How to determine if a family parameter is used in a Revit family file
This question concerns only Revit family files (.rfa)
I would like to do some cleanup and to delete the family parameters and the shared parameters that are not used in the document
How to determine that parameters are used (for instance for modeling like dimension, extrusion, ...) or not in a Revit family file ?
Put another way, in the "Family Types" dialog box, if we try to delete a parameter that is used, then the user may be warned that this "parameter is currently used by 1 dimension(s) and/or array(s)".
How to determine such parameters with the api ?
jeremytammik
Maybe you can open a transaction, perform the deletion, and detect whether the UI warning message is displayed or not. If it is, roll back the transaction, and nothing changes. If it is not, the parameter did not cause a warning, and the deletion can be confirmed by committing the transaction.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Thanks Jeremy for your answer.
I don't think that it works.
I use FamilyManager.RemoveParameter but it seems that the api proceeds the deletion silently. No warning message is shown.
Regards
itono
Hello.
I'm facing exactly this problem with deleting parameters in a process using DesignAutomation for Revit.
Any progress on how to determine if a parameter is being used ?
jeremy_tammik
No, no progress as far as I can see, and no ongoing work either.
If this question is important for you, it will probably help if you do some research yourself.
Just guessing, I would suggest that a very effective method to determine whether a parameter is being used could be implemented using a parameter filter, cf.
