How to create a Slanted wall with Revit API? (python)
Im trying to develop script for myself in dynamo(Revit 2021), but I don't understand how can I create the slanted wall? According to this blog of changes in revit 2021, there are such parameters for creating inclined walls as BuiltInParameter.WALL_CROSS_SECTION. However, there are no examples of using them to existing parameters or classes. Therefore, I do not understand exactly where to use it at the stage of creating a line or wall and what should be the appeal?
The part of the code where the wall itself is created, in the end I tried to turn to the wall and change its orientation parameter to an inclined one, because there are no other appeals.
import sys import clr clr.AddReference('ProtoGeometry') from Autodesk.DesignScript.Geometry import * clr.AddReference('RevitServices') import RevitServices from RevitServices.Persistence import DocumentManager from RevitServices.Transactions import TransactionManager doc = DocumentManager.Instance.CurrentDBDocument clr.AddReference('RevitAPI') import Autodesk from Autodesk.Revit.DB import * clr.AddReference('RevitNodes') import Revit clr.ImportExtensions(Revit.Elements) clr.ImportExtensions(Revit.GeometryConversion) # points for line p_tp_1_1 = XYZ(x_tp_1_1, y_tp1, levels.get_Parameter(BuiltInParameter.LEVEL_ELEV).AsDouble() + size_of_batten_1v_width) p_tp_1_2 = XYZ(x_tp_1_2, y_tp1, levels.get_Parameter(BuiltInParameter.LEVEL_ELEV).AsDouble() + size_of_batten_1v_width) # Draw a line wall_line_tp1 = Line.CreateBound(p_tp_1_1, p_tp_1_2) # Create a Wall wall_tp1 = Wall.Create(doc, wall_line_tp1, type.Id, levels.Id, h_tp_1, z_tp1, 0, 1) wall_tp1.Orientation(BuiltInParameter.WALL_CROSS_SECTION(1))
All informations for points are getting from excel file.
I waiting for feedback. Also if you have С# or С++ cod - it count too, I'll try to adapt it to python. Thanks for any help!
