Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
how to get contour lines from toposolid
9 REPLIES 9
Message 1 of 10
NZhouSNYLF
434 Views, 9 Replies
toposolid had a very big issue (at least for us) -> no contour lines displayed when "Modify Sub Elements", try to find solution or workaround, is API doable?
9 REPLIES 9
Message 2 of 10
jeremy_tammik
in reply to: NZhouSNYLF
I would assume that the contour lines can be accessed via view-specific geometry. Enter a view displaying them and use RevitLookup or some other database exploration tool to retrieve the toposolid view-specific element geometry. See if you can find the lines in there somewhere. If so, you should be able to copy their curve geometry and generate model curves from that.
Jeremy Tammik, Developer Advocacy and Support, The Building Coder, Autodesk Developer Network, ADN Open
Message 3 of 10
NZhouSNYLF
in reply to: jeremy_tammik
thanks Jeremy, i tried RevitLookup to search contour lines for both (new) Toposolid and (old) Topography but in vain, maybe i missed something simple?
Message 4 of 10
jeremy_tammik
IncludeNonVisibleObjects?
Message 5 of 10
NZhouSNYLF
so i can only access those contour lines via geometry instead of native Revit stuff? i'll give it a try, thanks Jeremy
edit: RevitLookup can find contour lines via GeometryElement
Message 6 of 10
NZhouSNYLF
hi Jeremy, i did a quick test, seems curtain wall works OK but toposolid doesn't, strangely RevitLookup looks OK but coding only list ONE solid
Message 7 of 10
jeremy_tammik
RevitLookup IS coding, exactly the same as yours, unless you missed something. Compare more carefully, spot the difference, and you will see how to achieve the same.
Message 8 of 10
NZhouSNYLF
thanks Jeremy, i did test for both Toposolid and TopographySurface
. RevitLookup can display contour lines info so it's doable as you mentioned early
. same coding approach works for TopographySurface but not for Toposolid
edit: need to add options.View = doc.ActiveView;
Message 9 of 10
jeremy_tammik
Great! Congratulations on solving it and thank you for the confirmation. Can you add a little bit more detail on your exact solution, maybe adding a small code snippet demonstrating the crucial points? Thank you!
Message 10 of 10
NZhouSNYLF
thanks Jeremy, works OK now after adding "options.View = doc.ActiveView;"
Rail Community
