How to force to run Add-Ins plugin in C# for Revit 2017 :)
910024
910024
Hi girls and boys, 🙂
right now I have Revit 2017 x64 v. 17.0.416.0,  MS Visual Studio 2017 x64 and everything this is working on Windows 7 SP1 x64 Ultimate.
I wouldl like to create my first plugIn to Revit 🙂
I added this source code into MS VS 2017 C#  (of course I added refferences on RevitAPI.dll and RevitAPIUI.dll, both from  c:\Program Files\Autodesk\Revit 2017\ directory into C# project) and I compiled it as x64 project - dll library (no AnyCPU is used - pure x64 project was bilt).
Final compilation - No errors - success !!!
using System;
using System.Reflection;
using System.Windows.Media.Imaging;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
namespace AddPanel
    /// <remarks>
    /// This application's main class. The class must be Public.
    /// </remarks>
    public class CsAddPanel : IExternalApplication
        // Both OnStartup and OnShutdown must be implemented as public method
        public Result OnStartup(UIControlledApplication application)
            // Add a new ribbon panel
            RibbonPanel ribbonPanel = application.CreateRibbonPanel("NewRibbonPanel");
            // Create a push button to trigger a command add it to the ribbon panel.
            string thisAssemblyPath = Assembly.GetExecutingAssembly().Location;
            PushButtonData buttonData = new PushButtonData("cmdHelloWorld",
               "Hello World", thisAssemblyPath, "AddPanel.HelloWorld");
            PushButton pushButton = ribbonPanel.AddItem(buttonData) as PushButton;
            // Optionally, other properties may be assigned to the button
            // a) tool-tip
            pushButton.ToolTip = "Say hello to the entire world.";
            // b) large bitmap
            Uri uriImage = new Uri(@"c:\Program Files\Autodesk\Revit 2017\AddIns\AddPanel\SMILE32x32.png");
            BitmapImage largeImage = new BitmapImage(uriImage);
            pushButton.LargeImage = largeImage;
         return Result.Succeeded;
      public Result OnShutdown(UIControlledApplication application)
         // nothing to clean up in this simple case
   /// <remarks>
   /// The "HelloWorld" external command. The class must be Public.
   /// </remarks>
   [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
    public class HelloWorld : IExternalCommand
            // The main Execute method (inherited from IExternalCommand) must be public
            public Autodesk.Revit.UI.Result Execute(ExternalCommandData revit,
                ref string message, ElementSet elements)
                TaskDialog.Show("Revit", "Hello World");
                return Autodesk.Revit.UI.Result.Succeeded;
I moved final .dll file + .addin + .png icon files to correct directory:  c:\Program Files\Autodesk\Revit 2017\AddIns\AddPanel\
see here:
Content of the .addin file is: (FullClassName classifier is correct - I hope so ...  )
<?xml version="1.0" encoding="utf-8" standalone="no"?>
<RevitAddIns>
  <AddIn Type="Application">
    <Assembly>AddPanel.dll</Assembly>
    <AddInId>604b1052-f742-4951-8576-c261d1993108</AddInId>
    <FullClassName>AddPanel.CsAddPanel</FullClassName>
    <VendorId>NAME</VendorId>
    <VendorDescription>Your Company Information</VendorDescription>
  </AddIn>
</RevitAddIns>
I closed Revit2017 and I launched it again but - as you can see - no added TabPage 😞  HellYaeh, JeepersCreepers !!! . And Revit is not able to describe where is problem - no error was posted.
Hovewer, I can see the "Add-Ins"  TabPage  provided by Revit 2017 (no LT version) .
So, where is errorr. Can someone help me ? I would like to be Revit PlugIn programmer in C#. 🙂
Kind regards
Jerry
Magnified (zoomed in ) only Add-Ins TabPage - hovewer NO "External Tools" button is visible:
Replies (7)
matthew_taylor
Hi @910024,
You look like you are doing okay.
Try putting your files directly (no subfolders) in the 'C:\Users\<your login>\AppData\Roaming\Autodesk\Revit\Addins\2017\' folder.
I know the .dll can be in a subfolder, but I'm not sure that an .addin manifest can be.
If you put them in the above folder, you should get some response.
If that doesn't work, try looking at the latest journal file (post it if you like) to see if that describes what is happening. (The latest journal can be found here: C:\Users\<your login>\AppData\Local\Autodesk\Revit\Autodesk Revit 2017\Journals\)
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
jeremytammik
Welcome to the Revit API!
In addition to Matt's good suggestion, you might want to work through the getting started material:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#2
That generally resolves most questions.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
910024
Hi, according to your recommendations I moved my .dll plug in to c:\Users\Jerry\AppData\Roaming\Autodesk\Revit\Addins\2017\
see here right window of TotalCommander and in back is newly launched Revit - no new TabPage - what can I do now ? ,
where is problem ? maybe the problem is somewhere amongst my ears 🙂 :
hovewer ... the situation is identical  - no added tab page. I also obtained some journals simultaneously:
First: journal.0001.worker1.log
' 0:< Initial VM: Avail 8388397 MB, Used 12 MB, Peak 12; RAM: Avail 6285 MB, Used 33 MB, Peak 12
' 0:< GUI Resource Usage GDI: Avail 9996, Used 4, User: Used 1
'C 30-May-2017 11:18:54.709;   0:< RevitWorker.exe 1
'C 30-May-2017 11:18:54.709;   0:< Worker Application Data: isWorkerForRevit=1, Name=RevitApplication, Ver=2015
'C 30-May-2017 11:18:54.709;   0:< ->UI-less InitNativeInstance
' 0:< Options::loadOptions: m_strDataLibraryLocations=Library=C:\ProgramData\Autodesk\RVT 2017\Libraries\Generic\ (defaultLib==\Library)
' 0:< ::0:: Delta VM: Avail -164 -> 8388233 MB, Used +32 -> 44 MB, Peak +38 -> 51 MB; RAM: Avail -2 -> 6283 MB, Used +47 -> 80 MB, Peak +47 -> 80 MB
' 0:< SystemSettings:
' 0:<               4=multiCoreCharacteristic
' 0:<            true=isProcessUserModeExceptionPolicyDisabledForCallbackFilter
' 0:< ::0:: Delta VM: Avail -78 -> 8388156 MB, Used +15 -> 60 MB, Peak +9 -> 60 MB; RAM: Avail -35 -> 6249 MB, Used +27 -> 108 MB, Peak +27 -> 108 MB
' 0:< GUI Resource Usage GDI: Avail 9988, Used 12, User: Used 10
' 0:< Autodesk Revit 2017
' 0:< 64-bit load point = C:\Program Files\Autodesk\Revit 2017
' 0:< this journal =
' 0:< API_SUCCESS { Registered an external service: Name(NavisWorks Draw Service); VendorId(ADSK); ServiceId(e454a471-b9f3-4cb7-96b1-bab4cf7742a6) }
' 0:< API_SUCCESS { Registered an external service: Name(External Resource Service); VendorId(ADSK); ServiceId(b3892e5f-9161-4bbc-958a-c8ef75e94e96) }
' 0:< API_SUCCESS { Registered an external service: Name(NavisworksExportService); VendorId(ADSK); ServiceId(a9bdf0fd-2632-429e-bc35-50ebc2b824d2) }
' 0:< API_SUCCESS { Registered an external service: Name(Code Checking Parameter Service); VendorId(ADSK); ServiceId(de6db8de-dea6-40bd-9503-4ffe62ff6143) }
' 0:< API_SUCCESS { Registered an external service: Name(FramingProfileService); VendorId(ADSK); ServiceId(b2f816c0-6493-4537-8067-78a4e67f559e) }
' 0:< API_SUCCESS { Registered an external service: Name(Modify Connection Parameters Service); VendorId(ADSK); ServiceId(e9c0f948-320e-4e7f-a573-10755555305d) }
' 0:< API_SUCCESS { Registered an external service: Name(Connection Type Changed Service); VendorId(ADSK); ServiceId(e31c3100-9cab-4303-b85b-4171703ce1c4) }
' 0:< API_SUCCESS { Registered an external service: Name(SteelConnectionsService); VendorId(ADSK); ServiceId(282385f9-9627-4057-8b74-826d019f103c) }
' 0:< API_SUCCESS { Registered an external service: Name(Section Type Parameter Service); VendorId(ADSK); ServiceId(c42c9b55-c491-4611-97e9-9e617958e13e) }
' 0:< API_SUCCESS { Registered an external service: Name(Internal Forces Service); VendorId(ADSK); ServiceId(a97444aa-af8d-4a1e-af1f-fa7b77b368ee) }
' 0:< API_SUCCESS { Registered an external service: Name(Duct Fitting/Accessory Pressure Drop Calculator); VendorId(ADSK); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external service: Name(Pipe Fitting/Accessory Pressure Drop Calculator); VendorId(ADSK); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external service: Name(Duct Pressure Drop Calculator); VendorId(ADSK); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external service: Name(Pipe Pressure Drop Calculator); VendorId(ADSK); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Registered an external service: Name(Plumbing Flow Calculator); VendorId(ADSK); ServiceId(bf0da776-5307-4747-8285-f358e92a90d0) }
' 0:< API_SUCCESS { Registered an external service: Name(IFC Export Service); VendorId(ADSK); ServiceId(d8b95737-f943-414c-9ad7-86785bf1acbc) }
' 0:< API_SUCCESS { Registered an external server: Name(Revit IFC Exporter); VendorId(ADSK); ServerId(ef8d0493-7f36-42b5-b9aa-8aaac716482b); ServiceId(d8b95737-f943-414c-9ad7-86785bf1acbc) }
' 0:< API_SUCCESS { Registered an external service: Name(IFC Import Service); VendorId(ADSK); ServiceId(98d317e2-e943-4cc0-a3da-2edf32a5d942) }
' 0:< API_SUCCESS { Registered an external server: Name(Revit IFC Importer); VendorId(ADSK); ServerId(660a7370-f6d6-43c8-8456-6b2eea785110); ServiceId(98d317e2-e943-4cc0-a3da-2edf32a5d942) }
'C 30-May-2017 11:18:55.489;   0:< manage debug modes
'C 30-May-2017 11:18:55.489;   0:< MFCApp::testGraphicsHardware
' 0:< Revit Graphics Information
' 0:< 	Current Mode : DirectX Hardware
' 0:< 	Use Hardware: ON
' 0:< 	Use Overlays : ON
' 0:< START CanUseHardware(forced)
' 1:<
'OGS Device Memory Size: 1152 MB
' 1:< ::0:: Delta VM: Avail -57 -> 8388099 MB, Used +42 -> 103 MB, Peak +44 -> 104 MB; RAM: Avail -7 -> 6242 MB, Used +14 -> 122 MB, Peak +15 -> 123 MB
' 1:< GUI Resource Usage GDI: Avail 9988, Used 12, User: Used 11
' 1:< DX Device: DirectX 11, Hardware
' 1:< DX Device: DirectX 11, WARP
'C 30-May-2017 11:18:55.657;   1:< START video card certification
' 1:< ::0:: Delta VM: Avail -21 -> 8388079 MB, Used +4 -> 108 MB, Peak +3 -> 108 MB; RAM: Avail -12 -> 6231 MB, Used +5 -> 128 MB, Peak +4 -> 128 MB
' 1:<
'Current driver version: 8.15.1.48
'Certified driver(s):
' 1:< VIDEO CARD ENVIRONMENT: CARD="VMware SVGA 3D" ManufacturerID="15AD" DeviceID="0405" osID="2000" DRIVER="8.15.1.48" DEVICE="DX11" FL_Caps="40" (Shader Model)
' 1:< Video card is blacklisted or feature level '40' is too low - cannot use hardware
' 1:< Software Mode Forced
'C 30-May-2017 11:18:55.740;   1:< FINISH video card certification
'  0.250589   1:<<<CanUseHardware(forced)
' 0:<
'Can use hardware=n
'Hardware support flags:
'FeatureLevelLow=n
'DrvOlderThanTested=n
'DrvNewerThanTested=n
'CardIsNotListed=n
'NotCertifiedEnv=n
'3GBSwitchIsOn=n
'SoftwareModeForced=y
' 0:< FINISH CanUseHardware(forced)
'C 30-May-2017 11:18:55.740;   0:< MFCApp::testMSAA
' 0:< 	Current Mode : DirectX Software
' 0:< DX Device: DirectX 11, WARP
'C 30-May-2017 11:18:55.753;   0:< <-UI-less InitNativeInstance
'C 30-May-2017 11:18:55.753;   0:< ->UI-less InitManagedInstance
' 0:< ::0:: Delta VM: Avail -448 -> 8387631 MB, Used +11 -> 119 MB, Peak +12 -> 120 MB; RAM: Avail -29 -> 6203 MB, Used +10 -> 138 MB, Peak +11 -> 139 MB
' 0:< GUI Resource Usage GDI: Avail 9988, Used 12, User: Used 12
' 0:< DBG_INFO: The addin file -AddPanel.addin- in current user folder is duplicated with the one in internal addin folder.: line 525 of AddIn\AddInManagerUtils.cpp.
' 0:< ::0:: Delta VM: Avail -4 -> 8387627 MB, Used 119 MB; RAM: Avail -17 -> 6186 MB, Used +1 -> 140 MB, Peak +2 -> 141 MB
' 0:< DBG_WARN: The assembly -AddPanel.addin- in internal addin C:\Program Files\Autodesk\Revit 2017\AddIns\AddPanel\AddPanel.dll is not signed as internal addin.: line 802 of AddIn\AddInManagerUtils.cpp.
' 0:< ::0:: Delta VM: Avail 8387627 MB, Used +0 -> 120 MB; RAM: Avail +25 -> 6212 MB, Used +7 -> 148 MB, Peak +6 -> 148 MB
'  0.236272   1:<<<DictionaryAnalysis::initialize
' 0:< ::0:: Delta VM: Avail -252 -> 8387376 MB, Used +70 -> 190 MB, Peak +69 -> 190 MB; RAM: Avail -130 -> 6082 MB, Used +96 -> 244 MB, Peak +96 -> 244 MB
' 0:< To make IFC server work.
' 0:< ExternalDBApplication KeynoteDBServer.ServerApp (C:\Program Files\Autodesk\Revit 2017\AddIns\Keynote\KeynoteDBServer.dll) was not loaded in RevitWorker
' 0:< API_SUCCESS { Registered an external server: Name(Prutok instalacních zarizovacích predmetu); VendorId(ADSK); ServerId(56121d7d-e1d7-42a3-bed8-f4d1d32058c8); ServiceId(bf0da776-5307-4747-8285-f358e92a90d0) }
' 0:< API_SUCCESS { Registered an external server: Name(Zjednodušená Colebrookova rovnice); VendorId(ADSK); ServerId(ea275fb1-5d7b-47d6-b828-bf856df9bfd5); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Registered an external server: Name(Altshulova-Tsalova rovnice); VendorId(ADSK); ServerId(042a10e0-8d24-46a4-9596-d192b3125d0c); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Haalandova rovnice); VendorId(USERADDIN); ServerId(2e9a77c0-62a0-4693-9442-33312be60ad7); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Haalandova rovnice); VendorId(USERADDIN); ServerId(58ea1b7c-2fca-453f-9ab9-7a3b9927ecc1); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Registered an external server: Name(Colebrookova rovnice); VendorId(USERADDIN); ServerId(e395a0ec-48a4-4255-b957-afbb3d73cb67); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Colebrookova rovnice); VendorId(USERADDIN); ServerId(0875f550-6141-4e34-a6b7-547cf9cfda01); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< ::0:: Delta VM: Avail -3 -> 8387373 MB, Used +0 -> 191 MB, Peak +2 -> 192 MB; RAM: Avail -13 -> 6069 MB, Used +2 -> 246 MB, Peak +2 -> 247 MB
' 0:< API_SUCCESS { Starting External DB Application: StraightSegmentCalculationServersApp, Class: StraightSegmentCalculationServers.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\StraightSegmentCalculationServers.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Není definováno); VendorId(ADSK); ServerId(76eff5da-2e71-45f7-b940-cc5716328ba0); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Koeficient z tabulky ASHRAE); VendorId(ADSK); ServerId(8baf7d75-8b9b-46d0-b8ce-3ad1c19e6b19); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Merný koeficient); VendorId(ADSK); ServerId(5a598293-1504-46cc-a9c0-de55c82848b9); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Merná ztráta); VendorId(ADSK); ServerId(46245996-eebb-4536-ac17-9c1cd917d8cf); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Není definováno); VendorId(ADSK); ServerId(61e7b8e1-16d1-4fe4-82f0-327af736323f); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(Koeficient K z tabulky); VendorId(ADSK); ServerId(51dd5e98-a9dd-464b-b286-4a37953610bf); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(Merný koeficient); VendorId(ADSK); ServerId(32d58662-b467-4f7b-b728-f6ad7b7ba5e3); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(Merná ztráta); VendorId(ADSK); ServerId(16f4f7be-0ac0-461d-a9a4-1d3511cd280e); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Starting External DB Application: FittingAndAccessoryCalculationServers, Class: FittingAndAccessoryCalculationServers.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\FittingAndAccessoryCalculationServers.dll }
' 0:< API_SUCCESS { Registered an external server: Name(SteelConnectionsServer); VendorId(ADSK); ServerId(9c209d4a-ec98-460f-bfde-38f17a3443b4); ServiceId(282385f9-9627-4057-8b74-826d019f103c) }
' 0:< ::0:: Delta VM: Avail -6 -> 8387367 MB, Used +2 -> 193 MB, Peak +6 -> 199 MB; RAM: Avail -12 -> 6057 MB, Used +8 -> 254 MB, Peak +9 -> 256 MB
' 0:< API_SUCCESS { Registered an external server: Name(FramingProfileServer); VendorId(ADSK); ServerId(54e490cd-8809-4dbb-84dd-dc0bc6cb1712); ServiceId(b2f816c0-6493-4537-8067-78a4e67f559e) }
' 0:< API_SUCCESS { Starting External DB Application: ExternalResourceDBServer, Class: RvtSteelConnectionsDB.SteelConnectionDBApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2017\AddIns\SteelConnections\RvtSteelConnectionsDB.dll }
' 0:< ExternalDBApplication Autodesk.Revit.UI.Collaborate.CollaborateDBApplication (C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\CollaborateDB.dll) was not loaded in RevitWorker
'C 30-May-2017 11:19:04.638;   0:< <-UI-less InitManagedInstance
'C 30-May-2017 11:19:04.640;   0:< Start RevitProcessMonitor
'C 30-May-2017 11:19:04.640;   0:< Log Summary
' 0:< .Count
' 0:< ...DBG_SOMETHING = 2
' 0:< ...DBG_WARNING = 1
' 0:< .Marshalling
' 0:< ...CompactCaching = 1 (Enabled)
' 0:< .ThreadPool
' 0:< ...ActivePoolSize = 26
' 0:< ...ConfiguredPoolSize = automatic
' 0:< ...ParallelCores = 4
' 0:< ...RequestedPoolSize = automatic
' 0:< .Tuning
' 0:< ...ElemTable = 1 (Serial except when multithreaded)
'C 30-May-2017 11:19:04.665;   0:< logging slave opened MasterQueue Session4700_P0MasterQueue
'C 30-May-2017 11:19:04.666;   0:< logging slave opened SlaveQueue Session4700_P1SlaveQueue
'C 30-May-2017 11:19:04.668;   0:< logging started queue minder
'C 30-May-2017 11:19:04.668;   0:< logging started worker services
'C 30-May-2017 11:19:04.668;   0:< ->Worker accepting requests
' 0:< ::0:: Delta VM: Avail -4 -> 8387364 MB, Used +0 -> 194 MB; RAM: Avail -239 -> 5819 MB, Used +1 -> 256 MB, Peak +1 -> 258 MB
' 0:< GUI Resource Usage GDI: Avail 9988, Used 12, User: Used 13
'C 30-May-2017 11:19:41.456;   0:< logging slave liberated
'C 30-May-2017 11:19:41.456;   0:< <-Worker accepting requests
' 0:< [00000aa0]QueueMinder stopped
'C 30-May-2017 11:19:41.457;   0:< logging finished virtualization services
'C 30-May-2017 11:19:41.457;   0:< logging finished worker services
'C 30-May-2017 11:19:41.459;   0:< logging erased queues
'C 30-May-2017 11:19:41.459;   0:< Log Summary
' 0:< .Count
' 0:< ...WorkerRequestHandledDeferredSecondary = 1
' 0:< ...WorkerRequestHandledImmediate = 1
'C 30-May-2017 11:19:41.460;   0:< ->UI-less ExitManagedInstance
' 0:< Forcibly removing all update triggers for all Updaters
' 0:< Unregistering all external services.
'C 30-May-2017 11:19:41.499;   0:< <-UI-less ExitManagedInstance
'C 30-May-2017 11:19:41.499;   0:< ->UI-less ExitNativeInstance
' 0:< ::0:: Delta VM: Avail +36 -> 8387400 MB, Used -30 -> 164 MB; RAM: Avail -6 -> 5814 MB, Used -4 -> 253 MB
' 0:< GUI Resource Usage GDI: Avail 9992, Used 8, User: Used 11
' 0:<                  FormOrAbandon exec=     1 (parallel=     0)   self=    0.000162 sec (avg=  0.000) rollup=   0.000162 (avg=  0.000)
' 0:<            InstrumentationTask exec=     1 (parallel=     1)
' 0:<                    QueueMinder exec=     1 (parallel=     1)
' 0:<                 TaskFileExists exec=   130 (parallel=   123)
' 0:< ::0:: Delta VM: Avail +45 -> 8387446 MB, Used -4 -> 161 MB; RAM: Avail +10 -> 5824 MB, Used -12 -> 241 MB
' 0:< GUI Resource Usage GDI: Avail 9992, Used 8, User: Used 9
'C 30-May-2017 11:19:42.053;   0:< <-UI-less ExitNativeInstance
'C 30-May-2017 11:19:42.054;   0:< End RevitProcessMonitor
and also journal.0001.txt file:
' 0:< Initial VM: Avail 8388348 MB, Used 14 MB, Peak 14; RAM: Avail 6606 MB, Used 48 MB, Peak 14
' 0:< GUI Resource Usage GDI: Avail 9995, Used 5, User: Used 3
'C 30-May-2017 11:18:36.590;   0:< started recording journal file
' Build: 20160225_1515(x64)
' Branch: RELEASE_2017_RTM
Dim Jrn
Set Jrn = CrsJournalScript
'C 30-May-2017 11:18:36.592;   0:< ->desktop InitApplication
'C 30-May-2017 11:18:36.620;   0:< <-desktop InitApplication
'C 30-May-2017 11:18:36.621;   0:< ->desktop InitNativeInstance
' 0:< ::0:: Delta VM: Avail -26 -> 8388322 MB, Used +4 -> 19 MB, Peak +4 -> 19 MB; RAM: Avail -25 -> 6581 MB, Used +11 -> 59 MB, Peak +11 -> 59 MB
' 0:< GUI Resource Usage GDI: Avail 9985, Used 15, User: Used 25
'C 30-May-2017 11:18:37.467;   0:< License initialization complete
' 0:< License version: 17.3.26.0
' 0:< ::0:: Delta VM: Avail -172 -> 8388151 MB, Used +31 -> 51 MB, Peak +34 -> 53 MB; RAM: Avail -73 -> 6509 MB, Used +49 -> 108 MB, Peak +49 -> 108 MB
' 0:< GUI Resource Usage GDI: Avail 9985, Used 15, User: Used 49
' 0:< ::0:: Delta VM: Avail -20 -> 8388131 MB, Used +8 -> 59 MB, Peak +5 -> 59 MB; RAM: Avail -26 -> 6483 MB, Used +15 -> 124 MB, Peak +15 -> 124 MB
' 0:< GUI Resource Usage GDI: Avail 9978, Used 22, User: Used 63
'C 30-May-2017 11:18:38.280;   0:< manage licensing
' 0:< ::0:: Delta VM: Avail -29 -> 8388102 MB, Used +4 -> 64 MB, Peak +4 -> 64 MB; RAM: Avail -50 -> 6433 MB, Used +12 -> 137 MB, Peak +12 -> 137 MB
' 0:< GUI Resource Usage GDI: Avail 9978, Used 22, User: Used 67
' 0:< License mode: Standalone
' 0:< Status: Your license is non-expiring.
' 0:< Type: Standalone - Locked
' 0:< Usage: Commercial
' 0:< Behavior: Permanent
' 0:< Expiration: None
' 0:< ::0:: Delta VM: Avail -667 -> 8387436 MB, Used +96 -> 160 MB, Peak +96 -> 160 MB; RAM: Avail -106 -> 6328 MB, Used +133 -> 270 MB, Peak +133 -> 270 MB
' 0:< GUI Resource Usage GDI: Avail 9824, Used 176, User: Used 166
' 0:< this journal = C:\Users\Jerry\AppData\Local\Autodesk\Revit\Autodesk Revit 2017\Journals\journal.0001.txt
' 0:< ::0:: Delta VM: Avail -9 -> 8387427 MB, Used +1 -> 161 MB, Peak +1 -> 161 MB; RAM: Avail -15 -> 6313 MB, Used +4 -> 275 MB, Peak +4 -> 275 MB
' 0:< Journal Init
'C 30-May-2017 11:18:54.534;   0:< Log Summary
' 0:< .Count
' 0:< ...PendingMessages = 10
' 0:< .Marshalling
' 0:< .ThreadPool
' 0:< .Tuning
'H 30-May-2017 11:18:54.535;   0:<
Jrn.Data "JournalDefaultTemplate"  _
        , "Construction Template=$AllUsersAppData\Templates\Generic\Default_M_ENU.rte, Architectural Template=$AllUsersAppData\Templates\Generic\Default_M_ENU.rte, Structural Template=$AllUsersAppData\Templates\Generic\Default_M_ENU.rte, Mechanical Template=$AllUsersAppData\Templates\Generic\Default_M_ENU.rte"
Jrn.Data "JournalDefaultViewDiscipline"  _
        , "Coordination"
Jrn.Directive "Version"  _
        , "2017.000", "2.153"
Jrn.Directive "Username"  _
        , "Jerry"
'H 30-May-2017 11:18:54.536;   0:<
Jrn.Directive "CategoryDisciplineFilter"  _
        , -1
Jrn.Directive "DisciplineOption"  _
        , 7677
Jrn.Directive "TabDisplayOptions"  _
        , "StayOnModifyInProject", 0
        , "StayOnModifyInFamily", 1
        , "ActiveCtOnSelection", 1
Jrn.Directive "AllowLinkSelection"  _
        , 1
Jrn.Directive "AllowFaceSelection"  _
        , 0
Jrn.Directive "AllowUnderlaySelection"  _
        , 0
'H 30-May-2017 11:18:54.537;   0:<
Jrn.Directive "AllowPinnedSelection"  _
        , 1
Jrn.Directive "ThinLinesEnabled"  _
        , 0
'C 30-May-2017 11:18:54.559;   1:< logging master created MasterQueue Session4700_P0MasterQueue
'C 30-May-2017 11:18:54.560;   1:< logging started queue minder
'C 30-May-2017 11:18:54.560;   1:< logging started worker services
' 0:< ::0:: Delta VM: Avail -10 -> 8387417 MB, Used +0 -> 162 MB, Peak +2 -> 163 MB; RAM: Avail -17 -> 6297 MB, Used +2 -> 277 MB, Peak +3 -> 278 MB
' 0:< GUI Resource Usage GDI: Avail 9821, Used 179, User: Used 166
' 0:< API_SUCCESS { Registered an external service: Name(External Resource UI Service); VendorId(ADSK); ServiceId(1fe75ba7-79d4-45f6-8e31-c1b83d4476a9) }
' 0:< API_SUCCESS { Registered an external service: Name(Point Cloud Snapping Service); VendorId(ADSK); ServiceId(aaa05780-790c-43dc-bc41-1c2150227f45) }
' 0:< API_SUCCESS { Registered an external service: Name(Duct fitting and accessory pressure drop UI service); VendorId(ADSK); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external service: Name(Pipe fitting and accessory pressure drop UI service); VendorId(ADSK); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< ::0:: Delta VM: Avail -33 -> 8387385 MB, Used +4 -> 166 MB, Peak +4 -> 168 MB; RAM: Avail -24 -> 6273 MB, Used +5 -> 282 MB, Peak +5 -> 283 MB
' 0:< GUI Resource Usage GDI: Avail 9821, Used 179, User: Used 168
' 0:< ::0:: Delta VM: Avail -12 -> 8387373 MB, Used +13 -> 179 MB, Peak +11 -> 179 MB; RAM: Avail -21 -> 6253 MB, Used +8 -> 290 MB, Peak +6 -> 290 MB
'  0.227718   1:<<<DictionaryAnalysis::initialize
' 0:< ::0:: Delta VM: Avail -221 -> 8387152 MB, Used +67 -> 247 MB, Peak +67 -> 247 MB; RAM: Avail -155 -> 6098 MB, Used +91 -> 381 MB, Peak +91 -> 381 MB
' 0:< ::0:: Delta VM: Avail -3 -> 8387150 MB, Used 247 MB, Peak +2 -> 249 MB; RAM: Avail -11 -> 6088 MB, Used +1 -> 382 MB, Peak +2 -> 383 MB
' 0:< API_SUCCESS { Registered an external server: Name(Revit Default DB Server); VendorId(ADSK); ServerId(bd4f0f53-394a-4468-b37e-1e7949013382); ServiceId(b3892e5f-9161-4bbc-958a-c8ef75e94e96) }
' 0:< API_SUCCESS { Starting External DB Application: KeynoteDBServer, Class: KeynoteDBServer.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2017\AddIns\Keynote\KeynoteDBServer.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Plumbing Fixture Flow); VendorId(ADSK); ServerId(56121d7d-e1d7-42a3-bed8-f4d1d32058c8); ServiceId(bf0da776-5307-4747-8285-f358e92a90d0) }
' 0:< API_SUCCESS { Registered an external server: Name(Simplified Colebrook Equation); VendorId(ADSK); ServerId(ea275fb1-5d7b-47d6-b828-bf856df9bfd5); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< ::0:: Delta VM: Avail -1 -> 8387149 MB, Used 247 MB; RAM: Avail -12 -> 6076 MB, Used +0 -> 383 MB
' 0:< API_SUCCESS { Registered an external server: Name(Altshul-Tsal Equation); VendorId(ADSK); ServerId(042a10e0-8d24-46a4-9596-d192b3125d0c); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Haaland Equation); VendorId(USERADDIN); ServerId(2e9a77c0-62a0-4693-9442-33312be60ad7); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Haaland Equation); VendorId(USERADDIN); ServerId(58ea1b7c-2fca-453f-9ab9-7a3b9927ecc1); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Registered an external server: Name(Colebrook Equation); VendorId(USERADDIN); ServerId(e395a0ec-48a4-4255-b957-afbb3d73cb67); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Colebrook Equation); VendorId(USERADDIN); ServerId(0875f550-6141-4e34-a6b7-547cf9cfda01); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Registered an external server: Name(Not Defined); VendorId(ADSK); ServerId(76eff5da-2e71-45f7-b940-cc5716328ba0); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Coefficient from ASHRAE Table); VendorId(ADSK); ServerId(8baf7d75-8b9b-46d0-b8ce-3ad1c19e6b19); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Coefficient); VendorId(ADSK); ServerId(5a598293-1504-46cc-a9c0-de55c82848b9); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Loss); VendorId(ADSK); ServerId(46245996-eebb-4536-ac17-9c1cd917d8cf); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< ::0:: Delta VM: Avail 8387149 MB, Used 247 MB; RAM: Avail +17 -> 6094 MB, Used 383 MB
' 0:< API_SUCCESS { Registered an external server: Name(Not Defined); VendorId(ADSK); ServerId(61e7b8e1-16d1-4fe4-82f0-327af736323f); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(K Coefficient from Table); VendorId(ADSK); ServerId(51dd5e98-a9dd-464b-b286-4a37953610bf); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Coefficient); VendorId(ADSK); ServerId(32d58662-b467-4f7b-b728-f6ad7b7ba5e3); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Loss); VendorId(ADSK); ServerId(16f4f7be-0ac0-461d-a9a4-1d3511cd280e); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< ::0:: Delta VM: Avail -2 -> 8387148 MB, Used +0 -> 248 MB, Peak +4 -> 254 MB; RAM: Avail -15 -> 6079 MB, Used +2 -> 385 MB, Peak +6 -> 389 MB
' 0:< ::0:: Delta VM: Avail -3 -> 8387146 MB, Used +1 -> 250 MB; RAM: Avail -31 -> 6049 MB, Used +4 -> 390 MB, Peak +0 -> 390 MB
' 0:< API_SUCCESS { Registering DocumentOpening event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Registering DocumentSavedAs event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< ::0:: Delta VM: Avail 8387146 MB, Used 250 MB; RAM: Avail +15 -> 6064 MB, Used 390 MB
' 0:< API_SUCCESS { Registering DocumentOpened event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Starting External DB Application: CollaborateDB, Class: Autodesk.Revit.UI.Collaborate.CollaborateDBApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\CollaborateDB.dll }
' 0:< ::0:: Delta VM: Avail -26 -> 8387120 MB, Used +8 -> 258 MB, Peak +4 -> 258 MB; RAM: Avail -14 -> 6051 MB, Used +12 -> 402 MB, Peak +12 -> 403 MB
' 0:< GUI Resource Usage GDI: Avail 9821, Used 179, User: Used 172
' 0:< API_SUCCESS { Registering ApplicationClosing event by application RaaS (d4f6554b-5d68-4a13-beec-4a0647c34408). }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_IN_CLOUD' Executed implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { API registering command  Executed event by application RaaS (d4f6554b-5d68-4a13-beec-4a0647c34408). }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_IN_CLOUD' CanExecute implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { API registering command  CanExecute event by application RaaS (d4f6554b-5d68-4a13-beec-4a0647c34408). }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_GALLERY' Executed implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_GALLERY' CanExecute implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { Starting External Application: RaaS, Class: Autodesk.RaaS.RevitAddin.EApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: RaaSApplication.dll }
'H 30-May-2017 11:19:04.879;   0:<
Jrn.Directive "IdleTimeTaskSymbol"  _
        , "0.ExternalEvent"
' 0:< API_SUCCESS { Starting External Application: AutoLoad, Class: AutoLoader.AutoLoader, Vendor : ADSK(), Assembly: AutoLoader.dll }
' 0:< ::0:: Delta VM: Avail -4 -> 8387117 MB, Used 258 MB, Peak +0 -> 259 MB; RAM: Avail -24 -> 6028 MB, Used +1 -> 404 MB, Peak +1 -> 404 MB
' 0:< GUI Resource Usage GDI: Avail 9817, Used 183, User: Used 174
' 0:< API_SUCCESS { Registering ViewActivated event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering DocumentClosed event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering DocumentChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering DockableFrameVisibilityChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< ::0:: Delta VM: Avail 8387117 MB, Used 258 MB; RAM: Avail +24 -> 6052 MB, Used 404 MB
'H 30-May-2017 11:19:05.184;   0:<
        , "1.OnIdleTask"
' 0:< API_SUCCESS { Registering Idling event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< ::0:: Delta VM: Avail 8387117 MB, Used 258 MB; RAM: Avail +13 -> 6065 MB, Used 404 MB, Peak +0 -> 405 MB
' 0:< API_SUCCESS { Registering FabricationPartBrowserChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_FABRICATION_SETTINGS' CanExecute implementation with implementation from application 'FabPartBrowserApplication' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\FabricationPartBrowser\FabricationPartBrowser.dll'. }
' 0:< API_SUCCESS { API registering command Fabrication Settings CanExecute event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_FABRICATION_SETTINGS' Executed implementation with implementation from application 'FabPartBrowserApplication' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\FabricationPartBrowser\FabricationPartBrowser.dll'. }
' 0:< API_SUCCESS { API registering command Fabrication Settings Executed event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Replacing command id 'ID_FABRICATION_PART_SHOW_SERVICE_IN_PART_BROWSER' CanExecute implementation with implementation from application 'FabPartBrowserApplication' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\FabricationPartBrowser\FabricationPartBrowser.dll'. }
' 0:< API_SUCCESS { API registering command Show Service in Part Browser
'Show Service in Part Browser
'Show Service in Part Browser CanExecute event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Starting External Application: FabPartBrowserApplication, Class: FabricationPartBrowser.FabPartBrowserApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: FabricationPartBrowser.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Duct not defined pressure drop UI server); VendorId(ADSK); ServerId(607992d7-359d-4593-b497-8aa238e2c564); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external server: Name(Duct specific coefficient pressure drop UI server); VendorId(ADSK); ServerId(9641a039-441e-42e2-93a6-c0e2177cc23c); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external server: Name(Duct specific loss pressure drop UI server); VendorId(ADSK); ServerId(d3b5e81d-9b8c-40da-8efb-99dd37fda611); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external server: Name(Duct coefficient from table pressure drop UI server); VendorId(ADSK); ServerId(25fa8de2-67c4-47d1-91f6-bd6f0803a5ed); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external server: Name(Pipe not defined pressure drop UI server); VendorId(ADSK); ServerId(62917391-e14d-4897-ad0c-05342d71e4f9); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< API_SUCCESS { Registered an external server: Name(Pipe specific coefficient pressure drop UI server); VendorId(ADSK); ServerId(247265b6-7b71-4147-97c6-cc52b39c12aa); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< API_SUCCESS { Registered an external server: Name(Pipe specific loss pressure drop UI server); VendorId(ADSK); ServerId(5978b92a-3f0b-4691-bbc8-caf2fae20a71); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< API_SUCCESS { Registered an external server: Name(Pipe K coefficient from table pressure drop UI server); VendorId(ADSK); ServerId(cda19b6f-fbd5-4725-a0ce-f159bf5d02fe); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< ::0:: Delta VM: Avail -1 -> 8387116 MB, Used +0 -> 259 MB; RAM: Avail -12 -> 6054 MB, Used 404 MB
' 0:< API_SUCCESS { Starting External Application: FittingAndAccessoryCalculationUIServers, Class: FittingAndAccessoryCalculationUIServers.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: FittingAndAccessoryCalculationUIServers.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_EXPORT_IFC' Executed implementation with implementation from application 'IFC override' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\IFCExporterUI\IFCExportUI.dll'. }
' 0:< API_SUCCESS { API registering command Export to IAI IFC (Industry Foundation Classes) file format Executed event by application IFC override (e78da2e3-7e89-464c-97cd-2212c8be3fa8). }
' 0:< API_SUCCESS { Starting External Application: IFC override, Class: BIM.IFC.Export.UI.IFCCommandOverrideApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: IFCExportUI.dll }
' 0:< ::0:: Delta VM: Avail 8387116 MB, Used 259 MB; RAM: Avail +11 -> 6065 MB, Used 404 MB
' 0:< API_SUCCESS { Starting External Application:  Import Shape, Class: ImportShape.ImportShape, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: ImportShape.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Revit Default UI Server.); VendorId(ADSK); ServerId(3ffc688a-bb2e-4145-90ab-9443da02aef6); ServiceId(1fe75ba7-79d4-45f6-8e31-c1b83d4476a9) }
' 0:< API_SUCCESS { Starting External Application: KeynoteUIServer, Class: KeynoteUIServer.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: KeynoteUIServer.dll }
' 0:< ::0:: Delta VM: Avail 8387116 MB, Used 259 MB; RAM: Avail -11 -> 6055 MB, Used +0 -> 405 MB
' 0:< API_SUCCESS { Registered an external server: Name(Internal Forces Server); VendorId(ADSK); ServerId(a97444aa-af8d-4a1e-af1f-fa7b77b368ee); ServiceId(a97444aa-af8d-4a1e-af1f-fa7b77b368ee) }
' 0:< API_SUCCESS { Starting External Application: Member Forces, Class: MemberForcesUI.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: MemberForces.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_NUMBERING_REINF_PARTITIONS' Executed implementation with implementation from application 'Object Numbering' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\ObjectNumbering\ObjectNumberingUI.dll'. }
' 0:< API_SUCCESS { API registering command  Executed event by application Object Numbering (32b5860a-aec9-4df7-96b0-07168b27446e). }
' 0:< API_SUCCESS { Replacing command id 'ID_NUMBERING_REINF_PARTITIONS' CanExecute implementation with implementation from application 'Object Numbering' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\ObjectNumbering\ObjectNumberingUI.dll'. }
' 0:< API_SUCCESS { API registering command  CanExecute event by application Object Numbering (32b5860a-aec9-4df7-96b0-07168b27446e). }
' 0:< API_SUCCESS { Starting External Application: Object Numbering, Class: BIM.Numbering.UI.NumberingUIApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: ObjectNumberingUI.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_DUCT_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Duct Pressure Loss Report CanExecute event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_DUCT_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Duct Pressure Loss Report Executed event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_PIPE_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Pipe Pressure Loss Report CanExecute event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_PIPE_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Pipe Pressure Loss Report Executed event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_DUCT_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_DUCT_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_PIPE_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_PIPE_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Starting External Application: PressureLossReport, Class: PressureLossReport.PressureLossReportApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: PressureLossReport.dll }
' 0:< API_SUCCESS { Registered an external server: Name(SectionTypeParameterServer); VendorId(ADSK); ServerId(1b91ce46-ddb4-44ec-a942-d45efadde353); ServiceId(c42c9b55-c491-4611-97e9-9e617958e13e) }
' 0:< API_SUCCESS { Starting External Application: Structural Section Properties, Class: SectionProperties.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: SectionProperties.dll }
' 0:< ::0:: Delta VM: Avail -2 -> 8387114 MB, Used 259 MB, Peak +0 -> 260 MB; RAM: Avail -13 -> 6043 MB, Used 405 MB, Peak +1 -> 406 MB
' 0:< API_SUCCESS { Registering ViewActivated event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE' Executed implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command Collaborate Executed event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE' CanExecute implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command Collaborate CanExecute event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_360' Executed implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command  Executed event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_360' CanExecute implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command  CanExecute event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Starting External Application: Collaborate, Class: Autodesk.Revit.UI.Collaborate.CollaborateApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\Collaborate.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_BROWSER' Executed implementation with implementation from application 'CollaborateBrowser' dll 'C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\CollaborateBrowser.dll'. }
' 0:< API_SUCCESS { API registering command A360 Projects Executed event by application CollaborateBrowser (901c7e33-857c-4c9c-846c-8f971c7cf72a). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_BROWSER' CanExecute implementation with implementation from application 'CollaborateBrowser' dll 'C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\CollaborateBrowser.dll'. }
' 0:< API_SUCCESS { API registering command A360 Projects CanExecute event by application CollaborateBrowser (901c7e33-857c-4c9c-846c-8f971c7cf72a). }
' 0:< API_SUCCESS { Starting External Application: CollaborateBrowser, Class: Autodesk.Revit.UI.CollaborateBrowser.CollaborateBrowserApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\CollaborateBrowser.dll }
'C 30-May-2017 11:19:06.353;   0:< Loading bcg.dll: Autodesk.Bcg, Version=1.7.3.0, Culture=neutral, PublicKeyToken=d672471c03b2c408
' 0:< ::0:: Delta VM: Avail -3 -> 8387111 MB, Used +3 -> 262 MB, Peak +2 -> 263 MB; RAM: Avail +13 -> 6056 MB, Used +3 -> 409 MB, Peak +2 -> 409 MB
'C 30-May-2017 11:19:06.664;   0:< SkyscraperClientHost: Initialize Success: True
' 0:< API_SUCCESS { Starting External Application: SkyscraperClientHostApplication, Class: SkyscraperClientHost.SkyscraperClientHostApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\SkyscraperClientHost.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6400, name: , text: Glue, class: BIM360RevitAddin.GlueItCommand, assembly: C:\ProgramData\Autodesk\Revit\Addins\2017\BIM360Glue\BIM360GlueRevit2017Addin.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6401, name: , text: Clash
'Pinpoint, class: BIM360RevitAddin.GluePinPointCommand, assembly: C:\ProgramData\Autodesk\Revit\Addins\2017\BIM360Glue\BIM360GlueRevit2017Addin.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6402, name: , text: Equipment
'Properties, class: BIM360RevitAddin.EquipmentCommand, assembly: C:\ProgramData\Autodesk\Revit\Addins\2017\BIM360Glue\BIM360GlueRevit2017Addin.dll }
' 0:< ::0:: Delta VM: Avail -14 -> 8387098 MB, Used +10 -> 273 MB, Peak +20 -> 284 MB; RAM: Avail -10 -> 6047 MB, Used +13 -> 422 MB, Peak +22 -> 431 MB
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application Ribbon (c82755fa-ff61-5113-9a07-27b2127a13e5). }
' 0:< API_SUCCESS { Registering ApplicationClosing event by application Ribbon (c82755fa-ff61-5113-9a07-27b2127a13e5). }
' 0:< API_SUCCESS { Starting External Application: Ribbon, Class: BIM360RevitAddin.HorizontalRibbon, Vendor : BIM360(Autodesk, Inc, www.autodesk.com), Assembly: BIM360Glue/BIM360GlueRevit2017Addin.dll }
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentCreated event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentSavedAs event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentSaved event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentClosed event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering ApplicationClosing event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< ::0:: Delta VM: Avail 8387098 MB, Used 273 MB; RAM: Avail -14 -> 6033 MB, Used +0 -> 423 MB
' 0:< API_SUCCESS { Replacing command id 'ID_TEAM' Executed implementation with implementation from application 'Communicator for Autodesk Revit' dll 'C:\ProgramData\Autodesk\Revit\Addins\2017\Communicator\SmartMonkey.dll'. }
' 0:< API_SUCCESS { API registering command Communicator Executed event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Replacing command id 'ID_TEAM' CanExecute implementation with implementation from application 'Communicator for Autodesk Revit' dll 'C:\ProgramData\Autodesk\Revit\Addins\2017\Communicator\SmartMonkey.dll'. }
' 0:< API_SUCCESS { API registering command Communicator CanExecute event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Starting External Application: Communicator for Autodesk Revit, Class: Autodesk.Revit.SmartMonkeyPlugin.SmartMonkeyApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: Communicator\SmartMonkey.dll }
' 0:< API_SUCCESS { Registering Idling event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering ViewActivated event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering ViewActivating event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering DocumentClosed event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Replacing command id 'ID_VISUAL_PROGRAMMING_DYNAMO' CanExecute implementation with implementation from application 'Dynamo For Revit' dll 'C:\Program Files\Dynamo 0.9\Revit_2017\DynamoRevitVersionSelector.dll'. }
' 0:< API_SUCCESS { API registering command Launch Dynamo
'Dynamo CanExecute event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
'Dynamo BeforeExecuted event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Replacing command id 'ID_VISUAL_PROGRAMMING_DYNAMO' Executed implementation with implementation from application 'Dynamo For Revit' dll 'C:\Program Files\Dynamo 0.9\Revit_2017\DynamoRevitVersionSelector.dll'. }
'Dynamo Executed event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< Third Party Updater 'Dynamo For Revit: Sun and Shadow Settings Updater' registered for all documents.
' 0:< API_SUCCESS { Registering DocumentChanged event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Starting External Application: Dynamo For Revit, Class: Dynamo.Applications.VersionLoader, Vendor : ADSK(Dynamo), Assembly: C:\Program Files\Dynamo 0.9\Revit_2017\DynamoRevitVersionSelector.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_VIEWS_FOR_A360' Executed implementation with implementation from application 'Views For A360' dll 'C:\ProgramData\Autodesk\Revit\Addins\2017\.\ExportViewSelectorAddin\ExportViewSelectorAddin.dll'. }
' 0:< API_SUCCESS { API registering command Views For A360 Executed event by application Views For A360 (78bd1446-1817-4842-8075-591b0424acaa). }
' 0:< API_SUCCESS { Replacing command id 'ID_VIEWS_FOR_A360' CanExecute implementation with implementation from application 'Views For A360' dll 'C:\ProgramData\Autodesk\Revit\Addins\2017\.\ExportViewSelectorAddin\ExportViewSelectorAddin.dll'. }
' 0:< API_SUCCESS { API registering command Views For A360 CanExecute event by application Views For A360 (78bd1446-1817-4842-8075-591b0424acaa). }
' 0:< API_SUCCESS { Starting External Application: Views For A360, Class: Autodesk.Revit.Addin.ExportViewSelector.ExportViewSelectorApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: .\ExportViewSelectorAddin\ExportViewSelectorAddin.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6403, name: , text: Convert RFA
'to FormIt 360, class: RFAToAXMAddon.RFAToAXMCommand, assembly: C:\Program Files\Autodesk\FormIt 360 Converter For Revit 2017\FormIt360ConversionAddon\RFAToAXMAddon.dll }
' 0:< ::0:: Delta VM: Avail -1 -> 8387097 MB, Used 273 MB; RAM: Avail +11 -> 6045 MB, Used -1 -> 422 MB
' 0:< GUI Resource Usage GDI: Avail 9808, Used 192, User: Used 177
' 0:< API_SUCCESS { Added pushbutton Id: 6404, name: , text: Convert SKP
'to FormIt 360, class: RFAToAXMAddon.SketchUpToAXMCommand, assembly: C:\Program Files\Autodesk\FormIt 360 Converter For Revit 2017\FormIt360ConversionAddon\RFAToAXMAddon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6405, name: , text: Import FormIt 360
'to RVT, class: AXMImportorAddon.AXMImportorCommand, assembly: C:\Program Files\Autodesk\FormIt 360 Converter For Revit 2017\FormIt360ConversionAddon\AXMImportorAddon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6406, name: , text: Reload Families, class: AXMImportorAddon.ReloadFamiliesCommand, assembly: C:\Program Files\Autodesk\FormIt 360 Converter For Revit 2017\FormIt360ConversionAddon\AXMImportorAddon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6407, name: , text: About FormIt 360, class: FormItConverter.FormIt360Link, assembly: C:\Program Files\Autodesk\FormIt 360 Converter For Revit 2017\FormIt360ConversionAddon\FormItConverterRibbon.dll }
' 0:< API_SUCCESS { Starting External Application: FormIt Conversion, Class: FormItConverter.Ribbon, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\FormIt 360 Converter For Revit 2017\FormIt360ConversionAddon\FormItConverterRibbon.dll }
'C 30-May-2017 11:19:10.572;   0:< ->processShellCommand
 'E 30-May-2017 11:19:10.573;   0:<
 Jrn.Command "Internal" , "Show or hide recent files , ID_STARTUP_PAGE"
' 0:< ::1:: Delta VM: Avail -28 -> 8387069 MB, Used +13 -> 287 MB, Peak +3 -> 287 MB; RAM: Avail -12 -> 6033 MB, Used +10 -> 433 MB, Peak +1 -> 433 MB
' 0:< GUI Resource Usage GDI: Avail 9811, Used 189, User: Used 186
'C 30-May-2017 11:19:10.834;   0:< <-processShellCommand
'C 30-May-2017 11:19:10.835;   0:< ->DesktopMFCApp::doStartupWarnings
'C 30-May-2017 11:19:10.835;   0:< License readyForUI
'C 30-May-2017 11:19:10.983;   0:< manage involvement
' 0:< ::1:: Delta VM: Avail -12 -> 8387058 MB, Used 287 MB; RAM: Avail -10 -> 6023 MB, Used +1 -> 434 MB, Peak +1 -> 435 MB
' 0:< GUI Resource Usage GDI: Avail 9811, Used 189, User: Used 185
'C 30-May-2017 11:19:11.034;   0:< manage debug modes
'C 30-May-2017 11:19:11.034;   0:< MFCApp::testGraphicsHardware
' 1:<
' 1:< ::1:: Delta VM: Avail -103 -> 8386955 MB, Used +32 -> 319 MB, Peak +33 -> 321 MB; RAM: Avail -17 -> 6006 MB, Used +17 -> 452 MB, Peak +18 -> 454 MB
' 1:< GUI Resource Usage GDI: Avail 9810, Used 190, User: Used 199
'C 30-May-2017 11:19:11.517;   1:< START video card certification
' 1:<
'C 30-May-2017 11:19:11.585;   1:< FINISH video card certification
'  0.550037   1:<<<CanUseHardware(forced)
' 0:<
'Can use hardware=n
'FeatureLevelLow=n
'CardIsNotListed=n
'NotCertifiedEnv=n
'3GBSwitchIsOn=n
'C 30-May-2017 11:19:11.585;   0:< MFCApp::testMSAA
'C 30-May-2017 11:19:11.599;   0:< postConditionalWarnings
'C 30-May-2017 11:19:11.599;   0:< giveAtomRegistrationWarnings
'C 30-May-2017 11:19:11.599;   0:< warnings->consumeAll
' 0:< TaskDialog "Hardware Acceleration disabled. Software emulation mode is in use."
'Id : TaskDialog_Graphics_Options_Cannot_Use_Hardware_Acceleration
'CommonButtons : Close
'DefaultButton : Close
' 0:< ::1:: Delta VM: Avail -39 -> 8386917 MB, Used +18 -> 337 MB, Peak +17 -> 338 MB; RAM: Avail -18 -> 5989 MB, Used +28 -> 481 MB, Peak +27 -> 482 MB
' 0:< GUI Resource Usage GDI: Avail 9780, Used 220, User: Used 200
'C 30-May-2017 11:19:14.818;   0:< Process result of DebugModes-Changed Task Dialog
'C 30-May-2017 11:19:14.818;   0:< isMaterialLibraryAvailable
'C 30-May-2017 11:19:14.819;   0:< start up warnings for AddIns
'C 30-May-2017 11:19:14.820;   0:< <-DesktopMFCApp::doStartupWarnings
'C 30-May-2017 11:19:14.820;   0:< <-desktop InitNativeInstance
'C 30-May-2017 11:19:14.820;   0:< ->desktop InitManagedInstance
' 1:< API_SUCCESS { Registering ViewActivated event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 1:< API_SUCCESS { Registering DocumentSynchronizingWithCentral event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 1:< API_SUCCESS { Registering DocumentSynchronizedWithCentral event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
'C 30-May-2017 11:19:15.046;   0:< <-desktop InitManagedInstance
'C 30-May-2017 11:19:15.054;   0:< appPriv idle
' 0:< OPERATING SYSTEM INFORMATION:
' 0:<    BuildNumber : 7601
' 0:<    BuildType : Multiprocessor Free
' 0:<    Caption : Microsoft Windows 7 Ultimate
' 0:<    CodeSet : 1252
' 0:<    CountryCode : 1
' 0:<    CSDVersion : Service Pack 1
' 0:<    FreePhysicalMemory : 6132988
' 0:<    FreeSpaceInPagingFiles : 8388088
' 0:<    FreeVirtualMemory : 14571656
' 0:<    MaxProcessMemorySize : 8589934464
' 0:<    OSLanguage : 1033
' 0:<    OSType : 18
' 0:<    ServicePackMajorVersion : 1
' 0:<    ServicePackMinorVersion : 0
' 0:<    TotalVirtualMemorySize : 16774316
' 0:<    TotalVisibleMemorySize : 8388088
' 0:<    Version : 6.1.7601
' 0:<    Process affinity mask : F
' 0:<    System affinity mask : F
 'E 30-May-2017 11:19:15.949;   0:<
 Jrn.Command "StartupPage" , "Open this project , ID_FILE_MRU_FIRST"
 'H 30-May-2017 11:19:15.950;   0:<
 Jrn.Data "MRUFileName"  _
         , "..\..\..\..\..\..\..\..\29\hotel R2017.rvt"
 ' 1:<   System (MB) [Available /  Total ]  [Revit Memory Usage (MB)   ]
 ' 1:< RAM Statistics:     5986 /     8191       484=InUse      485=Peak
 ' 1:< VM  Statistics:  8386915 /  8388607       339=InUse      340=Peak
 ' 2:< ::2:: Delta VM: Avail -3 -> 8386915 MB, Used +1 -> 339 MB, Peak +1 -> 340 MB; RAM: Avail -12 -> 5977 MB, Used +4 -> 485 MB, Peak +4 -> 486 MB
 ' 2:< GUI Resource Usage GDI: Avail 9779, Used 221, User: Used 207
 ' 2:< API_SUCCESS { Registered an external server: Name(A360); VendorId(ADSK); ServerId(d2c3617d-7a16-45bc-b395-44897852f485); ServiceId(b3892e5f-9161-4bbc-958a-c8ef75e94e96) }
 ' 2:< File: Open
 ' 3:< DataStorage 000000000D957170 is created
 ' 3:< Connecting session [$c5265ff0] to Worksharing Log [C:\Users\Jerry\AppData\Local\Autodesk\Revit\Autodesk Revit 2017\Journals\journal.0001.txt]
 ' 3:< Additional IP address/name found for host WIN-A249JB4L2UH: fe80::343f:c4e:3d1b:7f13%13
 ' 3:< Additional IP address/name found for host WIN-A249JB4L2UH: 10.0.0.3
 ' 4:< DataStorage 000000000D956C70 is created
  'E 30-May-2017 11:19:16.126;   6:<
  ' [Jrn.BasicFileInfo] Rvt.Attr.Worksharing: Not enabled Rvt.Attr.UserName:  Rvt.Attr.CentralModelPath:  Rvt.Attr.RevitBuildVersion: Autodesk Revit 2017 (Build: 20160225_1515(x64)) Rvt.Attr.LastSavePath: C:\29\hotel R2017.rvt Rvt.Attr.ProjectSpark: notProjectSpark Rvt.Attr.LocaleWhenSaved: CSY
  ' 7:< [ISL] On open, Adler Checksum: 0xb208efe2 [C:\29\hotel R2017.rvt]
  ' 6:< [ISL] Read last modification time: 29-May-2017 18:08:23 (UTC: 29-May-2017 16:08:23)
  ' 6:< ::3:: Delta VM: Avail -8 -> 8386907 MB, Used 339 MB; RAM: Avail -10 -> 5968 MB, Used +10 -> 495 MB, Peak +9 -> 495 MB
  ' 6:< GUI Resource Usage GDI: Avail 9777, Used 223, User: Used 207
  ' 6:< File was saved in Autodesk Revit 2017 (Build: 20160225_1515(x64))
  ' 8:< ::3:: Delta VM: Avail -44 -> 8386864 MB, Used +15 -> 354 MB, Peak +14 -> 354 MB; RAM: Avail -33 -> 5935 MB, Used +19 -> 515 MB, Peak +19 -> 515 MB
  ' 8:< GUI Resource Usage GDI: Avail 9777, Used 223, User: Used 207
  ' 8:< Loaded elemStream#32: uncompSize=17023286, compSize=3090576, count=25001
  '  0.406129          8:<<<loadLatestVersion
  ' 7:< ::3:: Delta VM: Avail -12 -> 8386852 MB, Used +12 -> 366 MB, Peak +12 -> 366 MB; RAM: Avail +3 -> 5938 MB, Used +5 -> 521 MB, Peak +5 -> 521 MB
  ' 7:< GUI Resource Usage GDI: Avail 9777, Used 223, User: Used 207
  '  0.269989          8:<<<commitSwapouts
  '  0.676736         7:<<loadSelectedEpochs
  '  0.721984        6:<<TrustedUtility::readStreams/ALL_GAPS   0.045248/Threshold_GAPs 91%
  ' 7:< ::3:: Delta VM: Avail +1 -> 8386853 MB, Used +1 -> 368 MB, Peak +1 -> 368 MB; RAM: Avail -17 -> 5922 MB, Used +2 -> 523 MB, Peak +2 -> 523 MB
  ' 7:< GUI Resource Usage GDI: Avail 9777, Used 223, User: Used 215
  '  0.108176          8:<<<updating dependencies in delayed deletion
  '  0.120273         7:<<overall delayed deletion from upgrade/ALL_GAPS   0.012097/Threshold_GAPs 86%
  '  0.207350        6:<<ADocumentUpgrade::docUpgrade [C:\29\hotel R2017.rvt]/ALL_GAPS   0.087076/Threshold_GAPs 2%
  '  1.092635      4:<<loadSerialize/ALL_GAPS   0.163301/TurnOff_GAPs 100%
  '  1.092975     3:<<LoadFromStorage
  ' 2:< No key-based tree File: RevitKeynotes_Imperial_2004.txt - in this Library Location: C:\ProgramData\Autodesk\RVT 2017\Libraries\Generic\ - file does not exist: C:\ProgramData\Autodesk\RVT 2017\Libraries\Generic\RevitKeynotes_Imperial_2004.txt
  ' 2:< No key-based tree File: UniformatClassifications.txt - in this Library Location: C:\ProgramData\Autodesk\RVT 2017\Libraries\Generic\ - file does not exist: C:\ProgramData\Autodesk\RVT 2017\Libraries\Generic\UniformatClassifications.txt
  ' 4:< Unnecessary nesting;Document\PostLoadDocument.cpp;184;String_Revit_DelayedPropagatoinRegen ;N++E(N);
  ' 5:<   System (MB) [Available /  Total ]  [Revit Memory Usage (MB)   ]
  ' 5:< RAM Statistics:     5922 /     8191       525=InUse      525=Peak
  ' 5:< VM  Statistics:  8386853 /  8388607       368=InUse      368=Peak
  ' 5:< Element Expansion Statistics:
  ' 5:<  0% Opening Plans                    (0)
  ' 5:<  0% Opening RC Plans                 (0)
  ' 5:<  0% Opening 3d Views                 (0)
  ' 5:<  0% Opening Elevations and Sections  (0)
  ' 5:<  0% In Regnerate                     (0)
  ' 5:<  0% In Autojoin                      (0)
  ' 5:<  0% In Overlap Checking              (0)
  ' 5:<  0% Reviewing PostedWarnings         (0)
  ' 5:<  100% Other                            (1431585)
  ' 5:< total bytes expanded: 1431585
  ' 5:< ;EES;0;0;0;0;0;0;0;0;100;
  ' 6:< Connecting session [$6ff90067] to Worksharing Log [C:\Users\Jerry\AppData\Local\Autodesk\Revit\Autodesk Revit 2017\Journals\journal.0001.txt]
  ' 6:< Additional IP address/name found for host WIN-A249JB4L2UH: fe80::343f:c4e:3d1b:7f13%13
  ' 6:< Additional IP address/name found for host WIN-A249JB4L2UH: 10.0.0.3
  ' 3:< ::3:: Delta VM: Avail 8386853 MB, Used 368 MB; RAM: Avail +12 -> 5935 MB, Used +3 -> 527 MB, Peak +3 -> 527 MB
  ' 3:< GUI Resource Usage GDI: Avail 9777, Used 223, User: Used 215
  ' 3:< Unnecessary nesting;Document\PostLoadDocument.cpp;440;ID_SETTINGS_SNAPPING ;N++E(N);
  'C 30-May-2017 11:19:17.186;   4:< The current load request is an automated one.
  'C 30-May-2017 11:19:17.232;   4:< The current load request is an automated one.
  ' 3:< Document save history --> :
  ' 3:<   Revit LT 2016 2016 (2016.000) : 20150220_1215
  ' 3:<   Revit 2017 2017 (2017.000) : 20160225_1515(x64)
  ' 3:< Document save history <--
  '  0.130078     3:<<[Cloud]postLoadDocument
  ' 1:< ::3:: Delta VM: Avail -7 -> 8386847 MB, Used +6 -> 374 MB, Peak +6 -> 374 MB; RAM: Avail -24 -> 5911 MB, Used +15 -> 542 MB, Peak +15 -> 542 MB
  ' 1:< GUI Resource Usage GDI: Avail 9779, Used 221, User: Used 215
  '  1.333745    2:<<FormOrAbandon::openFromModelPath [C:\29\hotel R2017.rvt]/ALL_GAPS   0.110692/Threshold_GAPs 4%
  'H 30-May-2017 11:19:17.364;   1:<
  Jrn.Directive "DocSymbol"  _
          , "[hotel R2017.rvt]"
  'C 30-May-2017 11:19:17.434;   2:< Protein : initialize RPC plug-ins
  ' 2:< ::3:: Delta VM: Avail -22 -> 8386826 MB, Used +7 -> 382 MB, Peak +7 -> 382 MB; RAM: Avail -18 -> 5894 MB, Used +9 -> 552 MB, Peak +9 -> 552 MB
  ' 2:< GUI Resource Usage GDI: Avail 9757, Used 243, User: Used 246
  'C 30-May-2017 11:19:17.451;   2:< Protein : Register Preview Factories
  'C 30-May-2017 11:19:17.451;   2:< Protein : Initialize Renderer Module
  'C 30-May-2017 11:19:17.451;   2:< Protein : Open Protein content Libraries
  ' 2:< ::3:: Delta VM: Avail -5 -> 8386821 MB, Used +7 -> 389 MB, Peak +8 -> 391 MB; RAM: Avail +11 -> 5905 MB, Used +6 -> 558 MB, Peak +7 -> 559 MB
  'C 30-May-2017 11:19:17.587;   2:< Protein : Load Library:
  ' 2:< C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\2017\assetlibrary_base.adsklib
  'C 30-May-2017 11:19:17.587;   2:< Protein : Texture Path:
  ' 2:< C:/Program Files (x86)/Common Files/Autodesk Shared/Materials/Textures/
  ' 2:< ::3:: Delta VM: Avail 8386821 MB, Used 389 MB; RAM: Avail -40 -> 5866 MB, Used +1 -> 559 MB
  'C 30-May-2017 11:19:19.149;   2:< Protein : Notify Plugins to load the content on the asset library
  'C 30-May-2017 11:19:19.150;   2:< Protein : Register the Protein RenderingAsset Manager
  'H 30-May-2017 11:19:19.180;   2:<
  Jrn.Directive "GlobalToProj"  _
          , "[hotel R2017.rvt]", "Floor Plan: Level 1" _
          , 0.01041666666667 _
          , 1.00000000000000, 0.00000000000000, 0.00000000000000 _
          , 0.00000000000000, 1.00000000000000, 0.00000000000000 _
          , 0.00000000000000, 0.00000000000000, 1.00000000000000 _
          , 0.00000000000000, 0.00000000000000, 0.00000000000000
  'H 30-May-2017 11:19:19.181;   2:<
  Jrn.Directive "ProjToPage"  _
  'H 30-May-2017 11:19:19.182;   2:<
  Jrn.Directive "WindowSize"  _
          , 1352, 607
  ' 2:< Before : Create Display Manager
  ' 2:<   System (MB) [Available /  Total ]  [Revit Memory Usage (MB)   ]
  ' 2:< RAM Statistics:     5859 /     8191       559=InUse      559=Peak
  ' 2:< VM  Statistics:  8386821 /  8388607       390=InUse      391=Peak
  ' 2:< Revit Graphics Information
  ' 2:< 	Current Mode : DirectX Software
  ' 2:< 	Use Hardware: ON
  ' 2:< 	Use Overlays : ON
  ' 2:< After : Create Display Manager
  ' 2:< RAM Statistics:     5862 /     8191       559=InUse      559=Peak
  ' 2:< ::3:: Delta VM: Avail -9 -> 8386813 MB, Used +3 -> 393 MB, Peak +1 -> 393 MB; RAM: Avail -15 -> 5851 MB, Used +4 -> 564 MB, Peak +4 -> 564 MB
  ' 2:< GUI Resource Usage GDI: Avail 9402, Used 598, User: Used 324
  'H 30-May-2017 11:19:19.277;   2:<
  Jrn.Directive "ScreenResolution"  _
          , 370, 1050
   ' 2:< ::3:: Delta VM: Avail 8386813 MB, Used 393 MB; RAM: Avail +15 -> 5867 MB, Used 564 MB
   ' 2:< GUI Resource Usage GDI: Avail 9402, Used 598, User: Used 317
   ' 2:< Activate "[hotel R2017.rvt]" , Floor Plan: Level 1
   ' 2:< View Open: Element expansion used 0.000000 seconds averaging 0.000000 seconds/hit for 0 hits.
' 2:< ::3:: Delta VM: Avail -2 -> 8386811 MB, Used +12 -> 405 MB, Peak +13 -> 406 MB; RAM: Avail +14 -> 5881 MB, Used +17 -> 581 MB, Peak +17 -> 582 MB
' 2:< GUI Resource Usage GDI: Avail 9364, Used 636, User: Used 324
' 2:< PROCESSOR INFORMATION:
' 2:<    AddressWidth : 64
' 2:<    Architecture : 9
' 2:<    Availability : 3
' 2:<    Caption : AMD64 Family 21 Model 1 Stepping 2
' 2:<    CurrentClockSpeed : 3616
' 2:<    DataWidth : 64
' 2:<    Description : AMD64 Family 21 Model 1 Stepping 2
' 2:<    Family : 2
' 2:<    L2CacheSize : 2048
' 2:<    Level : 21
' 2:<    Manufacturer : AuthenticAMD
' 2:<    MaxClockSpeed : 3616
' 2:<    Name : AMD FX(tm)-4100 Quad-Core Processor
' 2:<    ProcessorType : 3
' 2:<    Revision : 258
' 2:<    Role : CPU
' 2:<    SocketDesignation : CPU #000
' 2:<    StatusInfo : 3
' 2:<    Stepping : 2
' 2:<    Version : Model 1, Stepping 2
 'H 30-May-2017 11:19:20.886;   2:<
         , 1652, 926
' 2:< View Open: Element expansion used 0.000067 seconds averaging 0.000067 seconds/hit for 1 hits.
 ' 2:< ::3:: Delta VM: Avail 8386811 MB, Used +1 -> 406 MB, Peak +1 -> 408 MB; RAM: Avail -15 -> 5867 MB, Used +2 -> 583 MB, Peak +2 -> 584 MB
 ' 2:< GUI Resource Usage GDI: Avail 9355, Used 645, User: Used 343
 'H 30-May-2017 11:19:21.155;   2:<
         , 1448, 824
 'H 30-May-2017 11:19:21.158;   2:<
         , 1428, 804
' 5:< ::3:: Delta VM: Avail +3 -> 8386814 MB, Used +0 -> 407 MB; RAM: Avail +12 -> 5880 MB, Used -1 -> 582 MB
' 5:< GUI Resource Usage GDI: Avail 9225, Used 775, User: Used 390
'  3.882693!!!! 3:!!!BIG_GAP [Cloud]openOntoDesktop
' 2:< FileCheckTrigger dependencies update
' 2:< DBG_INFO: Detected unfrozen change of selection.: line 616 of d:\ship\2017_px64\source\revit\revitui\modscope\ModScope.cpp.
' 6:< ::3:: Delta VM: Avail -8 -> 8386806 MB, Used +12 -> 419 MB, Peak +10 -> 419 MB; RAM: Avail -11 -> 5870 MB, Used +1 -> 584 MB
' 6:< GUI Resource Usage GDI: Avail 9225, Used 775, User: Used 390
' 6:< DBG_INFO: If bHandleEdgeInCutPlane is true, bUseVertexTol should also be true.: line 2268 of GeomXSec.cpp.
' 2:< <<Begin build CT>>
'Edit mode: IDR_COMMON
'Command:
'Category: 0
'Bar list:
'Presenter list:
'Product: Unknown
'Edit mode context, but no edit mode set.
'<<End build CT>>
 ' 2:< ::3:: Delta VM: Avail +0 -> 8386807 MB, Used 419 MB, Peak +1 -> 420 MB; RAM: Avail -13 -> 5857 MB, Used +3 -> 587 MB, Peak +3 -> 588 MB
 ' 2:< GUI Resource Usage GDI: Avail 9217, Used 783, User: Used 405
 'H 30-May-2017 11:19:21.987;   2:<
         , 1448, 824
  'H 30-May-2017 11:19:21.991;   2:<
          , 1428, 804
  'H 30-May-2017 11:19:22.000;   2:<
          , 1442.76298000202223 _
          , 1442.76298000202223, 0.00000000000000, 0.00000000000000 _
          , 0.00000000000000, 1442.76298000202223, 0.00000000000000 _
          , 0.00000000000000, 0.00000000000000, 1442.76298000202223 _
  'H 30-May-2017 11:19:22.001;   2:<
          , 804.58914093739622, -397.28603206124973, 0.00000000000000
  '  4.655857    2:<<[Cloud]openOntoDesktop
  ' 1:< Third Party Updater 'Revit: ObjectNumberingUpdater' registered for document 'hotel R2017'.
  ' 1:< ::3:: Delta VM: Avail 8386807 MB, Used 419 MB, Peak +0 -> 421 MB; RAM: Avail +18 -> 5875 MB, Used 587 MB
  ' 1:< GUI Resource Usage GDI: Avail 9215, Used 785, User: Used 406
  ' 1:< RAM Statistics:     5875 /     8191       587=InUse      588=Peak
  ' 1:< VM  Statistics:  8386807 /  8388607       419=InUse      421=Peak
  ' 1:< Element Expansion Statistics:
  ' 1:<  49% Opening Plans                    (1575374)
  ' 1:<  0% Opening RC Plans                 (0)
  ' 1:<  0% Opening 3d Views                 (0)
  ' 1:<  0% Opening Elevations and Sections  (0)
  ' 1:<  0% In Regnerate                     (0)
  ' 1:<  0% In Autojoin                      (0)
  ' 1:<  0% In Overlap Checking              (0)
  ' 1:<  0% Reviewing PostedWarnings         (0)
  ' 1:<  51% Other                            (1649866)
  ' 1:< total bytes expanded: 3225240
  ' 1:< ;EES;49;0;0;0;0;0;0;0;51;
  '  6.328431-- 1:<<[Cloud]standardOpenDocumentFile
   'E 30-May-2017 11:19:22.359;   0:<
   ' [Jrn.File Input Information] COMMON.FILE_INPUT.FILE_TYPE: .rvt 03534848.000000
 ' 0:< ::4:: Delta VM: Avail +24 -> 8386832 MB, Used -8 -> 411 MB; RAM: Avail +1 -> 5877 MB, Used -8 -> 579 MB
 ' 0:< GUI Resource Usage GDI: Avail 9236, Used 764, User: Used 382
 'E 30-May-2017 11:19:22.452;   0:<
 Jrn.Size        0 ,   1449 ,    825
 'H 30-May-2017 11:19:22.452;   0:<
         , 1449, 825
 'E 30-May-2017 11:19:22.456;   0:<
 Jrn.Size        0 ,   1429 ,    805
 'H 30-May-2017 11:19:22.456;   0:<
         , 1429, 805
 'E 30-May-2017 11:19:22.466;   0:<
 Jrn.Size        0 ,   1448 ,    824
 'H 30-May-2017 11:19:22.466;   0:<
         , 1448, 824
 'E 30-May-2017 11:19:22.470;   0:<
 Jrn.Size        0 ,   1428 ,    804
 'H 30-May-2017 11:19:22.470;   0:<
         , 1428, 804
' 0:< GContext::getDefaultDpi(): s_defaultDpi = 96
' 0:< ::8:: Delta VM: Avail -38 -> 8386794 MB, Used +37 -> 449 MB, Peak +28 -> 449 MB; RAM: Avail -49 -> 5828 MB, Used +42 -> 622 MB, Peak +33 -> 622 MB
' 0:< GUI Resource Usage GDI: Avail 9220, Used 780, User: Used 387
'  0.822114   1:<<;PERF;MISC;drawing
' 0:< ::8:: Delta VM: Avail 8386794 MB, Used 449 MB; RAM: Avail +15 -> 5844 MB, Used 622 MB
'C 30-May-2017 11:19:23.416;   0:< idle0_doc
'H 30-May-2017 11:19:23.418;   0:<
Jrn.Directive "AllowPressAndDrag"  _
        , 1
' 0:< <<Begin build CT>>
'Command: ID_BUTTON_SELECT
'Category: 0
'Bar list:
'	Dialog_Revit_DynamicLabelDBar
'	Dialog_Essentials_FilterSelectionNew
'Presenter list:
'	PP_DebugTab_Binding_Demo
'Product: Revit
'<<End build CT>>
' 0:< VIDEO CONTROLLER INFORMATION:
' 0:<    AdapterCompatibility : VMware, Inc.
' 0:<    AdapterDACType : n/a
' 0:<    AdapterRAM : 1073741824
' 0:<    Caption : VMware SVGA 3D
' 0:<    CurrentBitsPerPixel : 32
' 0:<    CurrentHorizontalResolution : 1680
' 0:<    CurrentNumberOfColors : 4294967296
' 0:<    CurrentRefreshRate : 60
' 0:<    CurrentVerticalResolution : 1050
' 0:<    Description : VMware SVGA 3D
' 0:<    DriverDate : 20160712000000.000000-000
' 0:<    DriverVersion : 8.15.1.48
' 0:<    MaxRefreshRate : 60
' 0:<    MinRefreshRate : 60
' 0:<    Monochrome : 0
' 0:<    Name : VMware SVGA 3D
' 0:<    VideoArchitecture : 5
' 0:<    VideoMemoryType : 2
' 0:<    VideoModeDescription : 1680 x 1050 x 4294967296 colors
' 0:<    VideoProcessor : VMware Virtual SVGA 3D Graphics Adapter
' 0:< PRINTER INFORMATION:
' 0:<    Caption : Microsoft XPS Document Writer
' 0:<    Default : -1
' 0:<    DeviceID : Microsoft XPS Document Writer
' 0:<    Direct : 0
' 0:<    DriverName : Microsoft XPS Document Writer
' 0:<    EnableBIDI : 0
' 0:<    EnableDevQueryPrint : 0
' 0:<    HorizontalResolution : 600
' 0:<    Local : -1
' 0:<    Name : Microsoft XPS Document Writer
' 0:<    Network : 0
' 0:<    PortName : XPSPort:
' 0:<    PrintJobDataType : RAW
' 0:<    PrintProcessor : winprint
' 0:<    RawOnly : 0
' 0:<    Shared : 0
' 0:<    SpoolEnabled : -1
' 0:<    VerticalResolution : 600
' 0:<    Caption : Fax
' 0:<    Default : 0
' 0:<    DeviceID : Fax
' 0:<    Direct : 0
' 0:<    DriverName : Microsoft Shared Fax Driver
' 0:<    HorizontalResolution : 200
' 0:<    Local : -1
' 0:<    Name : Fax
' 0:<    Network : 0
' 0:<    PortName : SHRFAX:
' 0:<    RawOnly : 0
' 0:<    Shared : 0
' 0:<    VerticalResolution : 200
' 0:< ::8:: Delta VM: Avail -4 -> 8386791 MB, Used +0 -> 450 MB, Peak +1 -> 451 MB; RAM: Avail -11 -> 5833 MB, Used +2 -> 624 MB, Peak +2 -> 625 MB
' 0:< GUI Resource Usage GDI: Avail 9209, Used 791, User: Used 396
' 0:< PRINTER CONFIGURATION INFORMATION:
' 0:<    Color : 2
' 0:<    Copies : 1
' 0:<    Description : Microsoft XPS Document Writer
' 0:<    DriverVersion : 1536
' 0:<    Duplex : 0
' 0:<    Orientation : 1
' 0:<    PaperLength : 2794
' 0:<    PaperSize : Letter 8 1/2 x 11 in
' 0:<    PaperWidth : 2159
' 0:<    PrintQuality : 600
' 0:<    SpecificationVersion : 1025
' 0:<    XResolution : 600
' 0:<    YResolution : 600
' 0:<    Color : 1
' 0:<    Description : Fax
' 0:<    DriverVersion : 1024
' 0:<    Duplex : 0
' 0:<    PrintQuality : 200
' 0:<    XResolution : 200
' 0:<    YResolution : 200
 'E 30-May-2017 11:19:28.717;   0:<
 Jrn.MouseMove    0 ,    440 ,      1
 Jrn.RibbonEvent "TabActivated:Add-Ins"
 'E 30-May-2017 11:19:33.644;   0:<
 Jrn.RibbonEvent "TabActivated:Modify"
 ' 0:< ::11:: Delta VM: Avail -10 -> 8386781 MB, Used +21 -> 471 MB, Peak +20 -> 471 MB; RAM: Avail -19 -> 5815 MB, Used +21 -> 645 MB, Peak +20 -> 645 MB
 ' 0:< GUI Resource Usage GDI: Avail 9163, Used 837, User: Used 397
 'E 30-May-2017 11:19:35.994;   0:<
 'E 30-May-2017 11:19:40.519;   0:<
 Jrn.MouseMove    0 ,   1439 ,   -156
 Jrn.Command "SystemMenu" , "Quit the application; prompts to save projects , ID_APP_EXIT"
 ' 1:< RAM Statistics:     5817 /     8191       645=InUse      645=Peak
 ' 1:< VM  Statistics:  8386781 /  8388607       471=InUse      472=Peak
 ' 1:< API_SUCCESS { Registered an external server: Name(A360); VendorId(ADSK); ServerId(d2c3617d-7a16-45bc-b395-44897852f485); ServiceId(b3892e5f-9161-4bbc-958a-c8ef75e94e96) }
 ' 0:< CrsTimer event occurred for 0 times in DesktopMFCView [Floor Plan: Level 1]
 ' 0:<   System (MB) [Available /  Total ]  [Revit Memory Usage (MB)   ]
 ' 0:< RAM Statistics:     5823 /     8191       641=InUse      646=Peak
 ' 0:< VM  Statistics:  8386785 /  8388607       467=InUse      473=Peak ;oCD;
 ' 0:< Third Party Updater 'Revit: ObjectNumberingUpdater' has been unregistered.
 ' 0:< Before : Destroy Display Manager
 ' 0:< RAM Statistics:     5806 /     8191       643=InUse      646=Peak
 ' 0:< VM  Statistics:  8386785 /  8388607       469=InUse      473=Peak
 ' 0:< After : Destroy Display Manager
 ' 0:< RAM Statistics:     5807 /     8191       643=InUse      646=Peak
 ' 0:< DummyStorage destroying DataStorageInterface 0x000000000D956C70
 ' 0:< ::14:: Delta VM: Avail +11 -> 8386793 MB, Used -3 -> 469 MB, Peak +1 -> 473 MB; RAM: Avail -6 -> 5809 MB, Used -5 -> 640 MB, Peak +1 -> 646 MB
 ' 0:< GUI Resource Usage GDI: Avail 9193, Used 807, User: Used 351
 ' 0:< compact data space: 50068 blocks, occupying total of 15613160 bytes
 ' 0:< freed 50068 blocks
' 1:< ::14:: Delta VM: Avail +11 -> 8386804 MB, Used -2 -> 467 MB; RAM: Avail +121 -> 5931 MB, Used -2 -> 638 MB
' 1:< GUI Resource Usage GDI: Avail 9254, Used 746, User: Used 242
' 1:< Revit worker 1 closed cleanly
' 0:< [000008f0]QueueMinder stopped
'C 30-May-2017 11:19:42.478;   1:< logging finished virtualization services
'C 30-May-2017 11:19:42.478;   1:< logging finished worker services
'C 30-May-2017 11:19:42.479;   1:< logging erased queues
'  1.024966   1:<<<Terminating Slave Processes
'C 30-May-2017 11:19:42.480;   0:< ->desktop ExitManagedInstance
'C 30-May-2017 11:19:42.920;   0:< <-desktop ExitManagedInstance
'C 30-May-2017 11:19:42.920;   0:< ->desktop ExitNativeInstance
' 0:< API_SUCCESS { Unregistering ViewActivated event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Unregistering DocumentClosing event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Unregistering DocumentClosed event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Unregistering DocumentChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Unregistering DockableFrameVisibilityChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Unregistering Idling event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Restoring command id 'ID_MEP_FABRICATION_SETTINGS' CanExecute implementation. }
' 0:< API_SUCCESS { API unregistering command Fabrication Settings CanExecute event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Restoring command id 'ID_MEP_FABRICATION_SETTINGS' Executed implementation. }
' 0:< API_SUCCESS { API unregistering command Fabrication Settings Executed event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Restoring command id 'ID_FABRICATION_PART_SHOW_SERVICE_IN_PART_BROWSER' CanExecute implementation. }
' 0:< API_SUCCESS { API unregistering command Show Service in Part Browser
' 0:< API_SUCCESS { Restoring command id 'ID_EXPORT_IFC' Executed implementation. }
' 0:< API_SUCCESS { API unregistering command Export to IAI IFC (Industry Foundation Classes) file format Executed event by application IFC override (e78da2e3-7e89-464c-97cd-2212c8be3fa8). }
' 0:< API_SUCCESS { Unregistering ViewActivated event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Unregistering ApplicationClosing event by application Ribbon (c82755fa-ff61-5113-9a07-27b2127a13e5). }
' 0:< API_SUCCESS { Restoring command id 'ID_TEAM' Executed implementation. }
' 0:< API_SUCCESS { API unregistering command Communicator Executed event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Restoring command id 'ID_TEAM' CanExecute implementation. }
' 0:< API_SUCCESS { API unregistering command Communicator CanExecute event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering DocumentOpened event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering DocumentCreated event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering DocumentSavedAs event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering DocumentSaved event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering ApplicationClosing event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< ::14:: Delta VM: Avail -5 -> 8386800 MB, Used +0 -> 468 MB; RAM: Avail +11 -> 5942 MB, Used +1 -> 640 MB
' 0:< GUI Resource Usage GDI: Avail 9254, Used 746, User: Used 246
' 0:< API_SUCCESS { Unregistering DocumentSynchronizingWithCentral event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering DocumentSynchronizedWithCentral event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< ::14:: Delta VM: Avail +1 -> 8386801 MB, Used -30 -> 438 MB; RAM: Avail +16 -> 5958 MB, Used -30 -> 610 MB
' 0:< GUI Resource Usage GDI: Avail 9257, Used 743, User: Used 240
' 0:< API_SUCCESS { Unregistering DocumentSavedAs event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Unregistering DocumentOpened event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Unregistering DocumentClosing event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< Forcibly unregistering Updater with id:51c0be9b-07a8-443a-be8c-21db815b17e7
' 0:< Forcibly removing all update triggers for all Updaters
' 0:< Unregistering all external services.
' 0:< ::14:: Delta VM: Avail +4 -> 8386806 MB, Used -5 -> 434 MB; RAM: Avail +13 -> 5972 MB, Used -3 -> 608 MB
'C 30-May-2017 11:19:43.572;   0:< Protein : Unload plug-ins
'C 30-May-2017 11:19:43.572;   0:< Protein : Release Plugins
'C 30-May-2017 11:19:43.574;   0:< Protein : Release Renderer Module
'C 30-May-2017 11:19:43.575;   0:< Protein : Release Plugins
'C 30-May-2017 11:19:43.575;   0:< Protein : Release Renderer Module
'C 30-May-2017 11:19:43.575;   0:< Protein : Destroy RenderingAsset Library Manager
'C 30-May-2017 11:19:43.592;   0:< Protein : ProteinSdkManager has been destroyed successfully
' 0:< ::14:: Delta VM: Avail +80 -> 8386886 MB, Used -60 -> 375 MB; RAM: Avail +68 -> 6040 MB, Used -46 -> 563 MB
' 0:< GUI Resource Usage GDI: Avail 9261, Used 739, User: Used 222
'C 30-May-2017 11:19:43.765;   0:< License cleanup complete: 0, 0
' 0:< Journal Exit
'C 30-May-2017 11:19:43.767;   0:< Log Summary
' 0:< .Count
' 0:< ...CachingEngaged = 1
' 0:< ...ContentDocsLoaded = 66
' 0:< ...ContentDocsLoadedLazy = 66
' 0:< ...DBG_SOMETHING = 4
' 0:< ...DBG_WARNING = 1
' 0:< ...MoribundChecks = 2
' 0:< ...PayloadsLoaded = 67
' 0:< ...PendingMessages = 210
' 0:< ...resolveJoinStructure = 128
' 0:< ...SampleRateNominal = 5
' 0:< ...SampleRateTooLow = 1
' 0:< ...ThreadedExpansions = 2321
' 0:< ...tweakGRepsInView = 24
' 0:< ...UIThreadsCreated = 1
' 0:< ...UIThreadsHighWater = 1
' 0:< ...WorkerRequestHandledImmediate = 3
' 0:< Total session time spent reclaiming memory: 0.000000 seconds.  Averaged 0.000000 seconds/call for 0 calls.
' 0:<               BackgroundLoader exec=     1 (parallel=     1)
' 0:<        ConsumeMultiSegmentFile exec=   280 (parallel=   280)   self=    0.684279 sec (avg=  0.002)
' 0:<             ConsumeVisitBucket exec=    18 (parallel=    18)   self=    0.104475 sec (avg=  0.006)
' 0:<                  FormOrAbandon exec=     3 (parallel=     0)   self=    6.838007 sec (avg=  2.279) rollup=   6.871436 (avg=  2.290)
' 0:<     GIncrementalDrawTaskCanvas exec=     1 (parallel=     1)
' 0:<            InstrumentationTask exec=     1 (parallel=     1)
' 0:<              InvalidateArchive exec=     1 (parallel=     0)
' 0:<                   JoinTweaking exec=     6 (parallel=     2)   self=    0.002446 sec (avg=  0.000)
' 0:<                 PipeliningTask exec=    67 (parallel=    67)
' 0:<                 ProduceArchive exec=   347 (parallel=     0)   self=    0.032587 sec (avg=  0.000) rollup=   0.032513 (avg=  0.000)
' 0:<             ProduceVisitBucket exec=    31 (parallel=    31)   self=    0.001291 sec (avg=  0.000) rollup=   0.001283 (avg=  0.000)
' 0:<                    QueueMinder exec=     1 (parallel=     1)
' 0:<    ReadFileAndPerformOperation exec=    19 (parallel=     0)
' 0:<             RunPipelineContext exec=    13 (parallel=     9)   self=    0.000748 sec (avg=  0.000) rollup=   0.099488 (avg=  0.008)
' 0:<                 TaskFileExists exec=   248 (parallel=   241)
' 0:<                 TaskWaitCursor exec=     1 (parallel=     1)
' 0:< ::14:: Delta VM: Avail +48 -> 8386934 MB, Used -4 -> 372 MB; RAM: Avail +56 -> 6096 MB, Used -16 -> 548 MB
' 0:< GUI Resource Usage GDI: Avail 9284, Used 716, User: Used 211
'C 30-May-2017 11:19:44.293;   0:< <-desktop ExitNativeInstance
'C 30-May-2017 11:19:44.299;   0:< finished recording journal file
Hi Jeremy,
I tried your example
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=16849339
but without any success. What now ?
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
[TransactionAttribute(TransactionMode.Manual)]
[RegenerationAttribute(RegenerationOption.Manual)]
public class Lab1PlaceGroup : IExternalCommand
    public Result Execute(
      ExternalCommandData commandData,
      ref string message,
      ElementSet elements)
        //Get application and document objects
        UIApplication uiApp = commandData.Application;
        Document doc = uiApp.ActiveUIDocument.Document;
        //Define a Reference object to accept the pick result.
        Reference pickedRef = null;
        //Pick a group
        Selection sel = uiApp.ActiveUIDocument.Selection;
        pickedRef = sel.PickObject(ObjectType.Element, "Please select a group");
        Element elem = doc.GetElement(pickedRef);
        Group group = elem as Group;
        //Pick a point
        XYZ point = sel.PickPoint("Please pick a point to place group");
        //Place the group
        Transaction trans = new Transaction(doc);
        trans.Start("Lab");
        doc.Create.PlaceGroup(point, group.GroupType);
        trans.Commit();
        return Result.Succeeded;
<?xml version="1.0" encoding="utf-8"?>
<RevitAddIns>
  <AddIn Type="Command">
    <Assembly>
      c:\28\Lab1PlaceGroup\Lab1PlaceGroup\bin\x64\Release\Lab1PlaceGroup.dll
    </Assembly>
    <ClientId>502fe383-2648-4e98-adf8-5e6047f9dc34</ClientId>
    <FullClassName>Lab1PlaceGroup</FullClassName>
    <Text>Lab1PlaceGroup</Text>
    <VendorId>ADSK</VendorId>
    <VisibilityMode>AlwaysVisible</VisibilityMode>
  </AddIn>
</RevitAddIns>
there are Journal files
' 0:< Initial VM: Avail 8388397 MB, Used 12 MB, Peak 12; RAM: Avail 5694 MB, Used 33 MB, Peak 12
' 0:< GUI Resource Usage GDI: Avail 9996, Used 4, User: Used 1
'C 30-May-2017 15:17:20.302;   0:< RevitWorker.exe 1
'C 30-May-2017 15:17:20.302;   0:< Worker Application Data: isWorkerForRevit=1, Name=RevitApplication, Ver=2015
'C 30-May-2017 15:17:20.302;   0:< ->UI-less InitNativeInstance
' 0:< Options::loadOptions: m_strDataLibraryLocations=Library=C:\ProgramData\Autodesk\RVT 2017\Libraries\Generic\ (defaultLib==\Library)
' 0:< ::0:: Delta VM: Avail -164 -> 8388233 MB, Used +32 -> 44 MB, Peak +38 -> 51 MB; RAM: Avail -14 -> 5681 MB, Used +47 -> 80 MB, Peak +47 -> 80 MB
' 0:< SystemSettings:
' 0:<               4=multiCoreCharacteristic
' 0:<            true=isProcessUserModeExceptionPolicyDisabledForCallbackFilter
' 0:< ::0:: Delta VM: Avail -78 -> 8388156 MB, Used +15 -> 60 MB, Peak +9 -> 60 MB; RAM: Avail -24 -> 5658 MB, Used +27 -> 108 MB, Peak +27 -> 108 MB
' 0:< GUI Resource Usage GDI: Avail 9988, Used 12, User: Used 10
' 0:< Autodesk Revit 2017
' 0:< 64-bit load point = C:\Program Files\Autodesk\Revit 2017
' 0:< this journal =
' 0:< API_SUCCESS { Registered an external service: Name(NavisWorks Draw Service); VendorId(ADSK); ServiceId(e454a471-b9f3-4cb7-96b1-bab4cf7742a6) }
' 0:< API_SUCCESS { Registered an external service: Name(External Resource Service); VendorId(ADSK); ServiceId(b3892e5f-9161-4bbc-958a-c8ef75e94e96) }
' 0:< API_SUCCESS { Registered an external service: Name(NavisworksExportService); VendorId(ADSK); ServiceId(a9bdf0fd-2632-429e-bc35-50ebc2b824d2) }
' 0:< API_SUCCESS { Registered an external service: Name(Code Checking Parameter Service); VendorId(ADSK); ServiceId(de6db8de-dea6-40bd-9503-4ffe62ff6143) }
' 0:< API_SUCCESS { Registered an external service: Name(FramingProfileService); VendorId(ADSK); ServiceId(b2f816c0-6493-4537-8067-78a4e67f559e) }
' 0:< API_SUCCESS { Registered an external service: Name(Modify Connection Parameters Service); VendorId(ADSK); ServiceId(e9c0f948-320e-4e7f-a573-10755555305d) }
' 0:< API_SUCCESS { Registered an external service: Name(Connection Type Changed Service); VendorId(ADSK); ServiceId(e31c3100-9cab-4303-b85b-4171703ce1c4) }
' 0:< API_SUCCESS { Registered an external service: Name(SteelConnectionsService); VendorId(ADSK); ServiceId(282385f9-9627-4057-8b74-826d019f103c) }
' 0:< API_SUCCESS { Registered an external service: Name(Section Type Parameter Service); VendorId(ADSK); ServiceId(c42c9b55-c491-4611-97e9-9e617958e13e) }
' 0:< API_SUCCESS { Registered an external service: Name(Internal Forces Service); VendorId(ADSK); ServiceId(a97444aa-af8d-4a1e-af1f-fa7b77b368ee) }
' 0:< API_SUCCESS { Registered an external service: Name(Duct Fitting/Accessory Pressure Drop Calculator); VendorId(ADSK); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external service: Name(Pipe Fitting/Accessory Pressure Drop Calculator); VendorId(ADSK); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external service: Name(Duct Pressure Drop Calculator); VendorId(ADSK); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external service: Name(Pipe Pressure Drop Calculator); VendorId(ADSK); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Registered an external service: Name(Plumbing Flow Calculator); VendorId(ADSK); ServiceId(bf0da776-5307-4747-8285-f358e92a90d0) }
' 0:< API_SUCCESS { Registered an external service: Name(IFC Export Service); VendorId(ADSK); ServiceId(d8b95737-f943-414c-9ad7-86785bf1acbc) }
' 0:< API_SUCCESS { Registered an external server: Name(Revit IFC Exporter); VendorId(ADSK); ServerId(ef8d0493-7f36-42b5-b9aa-8aaac716482b); ServiceId(d8b95737-f943-414c-9ad7-86785bf1acbc) }
' 0:< API_SUCCESS { Registered an external service: Name(IFC Import Service); VendorId(ADSK); ServiceId(98d317e2-e943-4cc0-a3da-2edf32a5d942) }
' 0:< API_SUCCESS { Registered an external server: Name(Revit IFC Importer); VendorId(ADSK); ServerId(660a7370-f6d6-43c8-8456-6b2eea785110); ServiceId(98d317e2-e943-4cc0-a3da-2edf32a5d942) }
'C 30-May-2017 15:17:20.997;   0:< manage debug modes
'C 30-May-2017 15:17:20.997;   0:< MFCApp::testGraphicsHardware
' 0:< Revit Graphics Information
' 0:< 	Current Mode : DirectX Hardware
' 0:< 	Use Hardware: ON
' 0:< 	Use Overlays : ON
' 0:< START CanUseHardware(forced)
' 1:<
'OGS Device Memory Size: 1152 MB
' 1:< ::0:: Delta VM: Avail -57 -> 8388099 MB, Used +42 -> 103 MB, Peak +44 -> 104 MB; RAM: Avail +2 -> 5660 MB, Used +14 -> 122 MB, Peak +15 -> 123 MB
' 1:< GUI Resource Usage GDI: Avail 9988, Used 12, User: Used 11
' 1:< DX Device: DirectX 11, Hardware
' 1:< DX Device: DirectX 11, WARP
'C 30-May-2017 15:17:21.166;   1:< START video card certification
' 1:< ::0:: Delta VM: Avail -21 -> 8388079 MB, Used +5 -> 108 MB, Peak +3 -> 108 MB; RAM: Avail -11 -> 5650 MB, Used +5 -> 128 MB, Peak +4 -> 128 MB
' 1:<
'Current driver version: 8.15.1.48
'Certified driver(s):
' 1:< VIDEO CARD ENVIRONMENT: CARD="VMware SVGA 3D" ManufacturerID="15AD" DeviceID="0405" osID="2000" DRIVER="8.15.1.48" DEVICE="DX11" FL_Caps="40" (Shader Model)
' 1:< Video card is blacklisted or feature level '40' is too low - cannot use hardware
' 1:< Software Mode Forced
'C 30-May-2017 15:17:21.240;   1:< FINISH video card certification
'  0.242510   1:<<<CanUseHardware(forced)
' 0:<
'Can use hardware=n
'Hardware support flags:
'FeatureLevelLow=n
'DrvOlderThanTested=n
'DrvNewerThanTested=n
'CardIsNotListed=n
'NotCertifiedEnv=n
'3GBSwitchIsOn=n
'SoftwareModeForced=y
' 0:< FINISH CanUseHardware(forced)
'C 30-May-2017 15:17:21.240;   0:< MFCApp::testMSAA
' 0:< 	Current Mode : DirectX Software
' 0:< DX Device: DirectX 11, WARP
'C 30-May-2017 15:17:21.251;   0:< <-UI-less InitNativeInstance
'C 30-May-2017 15:17:21.251;   0:< ->UI-less InitManagedInstance
' 0:< ::0:: Delta VM: Avail -464 -> 8387616 MB, Used +14 -> 122 MB, Peak +15 -> 123 MB; RAM: Avail -22 -> 5628 MB, Used +9 -> 138 MB, Peak +10 -> 138 MB
' 0:< GUI Resource Usage GDI: Avail 9988, Used 12, User: Used 12
' 0:< DBG_INFO: The addin file -AddPanel.addin- in current user folder is duplicated with the one in internal addin folder.: line 525 of AddIn\AddInManagerUtils.cpp.
' 0:< DBG_WARN: The assembly -AddPanel.addin- in internal addin C:\Program Files\Autodesk\Revit 2017\AddIns\AddPanel\AddPanel.dll is not signed as internal addin.: line 802 of AddIn\AddInManagerUtils.cpp.
'  0.231845   1:<<<DictionaryAnalysis::initialize
' 0:< ::0:: Delta VM: Avail -257 -> 8387359 MB, Used +72 -> 195 MB, Peak +71 -> 195 MB; RAM: Avail -149 -> 5480 MB, Used +106 -> 244 MB, Peak +105 -> 244 MB
' 0:< To make IFC server work.
' 0:< ExternalDBApplication KeynoteDBServer.ServerApp (C:\Program Files\Autodesk\Revit 2017\AddIns\Keynote\KeynoteDBServer.dll) was not loaded in RevitWorker
' 0:< API_SUCCESS { Registered an external server: Name(Prutok instalacních zarizovacích predmetu); VendorId(ADSK); ServerId(56121d7d-e1d7-42a3-bed8-f4d1d32058c8); ServiceId(bf0da776-5307-4747-8285-f358e92a90d0) }
' 0:< API_SUCCESS { Registered an external server: Name(Zjednodušená Colebrookova rovnice); VendorId(ADSK); ServerId(ea275fb1-5d7b-47d6-b828-bf856df9bfd5); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Registered an external server: Name(Altshulova-Tsalova rovnice); VendorId(ADSK); ServerId(042a10e0-8d24-46a4-9596-d192b3125d0c); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Haalandova rovnice); VendorId(USERADDIN); ServerId(2e9a77c0-62a0-4693-9442-33312be60ad7); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Haalandova rovnice); VendorId(USERADDIN); ServerId(58ea1b7c-2fca-453f-9ab9-7a3b9927ecc1); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Registered an external server: Name(Colebrookova rovnice); VendorId(USERADDIN); ServerId(e395a0ec-48a4-4255-b957-afbb3d73cb67); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Colebrookova rovnice); VendorId(USERADDIN); ServerId(0875f550-6141-4e34-a6b7-547cf9cfda01); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Starting External DB Application: StraightSegmentCalculationServersApp, Class: StraightSegmentCalculationServers.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\StraightSegmentCalculationServers.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Není definováno); VendorId(ADSK); ServerId(76eff5da-2e71-45f7-b940-cc5716328ba0); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Koeficient z tabulky ASHRAE); VendorId(ADSK); ServerId(8baf7d75-8b9b-46d0-b8ce-3ad1c19e6b19); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Merný koeficient); VendorId(ADSK); ServerId(5a598293-1504-46cc-a9c0-de55c82848b9); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Merná ztráta); VendorId(ADSK); ServerId(46245996-eebb-4536-ac17-9c1cd917d8cf); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Není definováno); VendorId(ADSK); ServerId(61e7b8e1-16d1-4fe4-82f0-327af736323f); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(Koeficient K z tabulky); VendorId(ADSK); ServerId(51dd5e98-a9dd-464b-b286-4a37953610bf); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(Merný koeficient); VendorId(ADSK); ServerId(32d58662-b467-4f7b-b728-f6ad7b7ba5e3); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(Merná ztráta); VendorId(ADSK); ServerId(16f4f7be-0ac0-461d-a9a4-1d3511cd280e); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Starting External DB Application: FittingAndAccessoryCalculationServers, Class: FittingAndAccessoryCalculationServers.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2017\AddIns\MEPCalculation\FittingAndAccessoryCalculationServers.dll }
' 0:< ::0:: Delta VM: Avail -7 -> 8387353 MB, Used +1 -> 197 MB, Peak +2 -> 197 MB; RAM: Avail -15 -> 5465 MB, Used +7 -> 251 MB, Peak +7 -> 251 MB
' 0:< API_SUCCESS { Registered an external server: Name(SteelConnectionsServer); VendorId(ADSK); ServerId(9c209d4a-ec98-460f-bfde-38f17a3443b4); ServiceId(282385f9-9627-4057-8b74-826d019f103c) }
' 0:< API_SUCCESS { Registered an external server: Name(FramingProfileServer); VendorId(ADSK); ServerId(54e490cd-8809-4dbb-84dd-dc0bc6cb1712); ServiceId(b2f816c0-6493-4537-8067-78a4e67f559e) }
' 0:< API_SUCCESS { Starting External DB Application: ExternalResourceDBServer, Class: RvtSteelConnectionsDB.SteelConnectionDBApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2017\AddIns\SteelConnections\RvtSteelConnectionsDB.dll }
' 0:< ExternalDBApplication Autodesk.Revit.UI.Collaborate.CollaborateDBApplication (C:\Program Files\Autodesk\A360 Collaboration for Revit 2017\CollaborateDB.dll) was not loaded in RevitWorker
' 0:< ::0:: Delta VM: Avail -1 -> 8387352 MB, Used 197 MB, Peak +2 -> 200 MB; RAM: Avail +10 -> 5475 MB, Used +2 -> 253 MB, Peak +4 -> 256 MB
'C 30-May-2017 15:17:28.670;   0:< <-UI-less InitManagedInstance
'C 30-May-2017 15:17:28.671;   0:< Start RevitProcessMonitor
'C 30-May-2017 15:17:28.672;   0:< Log Summary
' 0:< .Count
' 0:< ...DBG_SOMETHING = 2
' 0:< .Marshalling
' 0:< ...CompactCaching = 1 (Enabled)
' 0:< .ThreadPool
' 0:< ...ActivePoolSize = 26
' 0:< ...ConfiguredPoolSize = automatic
' 0:< ...ParallelCores = 4
' 0:< ...RequestedPoolSize = automatic
' 0:< .Tuning
' 0:< ...ElemTable = 1 (Serial except when multithreaded)
'C 30-May-2017 15:17:28.697;   0:< logging slave opened MasterQueue Session1268_P0MasterQueue
'C 30-May-2017 15:17:28.698;   0:< logging slave opened SlaveQueue Session1268_P1SlaveQueue
'C 30-May-2017 15:17:28.700;   0:< logging started queue minder
'C 30-May-2017 15:17:28.700;   0:< logging started worker services
'C 30-May-2017 15:17:28.700;   0:< ->Worker accepting requests
' 0:< ::0:: Delta VM: Avail +2 -> 8387354 MB, Used 197 MB; RAM: Avail -276 -> 5200 MB, Used +1 -> 255 MB
' 0:< GUI Resource Usage GDI: Avail 9988, Used 12, User: Used 13
'C 30-May-2017 15:35:40.798;   0:< logging slave liberated
'C 30-May-2017 15:35:40.798;   0:< <-Worker accepting requests
' 0:< [000013b0]QueueMinder stopped
'C 30-May-2017 15:35:40.799;   0:< logging finished virtualization services
'C 30-May-2017 15:35:40.799;   0:< logging finished worker services
'C 30-May-2017 15:35:40.799;   0:< logging erased queues
'C 30-May-2017 15:35:40.800;   0:< Log Summary
' 0:< .Count
' 0:< ...WorkerRequestHandledDeferredSecondary = 1
' 0:< ...WorkerRequestHandledImmediate = 1
'C 30-May-2017 15:35:40.800;   0:< ->UI-less ExitManagedInstance
'C 30-May-2017 15:35:40.837;   0:< <-UI-less ExitManagedInstance
'C 30-May-2017 15:35:40.838;   0:< ->UI-less ExitNativeInstance
' 0:< ::0:: Delta VM: Avail +35 -> 8387390 MB, Used -31 -> 167 MB; RAM: Avail +0 -> 5201 MB, Used -4 -> 251 MB
' 0:< GUI Resource Usage GDI: Avail 9992, Used 8, User: Used 11
' 0:<                  FormOrAbandon exec=     1 (parallel=     0)   self=    0.000347 sec (avg=  0.000)
' 0:<                 TaskFileExists exec=   131 (parallel=   124)
' 0:< ::0:: Delta VM: Avail +45 -> 8387435 MB, Used -4 -> 164 MB; RAM: Avail -2 -> 5200 MB, Used -12 -> 239 MB
' 0:< GUI Resource Usage GDI: Avail 9992, Used 8, User: Used 9
'C 30-May-2017 15:35:41.383;   0:< <-UI-less ExitNativeInstance
'C 30-May-2017 15:35:41.384;   0:< End RevitProcessMonitor
matthew_taylor
It doesn't appear that anything at all is happening, as you describe.
Start a new VS solution using an addin wizard (http://thebuildingcoder.typepad.com/blog/2017/04/revit-2018-visual-studio-c-and-vb-net-add-in-wizard...), and copy-paste your code over. See if that sorts you out. (The post-build event copies the files into the correct place, so you don't need to worry about that - just build it, then start Revit.)
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
Hi, one small step close to success. So I used your MSVS template, I create a new project and copy and paste the source code - compilation ok, but .. I obtained an error at loading to Revit - see below:   What now ???
matthew_taylor
Make sure the classes and namespaces in your code match that shown in the dialog.
Cheers,
-Matt
