01:39 AM
I just wanted to learn Revit API and create a simple wall using ExternalCommand.
I think my problem is here:
var symbolId = document.GetDefaultFamilyTypeId(new ElementId(BuiltInCategory.OST_Walls));
When I debug it symbolId always -1.
Can you help me what is wrong with this code snippet?
public Autodesk.Revit.UI.Result Execute(
Autodesk.Revit.UI.ExternalCommandData command_data,
ref string message,
Autodesk.Revit.DB.ElementSet elements)
var document = command_data.Application.ActiveUIDocument.Document;
var level_id = new ElementId(1526);
// create line
XYZ point_a = new XYZ(-10, 0, 0);
XYZ point_b = new XYZ(10, 10, 10);
Line line = Line.CreateBound(point_a, point_b);
using (var transaction = new Transaction(doc))
transaction.Start("create walls");
Wall wall = Wall.Create(doc, line, level_id, false);
var position = new XYZ(0, 0, 0);
if (symbolId == ElementId.InvalidElementId) {
transaction.RollBack();
return Result.Failed;
var symbol = document.GetElement(symbolId) as FamilySymbol;
var level = (Level)document.GetElement(wall.LevelId);
document.Create.NewFamilyInstance(position, symbol, wall, level, StructuralType.NonStructural);
transaction.Commit();
return Result.Succeeded;
