How to create temporary element?
I am trying to get the bounding box of a familyinstance that is created inside a transcation and use it to adjust its parameter in a single transaction. Here is the code.
using (Transaction t = new Transaction(doc, "Create Multiple"))
                t.Start();
                foreach (View view in views)
                    FamilyInstance fi = doc.Create.NewFamilyInstance(point, symbol, view);
                    BoundingBoxXYZ b = fi.get_BoundingBox(doc.ActiveView);
                    fi.LookupParameter(param).Set(b.Max.X.ToString());
                t.Commit();
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
you can't set the value of instance parameter before creating the family instance in the project.
Instance parameters are accessible only after creating a family instance inside the project.
Your family instance is created only after the transaction gets completed.
To set the value for a parameter, create one more transaction and set the value.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
How do I create another transaction inside a loop and assimilate it in a single transaction to make it undoable once.  I am still new in creating subtransactions.
Got it to work. I thought that the error was in my Subtransaction.
ottosson_mathias
@AnonymousI'm having the same question. Can you share your solution?
Thanks!
LTusche1
Look into TransactionGroups, any transaction that you start and commit within a TransactionGroup, can be rolled back via TransactionGroup.RollBack.
1: Start a TransactionGroup
2: Start regular Transaction
3: Create your element
4: Commit regular Transaction
5: Start another regular Transaction
6: Change parameters
7: Commit regular Transaction
8: Get BoundingBox of your element
9: Rollback the TransactionGroup
Hope this helps.
