Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
How to disable addin on click of another addin in the same ribbon panel
1 REPLY 1
359 Views, 1 Reply
Hi folks,
on click of addin i am doing license check, if that gives me invalid user then i want to disable my other addins in the same ribbon panel,
is it possible in Revit.
Any help appreciated
1 REPLY 1
jeremytammik
There are obviously lots of ways to achieve this.
One very simple method that is supported by the Revit API is to simply disable all your other add-in buttons by turning off their Enabled property:
https://www.revitapidocs.com/2020/1e8498e5-1609-cf26-fb58-012e73db9f5b.htm
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Forma Design Contest
Rail Community
