How to get access to data from "Visiblity/Graphics"?
Act-3D
Act-3D
I want to check if "Visiblity/Graphics" settings changed for a given View.
jeremytammik
Dear Artur,
Thank you for your query.
Have you tried searching the Internet for this information?
I get quite a lot of hits searching for "revit api visibility graphics":
https://duckduckgo.com/?q=revit+api+visibility+graphics
You probably should be more precise about what exact settings you wish to access, though.
Here is one specific example from The Building Coder:
http://thebuildingcoder.typepad.com/blog/2014/08/upcoming-event-calendar.html#5
There are many more, though.
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Act-3D
Hi Jeremy,
Thank you for your reply.
What I'm exactly looking for is list of model categories hidden in a given view.
I'm aware of:
GetCategoryHidden(ElementId categoryId);
But maybe there is a better way than iterating through all categories and check if it is hidden?
jeremytammik
Dear Artur,
Thank you for your update.
I am not aware of a better method.
Check the View class methods:
http://www.revitapidocs.com/2017/d8d64cdb-46b7-6486-7cb5-07178b65a87b.htm
There is also a Visible property on the Category class:
http://www.revitapidocs.com/2017/863e37ff-4415-5d39-d371-36c3284812d7.htm
You might want to take a look at this related discussion as well:
https://forums.autodesk.com/t5/revit-api-forum/user-hidden-categories/td-p/6377567
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
