I've created a filter based on extracting the triangles from the mesh and extruding them.
The first filter stage is a bounding box filter to reduce the overhead on later slow filters.
Filter class:
Public Class ElementIntersectsElementMeshFilter
Private IntDoc As Document = Nothing
Private IntEl As Element = Nothing
Public Sub New(Element As Element)
IntDoc = Element.Document
IntEl = Element
End Sub
Public Function ToElements() As List(Of Element)
Dim Out As IEnumerable(Of Element) = From x As ElementId In ToElementIds()
Let e As Element = IntDoc.GetElement(x)
Where e Is Nothing = False
Select e
Return Out.ToList
End Function
Public Function ToElementIds() As List(Of ElementId)
Dim Eids As New List(Of ElementId)
'Dim BB As BoundingBoxXYZ = IntEl.Geometry(New Options With {.DetailLevel = ViewDetailLevel.Fine}).GetBoundingBox
Dim BB As BoundingBoxXYZ = IntEl.BoundingBox(Nothing)
Dim Points As XYZ() = New XYZ() {BB.Min, BB.Max}
Dim MaxX As Double = Points.Max(Function(j) j.X)
Dim MaxY As Double = Points.Max(Function(j) j.Y)
Dim MaxZ As Double = Points.Max(Function(j) j.Z)
Dim MinX As Double = Points.Min(Function(j) j.X)
Dim MinY As Double = Points.Min(Function(j) j.Y)
Dim MinZ As Double = Points.Min(Function(j) j.Z)
Dim BBFilt As New BoundingBoxIntersectsFilter(New Outline(New XYZ(MinX, MinY, MinZ), New XYZ(MaxX, MaxY, MaxZ)))
Dim FEC As New FilteredElementCollector(IntDoc)
Dim Eids_L0 As List(Of ElementId) = FEC.WherePasses(BBFilt).ToElementIds
If Eids_L0.Count = 0 Then
Return Eids
Dim Triangles As Solid() = GetMeshtriangleSolids(IntEl)
If Triangles Is Nothing Then Return Eids Else
For i = 0 To Triangles.Length - 1
Dim FECx As New FilteredElementCollector(IntDoc, Eids_L0)
Dim SFilt As New ElementIntersectsSolidFilter(Triangles(i))
Dim C0 As List(Of ElementId) = FECx.WherePasses(SFilt).ToElementIds
Eids = Eids.Union(C0).ToList
Next
Return Eids
End Function
Private Shared Function MakeTriangle(CurveTol As Double, Pt0 As XYZ, Pt1 As XYZ, Pt2 As XYZ) As Solid
Dim V0 As XYZ = (Pt1 - Pt0).Normalize
Dim V1 As XYZ = (Pt2 - Pt0).Normalize
Dim N As XYZ = V0.CrossProduct(V1)
'check short curve tolerance
If Pt0.DistanceTo(Pt1) < CurveTol Then Return Nothing Else
If Pt1.DistanceTo(Pt2) < CurveTol Then Return Nothing Else
If Pt2.DistanceTo(Pt0) < CurveTol Then Return Nothing Else
Dim LN As Line() = New Line() {Line.CreateBound(Pt0, Pt1), Line.CreateBound(Pt1, Pt2), Line.CreateBound(Pt2, Pt0)}
Dim CL As New CurveLoop
For i = 0 To LN.Length - 1
CL.Append(LN(i))
Next
Dim S As Solid = GeometryCreationUtilities.CreateExtrusionGeometry({CL}.ToList, N, 0.05 / 304.8)
Return S
End Function
'Only made this public to highlight form in direct shape
Public Shared Function GetMeshtriangleSolids(El As Element) As Solid()
Dim GeomEl As GeometryElement = El.Geometry(New Options With {.DetailLevel = ViewDetailLevel.Fine})
Dim GeomInst As GeometryInstance = GeomEl.FirstOrDefault(Function(j) j.GetType = GetType(GeometryInstance))
If GeomInst Is Nothing Then Return Nothing Else
Dim GeomEl_Inst As GeometryElement = GeomInst.GetInstanceGeometry()
Dim GeomMesh As Mesh = GeomEl_Inst.FirstOrDefault(Function(j) j.GetType = GetType(Mesh))
If GeomMesh Is Nothing Then Return Nothing Else
Dim TList As New List(Of Solid)
For i = 0 To GeomMesh.NumTriangles - 1
Dim T As MeshTriangle = GeomMesh.Triangle(i)
Dim TSol As Solid = ElementIntersectsElementMeshFilter.MakeTriangle _
(El.Document.Application.ShortCurveTolerance, T.Vertex(0), T.Vertex(1), T.Vertex(2))
If TSol IsNot Nothing Then
TList.Add(TSol)
Next
Return TList.ToArray
End Function
End Class
Usage:
Private Function Obj_210816b(ByVal commandData As Autodesk.Revit.UI.ExternalCommandData,
ByRef message As String, ByVal elements As Autodesk.Revit.DB.ElementSet) As Result
Dim UIDoc As UIDocument = commandData.Application.ActiveUIDocument
If UIDoc Is Nothing Then Return Result.Cancelled Else
Dim IntDoc As Document = UIDoc.Document
Dim R As Reference = Nothing
Try
R = UIDoc.Selection.PickObject(Selection.ObjectType.Element, "Pick element")
Catch ex As Exception
End Try
Dim El As Element = IntDoc.GetElement(R)
Dim Filt As New ElementIntersectsElementMeshFilter(El)
Dim Els As List(Of Element) = Filt.ToElements
For i = 0 To Els.Count - 1
Debug.WriteLine(Els(i).Name)
Next
Return Result.Succeeded
End Function
To visualise the solids being created by the extruded triangles I used this:
Private Function Obj_210816a(ByVal commandData As Autodesk.Revit.UI.ExternalCommandData,
Try
End Try
Dim SList_A As Solid() = ElementIntersectsElementMeshFilter.GetMeshtriangleSolids(El)
If SList_A Is Nothing Then Return Result.Cancelled Else
Dim TList As List(Of GeometryObject) = SList_A.Cast(Of GeometryObject).ToList
Using tx As New Transaction(IntDoc, "Solid mesh")
If tx.Start = TransactionStatus.Started Then
Dim DS As DirectShape = DirectShape.CreateElement(IntDoc, New ElementId(BuiltInCategory.OST_GenericModel))
DS.AppendShape(TList)
tx.Commit()
End Using
End Function
Example direct shape created by above:
I've only done some basic testing with it i.e. three close structural framing elements with one clashing expected but the principle seems sound.
