How to create non-linear dimensions in project document
Hi everyone,
This seems to be a basic function of Revit, but I have been searching it for a while and could not find the solution. The Revit help (link below) states NewDimension method can create a linear dimension only.
http://help.autodesk.com/view/RVT/2019/ENU/?guid=Revit_API_Revit_API_Developers_Guide_Revit_Geometri...
Then how do we create non-linear dimension, such as Radial dimension, in project document.
I tried the overloaded NewDimension method:
NewDimension(View view,Line line,ReferenceArray references,DimensionType dimensionType)
I tried to supply a non-linear dimensionType to the method, but it throws exception “the dimension type is a non-linear dimension type”.
I know methods available for creating non-linear dimensions in family document, but how about project document?
What am I missing here?
jeremytammik
Hi Steve,
I asked the development team for you.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
