How to create Rubber band line in Revit API
kite15
kite15
I have seen an option available to create a rubber band line in AutoCAD API development.
As an Example:
 PromptPointOptions pPtops1 = new PromptPointOptions("");
// Prompt for the first point
pPtops1.Message = "\nSpecify first point : ";
 pPtRes1 = acDoc.Editor.GetPoint(pPtops1);
 pPtops1.Message = "\nSpecify second point : ";
// Use the previous point as the base point
pPtops1.UseBasePoint = true;
pPtops1.BasePoint = pPtRes1.Value;
pPtRes2 = acDoc.Editor.GetPoint(pPtops1);
Point3d pnt2 = pPtRes2.Value;
 Since the first point can used as a base point with asking for the second point.
Can any one help. how it can by imply in Revit API development ?
Thanks in advance.
jeremy_tammik
The official Revit API does not provide support for this.
If you wish to take the risk and hack a bit, here is a possible approach:
kite15
Thank you, Mr. Jeremy,
I have found a similar kind approach in this link.
Link: https://stackoverflow.com/questions/45140151/how-can-i-draw-a-rubber-band-line-while-picking-the-sec...
However, the Revit application does not respond.
The said imaginary line should be displayed until the last point is confirmed.
Please, see the above snap for more understanding.
Thank you.
jeremy_tammik
I recommend that you just stick with the official functionality provided by the Revit API... so no rubber banding...
