How to create a execute file or msi in c#??
Hi!
I wanna create a execute file for my Add-in.
First I tried this way.
1. Add Setup Project to Solution Project
2. Right Click Application Folder in Setup and Add Project Output
3. Build Solution
But it didnt work..
Is there other way ???
Hello!
You should probably check out My First Revit Plugin Overview, if you want to get a hang how to go from a solution in Visual Studio, to working Add-In in Revit.
You can find it here: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/simplecontent/content/my-fi...
If you're past this point, please describe your problem in more detail.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
Opensource:
For creating Industrial scale deployment packages:
http://wixtoolset.org/documentation/manual/v3/main/
Default:
For creating simple deployment packages:
https://www.c-sharpcorner.com/UploadFile/1492b1/creating-an-msi-package-for-C-Sharp-windows-application-using-a-v/
Comments: Simple, 1 hour googling should get things sorted.
Paid\Freemium:
https://www.advancedinstaller.com/user-guide/tutorial-ai-ext-vs.html
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Thank you for  your reply.
I tried this Url https://www.c-sharpcorner.com/UploadFile/1492b1/creating-an-msi-package-for-C-Sharp-windows-applicat...
But It didn't work.
There is a setup folder but no exe file.
I wonder my visual studio setting can be problem.
Here is my setting.
RevitAPI and RevitUIAPI's Copy Locals are False;
and my add-in manifest's Copy to Output Directory is Copy if newer
Start external program is Revit.exe
and Post-build event command line in Build Events is copy "$(TargetDir)"."" "$(AppData)\Autodesk\Revit\Addins\2019\".
I really want to create an exe file for distribution.
I want to upload my application to Autodesk app store
Thank you for your reply!
I have create an add-in using Visual Studio 2017.
I want to create an exe file for distribution.
I add Setup Project to my Solution Project.
When i built my project, There is a setup folder but no exe file in there.
I wonder my setting can be problem or other problem.
Here is my setting.
Please Helps me.
thank you!
jeremytammik
You can contact the AppStore team directly for advice and help on creating the installer and submitting an add-in to the AppStore:
https://thebuildingcoder.typepad.com/blog/2018/10/revit-add-in-locations-and-bim360-eu.html#4
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
shashank.baganeK2K5N
Hi @naveen.kumar.t  I have already msi file for revit 2022. But I want to give only paths of Revit 2020, 21, 23, and 24. By default the path is given for revit 2022. Can you please guide me how to do this or how to achieve it ?
I really appriciate your time and support.
