How to get ConnectorSet or Connectors from FamilyInstance correctly?
gnab
gnab
Hello, everyone. I can't get ConnectorSet of FamilyInstance. I did almost the same thing like with Pipe but I got the Exception with FamilyInstanse. I tried also to get Connectors with LookUp method but sometimes I got the same Exception again. Why? How to get ConnectorSet of FamilyInstance correctly?
gnab
I think I can beat it. After placement of FamilyInstance you need to do doc.Regenerate() and then get Connectors from ConnectorSet with foreach cycle and creation a list of connectors. ConnectorSet and Lookup of FamilyInstance doesn't work correctly (ConnectorSet or one of Connectors provoke the Exception)..It's not normally, I suppose, because all of these methods work very well with Pipe but not with FamilyInstance. Devs should fix it.
reylorente1
Este es un metodo extraido de SDK Revit(
This is a method extracted from Revit SDK
/// <summary>
        /// Get all the connectors of a specific element
        /// </summary>
        /// <param name="element">the owner of the connector</param>
        /// <returns>if found, return all the connectors found, or else return null</returns>
        private ConnectorSet GetConnectorsElem(Autodesk.Revit.DB.Element element)
            if (element == null) return null;
            FamilyInstance fi = element as FamilyInstance;
            if (fi != null && fi.MEPModel != null)
                return fi.MEPModel.ConnectorManager.Connectors;
            MEPSystem system = element as MEPSystem;
            if (system != null)
                return system.ConnectorManager.Connectors;
            MEPCurve duct = element as MEPCurve;
            if (duct != null)
                return duct.ConnectorManager.Connectors;
            return null;
