How to create a dimension between two reference plane without any other elements?
2326751326
2326751326
How to solve this problem?
Hint: The two references are not geometrically aligned so the Alignment cannot be created.
My code:
UIDocument uidoc = commandData.Application.ActiveUIDocument;
Autodesk.Revit.DB.Document doc = uidoc.Document;
Transaction transaction = new Transaction(doc, "New Dimension");
transaction.Start();
XYZ rp1point1 = new XYZ(0, 0, 0);
XYZ rp1point2 = new XYZ(0, 100, 0);
XYZ rp1point3 = new XYZ(0, 0, 10);
XYZ rp2point1 = new XYZ(50, 0, 0);
XYZ rp2point2 = new XYZ(50, 100, 0);
XYZ rp2point3 = new XYZ(50, 0, 10);
try
ReferencePlane referencePlane1 = doc.Create.NewReferencePlane(rp1point1, rp1point2, rp1point3, doc.ActiveView);
Autodesk.Revit.DB.Reference reference1 = referencePlane1.GetReference();
ReferencePlane referencePlane2 = doc.Create.NewReferencePlane(rp2point1, rp2point2, rp2point3, doc.ActiveView);
Autodesk.Revit.DB.Reference reference2 = referencePlane2.GetReference();
try
Dimension dimension = doc.Create.NewAlignment(doc.ActiveView, reference1, reference2);
catch
TaskDialog.Show("Hint", "Create Dimension Failed.");
catch
TaskDialog.Show("Hint", "Create Reference Planes Failed.");
transaction.Commit();
return Result.Succeeded;
jeremy_tammik
I do not believe that Revit supports dimensioning between non-aligned geometry. Can you achieve that manually in the end user interface? If not, then you cannot do so programmatically either.
Of course when we create two reference planes manually in the view, then we can create a dimension by aligned dimension tool.
But why it hints the two reference planes are not geometrically aligned when we create the alignment dimension by RevitAPI?
