How to draw List<REX.Common.Geometry.REXxyz>
What is the simpliest way to draw List<REX.Common.Geometry.REXxyz> or List<ContourCont> variable?
jeremytammik
Are these normal XYZ points, more or less?
Do you mean how to draw them in the Revit model?
I assume that you have exactly two options:
  • In a planar view: using detail lines
  • In a 3D view: using model lines
You can check out The Building Coder samples Creator class:
https://github.com/jeremytammik/the_building_coder_samples
https://github.com/jeremytammik/the_building_coder_samples/blob/master/BuildingCoder/BuildingCoder/C...
Maybe it does more or less what you need.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
