the parameters of the curtainsystem, though I am afraid you don't get a XYZ-value for that point.
CurtainSystem curtain ; // Grid1 Parameter offset1 = curtain.get_Parameter(BuiltInParameter.CURTAINGRID_ORIGIN_1); Parameter justification1 = curtain.get_Parameter(BuiltInParameter.SPACING_JUSTIFICATION_1); Parameter angle1 = curtain.get_Parameter(BuiltInParameter.CURTAINGRID_ANGLE_1); // Grid2 Parameter offset2 = curtain.get_Parameter(BuiltInParameter.CURTAINGRID_ORIGIN_2); Parameter justification2 = curtain.get_Parameter(BuiltInParameter.SPACING_JUSTIFICATION_2); Parameter angle2 = curtain.get_Parameter(BuiltInParameter.CURTAINGRID_ANGLE_2);
thanks.
I have get xyz position.
1. change U grid number to 1;
2.change V grid number to 1;
3.use api function "grid.GetUGridLineIds()", "grid.GetVGridLineIds()"
so I get two Lines .
their intersect point is final result;
