How to create a new "project" parameter? Not SHARED parameter
onureFFSPL
onureFFSPL
Hello.
Please check this project parameter I created manually for "View" elements. Now I need to create it via Revit Api and C#.
I am somewhat experienced programming for Revit Api but all solutions I can find on Internet are for creating a shared parameter. I need to create a project parameter just like in this screenshot.
Can you please help?
ricaun
Create project parameter is not available in the Revit API, only Shared parameter. 😅
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
Moustafa_K
Not sure this is the best way to do it, but you may try as follow [not tested]:
1. store or save the current shared parameter file if any.
2. creating a temporary shared parameter file,
3. create the shared parameter you are looking to have,
4. then remover this temp shared parameter file
UiApp.Application.SharedParametersFilename = null
5. or restore back the original shared parameter file
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
onureFFSPL
I ended up creating a Global text parameter and storing the data in it by converting the data into Json string. The data contains the View3D elements' UniqueId. This way I am able to store all the data specific to each View3D element; not on the element itself as a regular parameter but in the single global parameter in Json format.
I hope this helps other people who read this in the future.
