how to copy ViewSection from one document to other document
Hi all,
I want to import all viewsection from one rvt to my opened rvt.
as i am able to import viewplan but not viewsection
How to import viewsection from one document to another document.
jeremytammik
Please search for the corresponding sample demonstrating this exact functionality in the Revit SDK.
  • DuplicateViews -- Summary: Use the copy paste APIs to copy drafting views and schedules from one document to another. The drafting view contents will also be copied.
Please perform some own search before asking any question, e.g., check the help documentation, developer guide, SDK samples and previous threads here in the forum before rasing  an new thread. It will save time and effort for both you yourself and others, besides making you a better and more competent programmer able to solve your own problems, and maybe more besides...
Thank you!
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Hi jeremy,
i can copy elements anything other than ViewSection
jeremytammik
Oh I see. Can you copy and paste section views manually in the end user interface?
Jeremy Tammik
The Building Coder
Manually, I can't. in the end user interface.
jeremytammik
Why not? What happens? Or what is stopping you?
Anyway the CopyElements API will only enable you to achieve programmatically what you can do in the UI with copy and paste as well, afaik.
Jeremy Tammik
The Building Coder
