How to Create Grid-to-Grid Dimension from Center of Grids in Revit API
emaguilera
emaguilera
Hello everyone,
I’m working on a Revit add-in to create dimensions between selected grids in the active view. I want each dimension line to be created from the center of each grid rather than the default endpoint.
Here's the code I currently have:
public class CreateGridToGridDimension : IExternalCommand
    public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
        UIDocument uidoc = commandData.Application.ActiveUIDocument;
        Document doc = uidoc.Document;
        View view = doc.ActiveView;
        ReferenceArray gridReferences = new ReferenceArray();
        IList<Reference> selectedGrids = null;
        try
            selectedGrids = uidoc.Selection.PickObjects(ObjectType.Element, new GridSelectionFilter(), "Seleccione grillas (presione ESC para terminar)");
            if (selectedGrids.Count < 2)
                message = "Debe seleccionar al menos dos grillas.";
                return Result.Failed;
            foreach (Reference gridReference in selectedGrids)
                gridReferences.Append(gridReference);
            using (Transaction t = new Transaction(doc, "Create Perpendicular Grid Dimensions"))
                t.Start();
                for (int i = 0; i < selectedGrids.Count - 1; i++)
                    // Obtener las grillas seleccionadas
                    Grid grid1 = doc.GetElement(selectedGrids[i]) as Grid;
                    Grid grid2 = doc.GetElement(selectedGrids[i + 1]) as Grid;
                    if (grid1 == null || grid2 == null)
                        message = "No se pudieron obtener las grillas seleccionadas.";
                        t.RollBack();
                    Line dimensionLine = Line.CreateBound(grid1.Curve.GetEndPoint(0), grid2.Curve.GetEndPoint(0));
                    ReferenceArray dimensionReferences = new ReferenceArray();
                    dimensionReferences.Append(selectedGrids[i]);
                    dimensionReferences.Append(selectedGrids[i + 1]);
                    Dimension dimension = doc.Create.NewDimension(view, dimensionLine, dimensionReferences);
                t.Commit();
        catch (Autodesk.Revit.Exceptions.OperationCanceledException)
            return Result.Cancelled;
        catch (System.Exception ex)
            message = ex.Message;
        return Result.Succeeded;
  • c
ctm_mka
instead of using the endpoints in your code,
you can get the midpoint of each curve like this:
Curve.Evaluate(0.5, true)
