I was used to pyAutocad a module which enable me to draw lines, texts and shapes, in Autocad only using python. It´s not necessary to interact with the Autocad project, the python code does all the drawing.
I'm trying to find something similar for Revit, unfortunately I didn't found a module for python alike pyAutocad .
Can you tell me if such a thing exists for Revit? It doesn't need to be in python, but I would like to draw using only code.
Thanks in advance
Hi!
To draw using only code you need to interact with Revit API. And all your "draw" functionality will be limited to what actually Revit API allows users to do in Revit via code.
There are several different approaches to do this. If you are familiar with Python you can use:
More advanced techniques include creating Revit Add-Ins using one of .NET languages.
