How to filter elements through the Tab?
The title is maybe a little confusing. For example, I had a List<Element> elements. As shown in the figure below, the System Tab owns various element types: HVAC type, Fabrication type, Mechanical type, Piping type, Electrical type. I need to classify the elements list by these types. Is there any method to implement this? Revit.png
naveen.kumar.t
Autodesk Support
Autodesk Support
Use FilteredElementCollector to collect elements and get the type of the elements and with the help of the type classify the elements
 FilteredElementCollector Collector = new FilteredElementCollector(doc).WhereElementIsNotElementType();
                IList<ElementId> all_eids = Collector.ToElementIds() as IList<ElementId>;
                IList<ElementId> mech_ids = new List<ElementId>();
                IList<ElementId> elec_ids = new List<ElementId>();
                IList<ElementId> HVAC_ids = new List<ElementId>();
                IList<ElementId> piping_ids = new List<ElementId>();
                IList<ElementId> fabrication_ids = new List<ElementId>();
                foreach(ElementId eid in all_eids)
                    Element e = doc.GetElement(eid);
                    Type T = e.GetType() as Type;
                    if(T.Name.Contains("Mechanical"))
                        mech_ids.Add(e.Id);
                    if(T.Name.Contains("Electrical"))
                        elec_ids.Add(e.Id);
                    if(T.Name.Contains("HVAC"))
                        HVAC_ids.Add(e.Id);
                    if(T.Name.Contains("Piping"))
                        piping_ids.Add(e.Id);
                    if(T.Name.Contains("Fabrication"))
                        fabrication_ids.Add(e.Id);
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous,
You can also approach by using with the below code
 FilteredElementCollector mech_coll = new FilteredElementCollector(doc).OfClass(typeof(MechanicalSystem)).WhereElementIsNotElementType();
                IList<ElementId> mech_ids = mech_coll.ToElementIds() as IList<ElementId>;
Naveen Kumar T
