How to create arc length dimensions in project by revit api ?
DinhMinhDuc
DinhMinhDuc
Hi everyone,
This seems to be a basic function of Revit, but I have been searching it for a while and could not find the solution. The Revit help (link below) states NewDimension method can create a linear dimension only.
http://help.autodesk.com/view/RVT/2019/ENU/?guid=Revit_API_Revit_API_Developers_Guide_Revit_Geometri...
Then how do we create non-linear dimension, such as Radial dimension, in project document.
I tried the overloaded NewDimension method:
NewDimension(View view,Line line,ReferenceArray references,DimensionType dimensionType)
I tried to supply a non-linear dimensionType to the method, but it throws exception “the dimension type is a non-linear dimension type”.
I know methods available for creating non-linear dimensions in family document, but how about project document?
What am I missing here?
raswart
You can use the AngularDimension Class to achieve this :
https://apidocs.co/apps/revit/2022/2e3b9201-d5fa-3cdb-53e4-8e204bda1fe5.htm
DinhMinhDuc
Thank you very much !
