How to create a reference line in revit API
I'm trying to create a reference line (not a reference plane) between two points on a plane. I couldn't find any method except for one method that changes the type of a model curve to a reference line. How can I do that through API?
for instance, please assume these two points:
XYZ point1 = new XYZ(30, 12, 0);
XYZ point2 = new XYZ(10, 30, 0);
Thanks a lot in advance!
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
Try using the below code
 Plane P = Plane.CreateByNormalAndOrigin(XYZ.BasisZ, new XYZ(0, 0, 0));
            SketchPlane sp = SketchPlane.Create(doc, P);
            XYZ startPoint;
            XYZ endPoint;
            Line l1 = Line.CreateBound(startPoint,endPoint);
            ModelLine mLine = doc.FamilyCreate.NewModelCurve(l1,sp) as ModelLine;
            if (mLine!=null)
                mLine.ChangeToReferenceLine();
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
