I am creating an app that will check to see if a DWG Export Setting with a specific name exists. If it exists I then grab the export options to use when I export a list of views. If the setting does not exist I would like to create it so that it is available for future exports. Currently everything works, except creating the ExportDWGSetting. When the app tries to create the setting Revit crashes when it reaches the line "ExportDWGSettings.Create(...)". This is coded in the 2015 API. Here is the code I am testing in a macro.
DWGExportOptions option = new DWGExportOptions();
option.ExportingAreas = true;
option.MergedViews = false;
ExportDWGSettings.Create(doc, "TestSetting",option);
Thanks!
Tim
