How to create image as parameter in a family
Hi everyone,
I am trying to add a new parameter to a family, in order to get that I do this
 var familySymbol = (FamilySymbol)annotation.ToList()?.First();
            var famDoc = this._uiDocument.Document.EditFamily(family.Family);
            using (var trans = new Transaction(famDoc))
                trans.Start("Adding parameter");
                var parameterType = ParameterType.Image;
                famDoc.FamilyManager.AddParameter("Symbol image", BuiltInParameterGroup.INVALID, parameterType,
                    true);
                trans.Commit();
But a error occurs,  "Instance parameter of image type is not allowed."
Can I add a image as a parameter using Revit Api?
RPTHOMAS108
The message is telling you that parameter types of ParameterType.Image can only be used for Type parameters, this is the same as in the UI. Therefore:
.AddParameter("Image 1", BuiltInParameterGroup.INVALID, ParameterType.Image, False)
Will work.
.AddParameter("Image 1", BuiltInParameterGroup.INVALID, ParameterType.Image, True)
Will not work.
