How to convert a Revit plugin from english to other languages?
Hey everybody,
I have been developing revit plugins for past 1-2 years in English language. I intend to convert my plugin into other languages so that I can make it useful for people all around the world. I would appreciate if anybody could help me with the procedure for doing so.
Thank you
Padmanabh
lukaskohout
You can use Resources with string table:
https://stackoverflow.com/questions/1142802/how-to-use-localization-in-c-sharp
Try Googel for more details.
Hitting Accepted Answer is a Community Contribution from me as well as from you.
Thank you very much, it helped me. Sorry for the late reply.
Padmanabh.
How do you do it? @Anonymous
Command code:
    [Transaction(TransactionMode.Manual)]
    [Regeneration(RegenerationOption.Manual)]
    public class Command : BaseCommand
        private FamilyTreeForm form;
        protected override void Execute(ElementSet elements)
            CultureInfo.DefaultThreadCurrentCulture = new CultureInfo(Resources.Language);
            CultureInfo.DefaultThreadCurrentUICulture = new CultureInfo(Resources.Language);
            form = new FamilyTreeForm(doc, mainHandle);
            form.ShowDialogPlus();
Addin file:
   <AddIn Type="Command">
      <Assembly>FamilyTree\FamilyTree.dll</Assembly>
      <ClientId>86317968-1B3F-4E8F-942E-0F4510BB5BC4</ClientId>
      <FullClassName>Tom.FamilyTree.Command</FullClassName>
      <Text>FamilyTree</Text>
      <VisibilityMode>AlwaysVisible</VisibilityMode>
      <LanguageType>Unknown</LanguageType>
      <VendorId>TOM</VendorId>
      <VendorDescription></VendorDescription>
  </AddIn>
Reference: https://forums.autodesk.com/t5/revit-api-forum/language-resources-are-not-parsed-properly/td-p/11502581
All of the above seems to be useless.
Here are the latest discussions:
https://forums.autodesk.com/t5/revit-api-forum/issue-with-languagetype-in-addin-manifest-for-localization/m-p/11512935#M66903
I seem to have made a closer to the correct answer in this discussion thread. There is still a doubt in there, LanguageType seems to be just a text identifier and seems to have no real value in sight.
