How to get all Family in Project Document
s04049
s04049
Hi
I am trying to Get all Editable Family on Project Document but it not working with the this code
collector = new FilteredElementCollector(doc).OfClass(typeof(Family));
I can use FamilySymbol to Find the Family but it will have a duplicate family on the list.
 IList<Element> FamilySybol = new FilteredElementCollector(doc).OfClass(typeof (FamilySymbol)).ToElements();
List<Element> EditableFamily = new List<Element>();
foreach (FamilySymbol ele in FamilySybol)
if (ele.Category != null && ele.Family.IsEditable)
EditableFamily.Add(ele);
So how can I remove the duplicate Family on the EditableFamily List?
or find the All Editable Family on the Project Document?
matthew_taylor
The quick answer is by importing system.linq and using .distinct():
EditableFamily.distinct()
Cheers,
-Matt
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
s04049
Hi Matt
I try this method before and I still have the duplicate Family on the list.
Mustafa.Salaheldin
Here is the cure for your pain 🙂
The following code lists all the loadable families names in your project and populates it in a Task dialog.
#region Namespaces
using System;
using System.Text;
using System.Linq;
using System.Xml;
using System.Reflection;
using System.ComponentModel;
using System.Collections;
using System.Collections.Generic;
using System.Windows;
using System.Windows.Media.Imaging;
using System.Windows.Forms;
using System.IO;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Events;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.DB.Structure;
using Autodesk.Revit.DB.Mechanical;
using Autodesk.Revit.DB.Electrical;
using Autodesk.Revit.DB.Plumbing;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.UI.Events;
//using Autodesk.Revit.Collections;
using Autodesk.Revit.Exceptions;
using Autodesk.Revit.Utility;
using RvtApplication = Autodesk.Revit.ApplicationServices.Application;
using RvtDocument = Autodesk.Revit.DB.Document;
#endregion
namespace RvtTest
    [Transaction(TransactionMode.Manual)]
    [Regeneration(RegenerationOption.Manual)]
    public class ExtCmd : IExternalCommand
        #region Cached Variables
        private static ExternalCommandData _cachedCmdData;
        public static UIApplication CachedUiApp
            get
                return _cachedCmdData.Application;
        public static RvtApplication CachedApp
            get
                return CachedUiApp.Application;
        public static RvtDocument CachedDoc
            get
                return CachedUiApp.ActiveUIDocument.Document;
        #endregion
        #region IExternalCommand Members
        public Result Execute(ExternalCommandData cmdData, ref string msg, ElementSet elemSet)
            _cachedCmdData = cmdData;
            try
                //TODO: add your code below.
                FilteredElementCollector collector = new FilteredElementCollector(CachedDoc);
                ICollection<Element> elements = collector.OfClass(typeof(Family)).ToElements();
                StringBuilder sb = new StringBuilder();
                foreach (Element el in elements)
                    sb.AppendLine(el.Name);
                TaskDialog.Show("reavit", sb.ToString());
                return Result.Succeeded;
            catch (Exception ex)
                msg = ex.ToString();
                return Result.Failed;
        #endregion
Try the code and if it satisfied your needs just mark this reply as an answer.
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
s04049
Ok thanks for that, this code is working fine.
I just found the mistake after I catch the Family list.
