A SAT file is a Standard ACIS Text file:
https://en.wikipedia.org/wiki/ACIS#File_format
> SAT files are ASCII text files that may be viewed with a simple text editor. A SAT file contains carriage returns, white space and other formatting that makes it readable to the human eye. A SAT file has a .sat file extension.
https://en.wikipedia.org/wiki/ACIS#Structure_of_the_Save_File
> Specification of SAT format for version 7.0 (circa 2001) has been made publicly available.
So, you can write the SAT file yourself.
Where does the solid geometry that you wish to save and import come from?
Is it just in your head, or do you have some hard data to use to generate it?
Here are some more details and an example:
http://paulbourke.net/dataformats/sat/sat.pdf
If you don't want to generate the SAT directly yourself, you can generate direct shape in Revit and save that as a SAT:
https://thebuildingcoder.typepad.com/blog/2012/01/export-walls-and-floors-to-sat.html
